Engine Code P261B Water Pump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jon Batchelor, Mar 3, 2026.
  1. Jon Batchelor
    Jon Batchelor Junior Member
    17
    FL
    Had this error code come up today from a check engine light. Dealership says they are trimming all the fat they can, and want to charge me $500 parts, $500 labor for it. I trust my dealership, but I just flat out cannot afford that.
    From all I can read, the water pump in question is the smaller, less expensive silver/gray one for the engine, not the one for the inverter? Luckily, after watching videos regarding each, also seems to be the one that is easier to reach of the two.
    I can get an Aisin PWT-190 (the one who manufactures them for Toyota) for less than $150, and have a friend who could install it. (While he hasn't worked on hybrids, he's done plenty of things like timing belts and non-hybrid water pumps in the past, and like I said, this one looks much easier to access and replace than the inverter pump.)
    Was even considering just trying to replace the impeller, but it doesn't look like those are sold by higher level companies (Toyota, Aisin), and the low end ones are rumored to only last a short time, so probably better to replace the whole thing.
    Thoughts on this? Anyone? Anything I'm not yet taking into account?
    52,472
  3. Brian1954
    Brian1954 Senior Member
    2,473
    990
    South Central PA, USA
    Code P261B is for the engine water pump. The water pump is not rotating fast enough. Get it replaced ASAP because the engine will overheat and possibly cause a problem with the head gasket. Overheating will occur when going uphills or traveling on a highway (60 mph and higher).
  4. Mendel Leisk
    41,998
    I'd go with the Aisin (WPT-190), from a reputable source. Plan to do that proactively (plus the thermostat), IF we ever make it to 100k miles. Most likely in conjunction with an engine coolant change.
    What's the miles on your btw
    ? They have a tendency to fail around 125~150k miles.
    @NutzAboutBolts video #29 here is a good one.
    Being in Canada, I'll likely go with this source, $151.51 CDN, all-in, on my doorstep ($110.60 USD)
  5. Jon Batchelor
    17
    FL
    320k miles. There was a reason I wanted to stay with Toyota/Aisin. These cars are incredible.
    This is what I am looking at, from the Aisin store on amazon. Perhaps I should suggest the thermostat at the same time, just because of the high mileage and being there anyway.
    [edit]Seems it's not showing the amazon link, but it's Aisin WPT-190 from the Aisin store for 138.17.[/edit]
    #5 Jon Batchelor, Mar 4, 2026
  6. PriusCamper
    PriusCamper Senior Member
    13,162
    5,323
    Pacific Northwest, USA
    It's a super easy job, there's plenty of youtube videos on how to do it and Aisin aftermarket pumps are way cheaper and not any different than OEM. If you lived near me It'd be about $200ish total including cost of part.
  7. Jon Batchelor
    17
    FL
    And yet the person who was lined up to do it called off, saying he didn't have the proper tools, and something about snapping the drive shaft if you didn't do things just right.
    Looking at the video, it didn't look that difficult to me. Sigh.
  8. Jon Batchelor
    17
    FL
    Unfortunately, it would be quite difficult to get further away ;)
  9. BiomedO1
    4,295
    2,256
    Left Coast
    I would replace the entire assembly; because I don't like doing the same job twice.
    I would also install some sort of ECT monitor, because the dummy lamp doesn't light up until your pass 248+F when nominal should be 185-205F. Your lucky to get that P261B, some people just pop their head gasket before figuring that out or run out of coolant.
    Good Luck.....
    Brian1954 likes this.
  10. Jon Batchelor
    17
    FL
    Besides, after 320k miles, why risk anything else going wrong by just replacing one part of it? Going for the whole thing.
    BiomedO1 likes this.
  11. ASRDogman
    ASRDogman Senior Member
    7,878
    4,011
    $500 for the water pump is high, labor seems a bit high also.
    It's a pretty simple job. Just fill the system very slowly, and a cup or two at a time.
    Doing so allows the coolant to push out the air, and not get trapped.
    Don't get it from ebay or amazon, likely a cheap chinese copy. Try an auto parts store.
    I replaced the impeller in mine at 266710 miles, 4 years ago. I have 384,6xx miles.
    Right at 122,000 miles ago. No issues.
  12. Jon Batchelor
    17
    FL
    Is the Aisin store on amazon not actually Aisin?
  13. PriusCamper
    13,162
    5,323
    Yep...
  14. ASRDogman
    7,878
    4,011
    No one knows for sure. But for certainty, amazon has a LOT of cheap chinese copies.....
    Why risk it. How often do you plan on replacing the coolant pump? Every 11 years?
  15. ChapmanF
    18,658
    There might be people who do know for sure. My only problem is I don't know for sure who they are.
  16. Jon Batchelor
    17
    FL
    Well, at this point, I'm considering making sure the product is sent directly to me, to check it for signs (proper packaging, gasket present, but not already in place, hopefully signs of Toyota scraped off), or biting the bullet, letting a friend pay the $1000, letting the dealership do it, and hoping I can eventually manage to fully pay them back.
    I hate scammers.
  17. ASRDogman
    7,878
    4,011
    Just have your friend watch a few youtube videos. It's not different than a non hybrid.
    With a minor exception. Remove the service switch on the hybrid battery. And make sure
    he reinstalls it correctly.
    You can find a Toyota coolant pump for less than $500 from other Toyota dealerships online.
    You may even get a 10% military discount.
    And get the TOYOTA 50/50 coolant! 2 gallons. Do not get substitutes.
  18. Jon Batchelor
    17
    FL
    Trying to find the proper thing I want on Toyota web sites is very complicated. That said, unless there's a lot of other things I need that I don't know about, I can get the proper water pump assembly from a local Toyota for $265, which is certainly better than $500. But I don't know if that is all I need, or if I also need this and that and the other.
    Anyone know with a fair amount of certainty if the water pump assembly is the totality of what I need for the pump? (ie not fluid or thermostat.) It is listed as the part number I was expecting.
  19. PriusCamper
    13,162
    5,323
    I'm seeing OEM on Ebay for $150 and a huge selection of aftermarket ones for less than $60. If I were doing it I'd study all the specs of the cheapers ones and buy the apparent highest quality build $60 version. That's mostly because the replacing of this pump is so easy and takes less than an hour and it saves me money in the short run and not much hassle in the long run.
  20. Mendel Leisk
    41,998
    Work around is to copy the Amazon link, then select a text string, like this:
    then select this tool:
    and paste in the Amazon link.
    You can subsequently make the (still selected) text “bold” which makes it more obvious it’s a link, otherwise it’s just a subtle pale-blue tint. Finished product:
    Amazon link
    See post #4? In a nutshell: water pump, thermostat, and a gallon of Toyota Super Long Life Coolant. To source the pump and thermostat Amayama’s reputable, and cheaper all-in than anything else mentioned so far.
    if a regular coolant change is not timely (schedule is every 5 years or 50k miles, whichever comes first), you could probably just clamp off hoses and top up after.
    #20 Mendel Leisk, Mar 5, 2026
    PriusCamper likes this.
