Why changing engine coolant more often than factory recommendation matters
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Mar 1, 2026 at 10:27 PM.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,497
    2,482
    Taylors, SC
    Degraded coolant may be the cause of premature head gasket failure.
    The head gasket is made of laminated steel with elastomers.
  2. rjparker
    10,415
    6,521
    Agree. Which is why I have done ten coolant changes over the years.
  3. ETC(SS)
    7,320
    Then why aren't more cars affected by them?
    Corollas especially used the same 2ZR-based engine and there were twice as many of them sold, AND their head gasket failure rates are not even close to those of the 'turd-gen' Priuses. ;)
    Same head gasket.
    Same coolant.
    Same maintenance periodicities.
    I completely agree with the FACT that Toyota's "lifetime" fluid change periodicities are only meant to last the 'lifetime' of their OEM warranty period.
    It's also true that their coolant will break down over time and can damage gasket material.
  4. rjparker
    10,415
    6,521
    Thermal cycling of the Prius
  5. Kenny94945
    Kenny94945 Active Member
    856
    433
    Sausalito
    2016 Prius v wagon
    "I completely agree with the FACT that Toyota's "lifetime" fluid change periodicities are only meant to last the 'lifetime' of their OEM warranty period. It's also true that their coolant will break down over time and can damage gasket material."
    There is truth, evidence, and some common sense in that comment :)
    Green coolant used to be flush every 3 years. Red (Dexcool) 5 years - as I recall.
    FWIW I would be inclined to 5 years flushes on Priuses.
    PS I advocate distilled water instead of potable/ drinkable water to mix the coolant.
