1. Noahdoge
    Noahdoge Active Member
    215
    148
    Mississippi
    Did the rear brakes on my 2012. I cleaned all the rust off the bracket. Properly lined up the caliper. Greased sliding pins. I used advics pads and rotors. Should I take it back apart? Anything you’d look for? Both wheels spin free and are not dragging, also no brake noise or shudder.
  2. bbrages
    bbrages Member
    165
    47
    St. Louis
    In my opinion -- this is just something that happens with hybrids. I guess the brake pads don't get enough use and the rotors corrode faster than the pads can keep them smooth. If it causes poor performance, replace the rotors.
    I've seen this in a Prius and also on my Accord Hybrid.
  3. Noahdoge
    215
    148
    Mississippi
    I guess my main concern is my old rotors were clean and didn’t have these grooves. I’ve also used neutral braking multiple times trying to clean it up. It helped a little but not much. These only have less than 1,000 miles on them too.
  4. Mendel Leisk
    41,814
    Did you compare the shape of the old and new pads? Maybe the aftermarket pads are not sweeping that rusty zone? Or the rotor dim's are different?
    It's never occurred to me to use anything other than the car companies products, over the years, keeps it simple(r).
  5. Tombukt2
    13,268
    2,396
    Yeah even on my cheap pads and rotors I get reasonably clean silver swipes . I. Using the ray estos burgundy labeled pads and cheap slotted X drilled rotors and these have been on car like 85K miles . Still look reasonably new
  6. Noahdoge
    215
    148
    Mississippi
    The rotors are advics which is the manufacturer for the rear rotors on the Prius. It was exactly the same. Also the pads I used to have was Wagner oex. The new advics pad goes basically to the painted black line.
  7. Noahdoge
    215
    148
    Mississippi
