Replacing spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by avoice217, Dec 19, 2025.
  1. indel
    indel Member
    261
    83
    Northwest Indiana
    Where exactly is this vent on a 2012?
  2. Mendel Leisk
    41,824
    It was here:
    wider view:
    Close up:
    In later model years, the main component is still there, and the same hoses connect, but the white cap is gone, which you could turn to allow air or coolant to flow through the spigot on the side.
    #62 Mendel Leisk, Jan 14, 2026
  3. indel
    indel Member
    261
    83
    Northwest Indiana
  4. ChapmanF
    18,454
    Yes, if your car has that valve and you want to use it, you can, and it will behave as described.
    Toyota later decided there was no need for it, or any of that related business in the instructions, and the later gen 3s still can be filled with coolant.
  5. rjparker
    10,411
    6,521
    I have never done anything on my 12v's coolant drain and fills other than leaving the reservoir cap loose during the initial warmup.
    Trapped air is not a problem unless combustion gasses are entering the pressurized system.
  6. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    Yes.
    It was already "gone" by the time they made my [late-year] 2011, so would likely be missing from a 2012.
  7. ChapmanF
    18,454
    You can also leave a gen 3's reservoir cap closed during the initial warmup, like the repair manual says to. There is enough headspace in the degas bottle to receive the air that circulates back.
    I'm not sure why they went out of their way to say put the cap on, but one guess could be that when you let the system reach pressure, any bubbles are half as big, and maybe circulate back to the bottle more easily.
  8. Mendel Leisk
    41,824
    Last fall I did engine coolant replacement (and inverter coolant), folllowed the repair manual instruction to fill reservoir to “B” line, cap reinstalled, run in maintenance mode. Worked well, coolant dropped, to slightly above full line IIRC.
    One thing, after running engine for about 20 minutes I figured it was done. Topside hoses felt hot. I had the front raised and engine under panel removed, so shut off the car and went under to replace under panel, felt a couple of hoses under there, and unlike the (toasty) topside ones, they were still stone-cold.
    accordingly, I restarted car in maintenance mode, crawled back under, and just lay there, reflecting on life an such, occasionally checking on the hose temps. Eventually they started warming, presumably due to thermostat opening, and got hot quite quick, in just a few minutes.
    Then I dubbed it done.
    CR94 likes this.
  9. indel
    indel Member
    261
    83
    Northwest Indiana
    I assume this was only on the ICE side, since there is no thermostat on the inverter side.
  10. avoice217
    avoice217 Member
    178
    22
    Ya I'd definitely say later on down the road I want to do a coolant flush.
  11. avoice217
    avoice217 Member
    178
    22
    Hey all, so I finally got the hose put in. I learned that I didn't tighten up spark plugs 3 & 4 correctly. Honestly, I'm even impressed that I did ANY of them correctly to begin with. However, now I'm getting error codes P0108 along with others. What I am considering doing is taking the car to a local mechanic shop since I'm switching back to being a college student again and don't have as much time to invest in trying to fix issues. I did read a post from someone else back in 2018 who had the same issue. Not sure if its wiring or the sensor itself on my end.
    However, I do have my truck that I can fall back on (even though its a gas guzzling Toyota Tundra), but at least its better than nothing.
  12. Mendel Leisk
    41,824
    is this your one-and-only Prius? If so, maybe fix your avatar. In North America, should be model year 2010~2015:
  13. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    If you get some MAP sensor cleaner and spray it well, it might take care of that issue.
    But check the wiring....
  14. avoice217
    avoice217 Member
    178
    22
    Hey all sorry for the delay in responding. So I recently found out that my 12 v battery was dead (was only reading 11.4 v). So I replaced that and now I am currently getting the following error codes: p0031, p0108, p0121, p0123, p2135 & u0100
