2009 classic fuel tank issues but also gauge?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tollkeen, Feb 25, 2026 at 11:27 AM.
  1. tollkeen
    tollkeen Junior Member
    Four Touring
    2009 Prius. Always had the classic fuel tank issues due to the bladder - lower capacity, certain pumps pumping too fast and clicking off immediately, seasonal variability in how successful gas pumping is. We always fill a bar or two before empty (before reading up about the bladder, we thought our gauge was just bad and we were always keeping tank half-full). This past week, gauge hit flashing empty on commute and I went for gas. Costco pump, started clicking immediately. I figured it surely needed at least a couple gallons, so I pumped in a few while fighting the constant clicks.
    But now, gauge is still flashing empty. Tried adding gas at several other stations over the space of a few days. Same issue, constant clicking, gauge still flashing empty. A few times the gas has actually seemingly gone all the way up the filler neck and started to come out, so it does seem to be near-full, whatever the capacity is.
    So, a couple questions. Is the only real fix to replace the whole $1500 assembly? I've seen posts about being able to slowly stretch the tank back out when warmer weather hits again. Second, is there a way to get the gauge working again without replacing the whole tank? I'm fine with limited capacity as long as it's at least like 5 or 6 gallons; we've dealt with that fine so far. I've tried the gauge reset instructions but had no luck.
    Also, is it worth $100 to get a diagnostic from the local dealer? Will they know any more?
  2. Tombukt2
    13,289
    2,397
    Diagnostic ... No .so filling up till at neck like you can see it . Then going 300 miles and uhhh repeat ? No possible ?cannot remember to set trip?
  3. dolj
    dolj Senior Member
    8,522
    4,325
    Wellington, New Zealand
    The bladder gets blamed a whole lot for these issues, but the same issues I read about on US cars with the bladder exist in cars without.
    Your issue is most likely a restricted ventilation pipe somewhere in the system. You will need a good mechanic well versed in the how the ORVR works.
    See this very good post by ChapmanF – Issue somewhere in the onboard refueling vapor recovery (ORVR) system.
    Also, the flashing gauge could be because there was a problem with the 12 V power supply. Check that your 12 V battery is fully charged then test its capacity. Auto parts store do that sometimes for free, in the hopes they can sell you a battery.
    I hope that helps.
    BiomedO1 likes this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,080
    1,995
    NJ-USA
    Most of the Gen 2 fuel tanks that I have replaced were done to correct fuel gauge problems. The level sensor inside gets worn and goes "open circuit" - which the dash gauge shows as 1 flashing bar.
    No, the whole tank assembly is sealed, and I don't know of any (reasonable) way to repair it.
    You can remove the rear seat base and access the fuel tank electrical connector to test sender resistance. It should read around 4 ohms "full" to 110 ohms "empty". If it is much higher (Kilo to Mega ohms), then it's bad.
    I believe it should be these two terminals (a brown and a black wire) prius%20tank%20conn.jpeg
  5. BiomedO1
    4,018
    2,109
    SacTown, Ca
    I had a similar issue on my old S10 pickup. It was my weekend dirt hauler, so i didn't want to spend money to fix it. I checked the float and it was working, but outside it's specified range. So I did some math and spliced in a resistor to get everything back into operating range.
    A few years later, I drove it to Pick-n-Pull for the $1500 gross polluter buy-out program. KBB stated it was worth $800. The Pick-n-Pull guy took one look at it and stated - "cars needs to run 50 yards on it own power to qualify". I said; does driving it here 20 miles from home qualify?
    YMMV
  6. Tombukt2
    13,289
    2,397
    Get a UK tank .no bladder . Someone's already fitted a Corolla tank and has it working . Put US pressure sensor in a yeti cup or similar . He has no. Lights I believe .
