I originaly bought junk yard assemblies but still had problems with lights intermittenly working. I use to need to turn the switch multiple times for them to come on. Often only one would work. After bypassing the ballast and going leds no more problems. I also dropped $250 on dna smoked healight assemblies from walmart online. I have a greenbean battery that is a year old. Both front fenders are wrecked and i havent found replacements at my local junkyard. My paint is oxidating. I changed the plugs and cleaned the intake and maf. One of the old spark plugs was covered in oil. My mpg jumped tp 45 after that. My mfd is trash. Sprayed primer on the top. My hatch is leaking. I sprayed the heck out of it with gorilla spray silicon. It still leaks but less. Check the back corners for water under the cubbies. I changed the trans oil. I had youtube videos on everything even the headlights but deleted them. I also pulled rims and tires of a prius in the junkyard and changed them because my tires were trash. I also paid 3k for car. Its saving me gas compared to my caravan but hopefully can be a daily driver for at least a few years to get my money back out of it. Overall its been a great car but ive only had it 3 months.
--------- Wow, whatever the opposite of TLC is, it sounds like the $3k car you bought had been living under those conditions. Reliability is just around the corner! Interesting about the oily spark plug and the improved mileage. Did you have any indications of a bad plug? Mine only has about 150k on it but I am the original owner. I think it might have the original plugs because I used to take it to the dealer when it was under warranty and can't remember if plugs were ever changed. My mileage runs about 41 to 46 depending on how often I reset it.
My car has 142k. I changed plugs to do it. It wasnt hard. The old plugs werent failing. The hids were failing. It came with the greenbean battery and the date of installation was on battery lable. The car had bad tires so i pulled wheels and tires from a junkyard prius $250 and swapped them. $250 for the new lights Other than that it still has wrecked fenders faded paint and very dim mfd. So i plan to do the oil, pcv valve and tran oil again at 145 and wash the engine bay with degreaser. Prob bout 4k in thus far.
did you replace the whole battery or you went to the modules one by one? I have to run these battery process 4 days lesser because they changed the roof of my house before I got back to it. It seems like this is almost done with 5 more cells to go. I was gonna ask you most of these old battery packs I just charge them like 4 to 5 times and they can go on full capacity of the 5000/7500. a few of them I have to go like 15 cycles. But I dont go straight. I alternate to different batteries that has physical distances. That's why some of them they got up to that number. How many charging cycle would you consider a battery as weak so I could replace them with a new one. So far I found 1 dead cell and 2 that I have to got over 12 charging cycles? I'm thinking about replacing the weak ones too. I think its important to condition and balance the whole battery so that you would have an idea how strong your hybrid batteries are. I wanna do it right since I went to this far. I'm pretty lucky I have a backup car to do this and I think its worth it because this prius gave me a 75,000 mile of trouble free and gas saving car. If I can get another 75,000, that will be great too! Thanks, C
I see that you have a method figured out and it seems to be working. I thought I had a method figured out but it never quite worked like I was hoping. I have an Autel MX808 analyzer and it was able to identify which individual modules appeared to be bad, and there were 2 bad ones. I was able to more or less verify the bad modules just by checking with a voltmeter and comparing readings. I bought 2 used modules and installed them in the battery pack, after removing the whole pack from the car. They are NiMH batteries so I tried to condition them by charging and discharging a few times. Nothing scientific, just a seat of the pants effort. Everything appeared to be ok so I installed the battery pack back into the car. Long story short, it was fine for a few days (I think) but then the triange of death appeared again. By that time I was running out of patience and just called by local toyota dealer and they gave me a fair price on a brand new replacement battery pack. I just bought that and installed it and everything has been fine since then. I did have an issue with a couple of the high density signal connectors that plugged into the battery pack, but after just making sure all the individual pins were seated correctly, the remaining error codes went away. Good luck on the project and I hope your persistence pays off. I actually still have 2 of the modules but I don't know if they are good ones or not. I don't need them if you think they might be of any use to you just PM me. I also have a used replacement computer module ( I would have to look at it to see which one it is) if that might just be something you want to keep on hand. Lloyd
in your case and since you have a new battery which is great! Just change all the buss bars and the wirings so you can close your eyes in the next additional 180,000 miles. I dont know much about hybrid batteries but I fly RC battery powered planes for a very long time. Its not Nimh but its a LiPo which is more critical in load and unload charging capacity. They heat up and will balloon very fast if the charging and discharging method is not correct. And I have load testers that can check the life cells. But on a prius its a module which is combined with 6 cells if that's correct. Normally those LiPo batteries only last like 3 seasons. I have batteries that are over 10 years now and can still climb a 90 degree thrust. If you run even the strongest battery to a wire that has a low continuity, it will drop the amperage and increase the voltage that will utterly eat your battery cell life without knowing and will die abnormally. The buss bars and the wirings can be those in your case. You can always replace those without pulling the battery out. I'd ask some of these guys in Prius Chat since some of them has experience enough with dealing with these and pointing you out to a quality buss bars and harness.
A factory new battery comes with all that on the battery side of the Battery ECU and the relays, However, you need to reuse all the stuff from your old battery that connect to those three main connections.
Does any aftermarket battery module have a replacement in the "Same or Better Category?" I'm talking about American Standard category not El-Cheapo. Thanks!
Wow, the preavious owner got the green bean battery done. Assuming they had greenbean install it they did not do a great job. I noticed there are many bolts missing so it wasnt reassembled correctly and with bolts missing I doubt they cleaned the fan. However thank goodness no issues with it thus far but its only was replaced a little over a year ago.
