Attention Prius Owners, I believe I have discovered a previously unknown Mechanism of Low MPG.
Discussion in 'Gen 2 Prius Main Forum' started by TheLastMojojomo, Nov 2, 2021.
  1. dreybay
    dreybay Junior Member
    cali
    Two Eco
    well it seems the system relearned my driving habits after around 2.5k miles...so happy my car is back to normal but afraid of next time.
    dex3703 likes this.
  2. dolj
    dolj Senior Member
    8,536
    4,333
    Wellington, New Zealand
    I the great scheme of things, you are talking about a drop in the ocean.
  3. dex3703
    dex3703 Member
    65
    31
    Seattle
    I had my HV battery replaced a few weeks ago, and my mileage has seen a significant decrease. Reading this long thread to figure out what I can do about it.
  4. dex3703
    dex3703 Member
    65
    31
    Seattle
    To update this, my mileage finally returning to normal after several long trips. Power, performance and battery use returning to previous baseline. Got 51mpg on a recent trip, after being in the low 40s right after battery replacement. Still tends to baby the battery, but it's so much better than it was.
    Brian1954 likes this.
  5. Fitch
    Fitch New Member
    Tuesday
    Big Spring, TX
    I've been following this thread because 100% my 2008 Prius (67,000miles) is stuck in the Weak EV state after I replaced my hybrid battery with a new OEM toyota battery and the 12v was disconnected, I can tell a dramatic difference in the way the EV performs after this. I can very very slightly use the electric only state where previously it was pretty aggressive. I can creeeeeep up to about 12-20mph and the motor will fire up and i'll watch the MPG instantly drop from the 99 to like 25. It's very frustrating and I hope that we can find a solution to this. If there is anything at all I can do I'm 100% willing to do it.
    Thank you so much Mojo for doing all this work and putting all this together. I was pulling my hair out about this trying to figure it out before I came across this post.
  6. Tombukt2
    13,318
    2,399
    What are y'all mail people or something,? I've never noticed my car driving under all the electric conditions ever backing up . Pulling out driveway till wheels hit blacktop. Never anywhere else I've got brand new battery in all. Prius here. I can gosilbox to mail box on elec carefully . That's about it . I've never had the cars newer where this was much different now I've other brand hybrids . That can but they're series systems .
  7. rjparker
    10,422
    6,525
    This behavior is normal for a gen2, gen3 and most non-lithium gen4s.
    Instantaneous mpg is a worthless metric. Average mpg over many tank fulls is more accurate but not perfect as it usually over estimates by a couple mpg. If you see average mpg drop and not recover in a week or two, then the hv battery may be getting weak, but this takes 8 years or more with a Toyota OEM hv battery replacement. Sometimes 15-20 years.
    More recent Toyota hybrids can do slightly better particularly on top speed in ev mode. Range is still a little over a mile with a feather foot.
    Obviously recent plug in hybrids are totally different - much more power, dramatically better mpg-e and all speed ev operation within their 40-50 mile battery range.
    So the best answer is to get a recent plug in. A Rav4 Prime/Plugin has over 300 hp, over 100 mpg-e and is the fastest accelerating Toyota. Apparently the improved 2026 model will start at $41k. If you really want extended ev and performance and are "100% willing to do it" .
  8. Tombukt2
    13,318
    2,399
    Cheap Chevy volt 1st Gen dirt cheap . Can find em good to . Ours go 90 mph for 40.miles almost forever generator comes on . They're kinda cool n cheap because folks scared . DY got everybody scared of electrics or at least his folks are scared they selling them off like hot cakes . Saw a volt running for 1350 the other day pretty clean to .
  9. dolj
    dolj Senior Member
    8,536
    4,333
    Read this article: 5 modes of Prius Operation. (which is linked in my signature) and see if it fits your driving scenario. Using the instantaneous MPG is not at all a suitable way to gauge your consumption. Look at the average MPG on the bottom of the Consumption screen after doing > 500 miles.
    As a summary, it takes about 15–25 minutes of driving to reach stage 4. Stage 4 give the greatest fuel economy.
    If you have a driving scenario like the OP (postal worker) the hard acceleration/hard braking with no meaningful cruise will kill MPG—Period.
