Prius trunk LEAKS pictures compilation - common problem areas. prius 2004-2015
Discussion in 'Gen 2 Prius Main Forum' started by tri4all, Nov 30, 2020.
  1. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Yeah. I'll be doing this to both my Prii. Now that I live where it rains a lot more this is a concern.
    Great Thread.
    On a side note I'm on a job in Miami and got AVIS to give me a 2022 Prius as my rental car for the week. WOW very different then my 08. Obviously... Not crazy about the center console display being in the middle. Mine is a base model I think. NAV not installed...how do I see if I have HUD?
  2. Annie P TPW
    Annie P TPW New Member
    Hi Everyone - let's make sure to CALL Toyota HQ for issues like this leaking trunk. IF enough of us report this, they may issue a recall or offer service to fix. I just called them to let them know, and forwarded this thread: (800) 331 - 4331
    But, they need each of us to call and report!
  3. dolj
    dolj Senior Member
    8,622
    4,376
    Wellington, New Zealand
    I doubt you will get any traction on a 19-year-old model, regardless of how many people contact "HQ" and I wouldn't hold my breath waiting for a recall.
    At this juncture, you just need to apply a little sealer to the affected areas and call it a day.
  4. Annie P TPW
    I hear you! I was rear ended by a truck in August. And since then have this leaking issue. Never had any leaking before. I'm taking my car into Toyota Service to verify what the cause of my leaking is....bc my car insurance needs to fix this!
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    As this entire post suggests this car has leak issues and doesn't need a rear end accident to leak. Its a rare 07 that does not leak including mine.
    In the present I would be more concerned the 12 volt battery may be sitting in a pool of water and if not dealt with could rot out that battery well and the battery could fall out.
    Someone needs to grab a flashlight and look in that 12 volt battery battery well and check to see if its filled with water like many and I can guarantee it wont be your insurance company.
  6. rm04
    rm04 Member
    53
    27
    United States
    This was a huge headache for me when I first got my gen2..took it to a good body shop and they poured water in different areas on the hatch to locate the leak points
    Toyota really dropped the ball on this one..really hesitant to buy a 2023 Prius because of their track record with new releases..
    PriusCamper likes this.
  7. Recall
    Recall New Member
    So. Cal.
    2016 Prius c
    The "hatch leak" problem should be added to the recall list and this is why.
    RUST.
    The entire battery bar is rusted. I have had to scrape the bar down and add wd 40 to it. Not a smell or a material you want in your car. Thermite only needs rust and magnesium to combust. Scary..and its sitting on top and next to two batteries. These are childrens seats. It is not safe.
    NO RESOLVE.
    There is no way to stop the leak (unless you get a plastic tarp; cant drive with a plastic tarp on). There is no product that can be bought via toyota or a retail box store to stop the leak (that i am aware of).
    On average, in one storm while parked and in motion i take in about a half gallon to a gallon of water. Had i not bought a rubber trunk mat water would have a direct route to the battery area.
    ACCESSORIES. The car camera i bought fogged up, condensed and stopped working. Any accessories you buy are going to have the same problem.
    MOLD. Mold and mildew follows. I can not reasonably air the car out after every storm.
    Lastly, what really pisses me off....there is a (3 year?) WARRANTY for the battery. Yet there is only one location in california to make the switch. I missed the warranty date this year and it pisses me off. Im left with a very inefficient prius that shoukd be going 500 miles per fill and instead gets half. I could have bought an older car for 1/4 of the cost and crashed it a thousands times and be ok with no water leak.
    Idk toyota always had great cars and this prius c leaves a bad mark. The hatch leak problem is recall worthy and should follow under the LEMON LAW.
    #27 Recall, Apr 7, 2024
  8. Recall
    Recall New Member
    So. Cal.
    2016 Prius c
    I forgot to meantion. Some windows roll down glitchy while sone wont roll down at all. Also, the passenger side electrical doesnt work at all.
  9. dolj
    dolj Senior Member
    8,622
    4,376
    Is this the Prius c in your profile that has this leak problem?
    Why do you say this?
  10. Troy1994
    Troy1994 New Member
    Netherlands, Europe
    Thanks for the detailed pictures! I knew about the roof leak, the others are a surprise!
    Leaks are fixable with caulk, I used silicone on my ‘08 Prius 2. Caulked both trim sides and no more standing water in the trunk. I treated the surface rust with Zinc spray, it stops rust and corrosion and dries fast. It leaves a light grey finish behind.
    C Wagner likes this.
  11. Troy1994
    Troy1994 New Member
    Netherlands, Europe
    Update since my last reply, it started leaking again. Now it’s leaking in front of the pressure vent (driver side). There was a pool of water in the vacant compartment underneath it. I was in the car when disassembling the liner, saw it dripping. Videotaped it right away. Going to hose it down soon to identify other leaky areas.
  12. jonatan R
    jonatan R New Member
    Fairhope AL
    This is very helpful information! Thank you for sharing. Although I have a question. How does the water get threw the top protective layer (the carpet and cloth)?
  13. tri4all
    tri4all Member
    99
    Pacific Northwest
    can you share pictures or videos. thanks
  14. Stephen Feather
    Stephen Feather Junior Member
    Atlanta
    I have a 4th gen and after the recent snow and ice here in Georgia, water was discovered in the spare tire well and had run forward under the rear seats and onto the floor pan on the rear floor.
    This is a great thread! Thank you to the OP for the photos. I had already suspected the drains behind the taillights but this confirmed in advance what I should be looking for.
  15. Zoey123
    Zoey123 New Member
    Is there anyway to get this covered by Toyota? This sounds like a huge quality issues regardless of age. The exact same issues are happening to my 2016 Prius 4 and I'm trying to fight them to get it covered because there's no way a reasonable consumer would be able to diagnose these leaks and prevent them on their own.
  16. James Analytic
    394
    59
    Michigan
    I'll chime in in regards to the gen 2's; as I am wondering this season that one of the causations, if not single cause, being ice jammed between the hatch and roof hatch recessed area so when opening the hatch and applying loads on the seams they tend to crack from that loading vector not well designed to accommodate for?
    I don't recall noticing in prior years, though might be this season has been rather icier than the last few or I was oblivious to prior.
    Finally, I'll note that the single sided self-adhesive foam sheets (Silly Winks) work great as a cost effective option for making gaskets for the penetrations through the hatch and body. The only where I tend to find more stubborn, and the foam alone doesn't always cooperate in sealing, are the two Philips head screws that hold the rear bumper on.
    Any suggestions with those for stock or improved methods or just plan next time I address, plan to apply silicone? Type 1 (vinegar smelling) is one of the better adhesive quality and the Type 2 (ammonia smelling) is not so good at being an adhesive. Though if applied thicker with a skin cured prior to tightening is usually a suitable method to seal IMO.
    The more I think about, the one bumper that did give me trouble was maybe more user error as I didn't completely remove the bumper and didn't use better practices.
    #36 James Analytic, Feb 24, 2026
  17. PriusCamper
    PriusCamper Senior Member
    13,299
    5,374
    Pacific Northwest, USA
    Everything leaks when it gets old... Every Prius I've worked on that's 10 years or older has water damage. And yes there's some serious design defects in the Prius line, but they're all by most people's standards an end of lifespan issue rather than premature.
