Attention Prius Owners, I believe I have discovered a previously unknown Mechanism of Low MPG.
Discussion in 'Gen 2 Prius Main Forum' started by TheLastMojojomo, Nov 2, 2021.
  1. dreybay
    dreybay Junior Member
    cali
    Two Eco
    well it seems the system relearned my driving habits after around 2.5k miles...so happy my car is back to normal but afraid of next time.
    dex3703 likes this.
  2. dolj
    dolj Senior Member
    8,606
    4,367
    Wellington, New Zealand
    I the great scheme of things, you are talking about a drop in the ocean.
  3. dex3703
    dex3703 Member
    65
    31
    Seattle
    I had my HV battery replaced a few weeks ago, and my mileage has seen a significant decrease. Reading this long thread to figure out what I can do about it.
  4. dex3703
    dex3703 Member
    65
    31
    Seattle
    To update this, my mileage finally returning to normal after several long trips. Power, performance and battery use returning to previous baseline. Got 51mpg on a recent trip, after being in the low 40s right after battery replacement. Still tends to baby the battery, but it's so much better than it was.
    Brian1954 likes this.
  5. Fitch
    Fitch New Member
    Big Spring, TX
    I've been following this thread because 100% my 2008 Prius (67,000miles) is stuck in the Weak EV state after I replaced my hybrid battery with a new OEM toyota battery and the 12v was disconnected, I can tell a dramatic difference in the way the EV performs after this. I can very very slightly use the electric only state where previously it was pretty aggressive. I can creeeeeep up to about 12-20mph and the motor will fire up and i'll watch the MPG instantly drop from the 99 to like 25. It's very frustrating and I hope that we can find a solution to this. If there is anything at all I can do I'm 100% willing to do it.
    Thank you so much Mojo for doing all this work and putting all this together. I was pulling my hair out about this trying to figure it out before I came across this post.
  6. Tombukt2
    Tombukt2 Senior Member
    13,597
    2,457
    Durham NC
    What are y'all mail people or something,? I've never noticed my car driving under all the electric conditions ever backing up . Pulling out driveway till wheels hit blacktop. Never anywhere else I've got brand new battery in all. Prius here. I can gosilbox to mail box on elec carefully . That's about it . I've never had the cars newer where this was much different now I've other brand hybrids . That can but they're series systems .
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,675
    6,706
    Texas Hill Country
    This behavior is normal for a gen2, gen3 and most non-lithium gen4s.
    Instantaneous mpg is a worthless metric. Average mpg over many tank fulls is more accurate but not perfect as it usually over estimates by a couple mpg. If you see average mpg drop and not recover in a week or two, then the hv battery may be getting weak, but this takes 8 years or more with a Toyota OEM hv battery replacement. Sometimes 15-20 years.
    More recent Toyota hybrids can do slightly better particularly on top speed in ev mode. Range is still a little over a mile with a feather foot.
    Obviously recent plug in hybrids are totally different - much more power, dramatically better mpg-e and all speed ev operation within their 40-50 mile battery range.
    So the best answer is to get a recent plug in. A Rav4 Prime/Plugin has over 300 hp, over 100 mpg-e and is the fastest accelerating Toyota. Apparently the improved 2026 model will start at $41k. If you really want extended ev and performance and are "100% willing to do it" .
    Paul Gregory likes this.
  8. Tombukt2
    13,597
    2,457
    Durham NC
    Cheap Chevy volt 1st Gen dirt cheap . Can find em good to . Ours go 90 mph for 40.miles almost forever generator comes on . They're kinda cool n cheap because folks scared . DY got everybody scared of electrics or at least his folks are scared they selling them off like hot cakes . Saw a volt running for 1350 the other day pretty clean to .
  9. dolj
    dolj Senior Member
    8,606
    4,367
    Read this article: 5 modes of Prius Operation. (which is linked in my signature) and see if it fits your driving scenario. Using the instantaneous MPG is not at all a suitable way to gauge your consumption. Look at the average MPG on the bottom of the Consumption screen after doing > 500 miles.
    As a summary, it takes about 15–25 minutes of driving to reach stage 4. Stage 4 give the greatest fuel economy.
    If you have a driving scenario like the OP (postal worker) the hard acceleration/hard braking with no meaningful cruise will kill MPG—Period.
  10. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Sorry, Fitch, that's the problem with this topic - you get reflex responses from people who haven't actually understood the fundamental behaviour change here, and make statements like "it's normal to not run on electric all the time". Well, duh, yes, thanks for that contribution.
    I think people just like assuming other people are stupid and asking a stupid question, and then once they've assumed that, they focus on the bits they want to answer, and ignore the bits they don't have an answer to. (And indeed, almost the whole thread.)
    In this case, "a dramatic difference in the way the EV performs after this".
    What's going on, and that there is a issue hitting some people, is crystal clear in the videos and graphs the OP posted back in the thread (see page 6 for the video).
    The "limp" behaviour of the Prius where it avoids using the battery is well known, and that seems to be what's happening here - cars getting stuck in the limp state or something close to it, apparently due to a failure to recalibrate something after losing some state when the 12V was disconnected.
    @Fitch - it does seem there's still no definite "cure" here. Some have suggested replacing the 12V battery with a new one, but I've seen no reports of that working. Otherwise, wait and hope seems to be the best bet at the minute. Eventually a car get what it's looking for in the recalibration, even taking a couple of thousand miles.
    How long has yours been in the "weak" state?
  11. Fitch
    Fitch New Member
    Big Spring, TX
    A week or so. I'm pretty familiar with my car and the feel of it. I get that the readout isn't the best but what I'm trying to say is it feels like when the ICE kicks on to pick up the slack during what I would classify as basic (non-aggressive) acceleration which was previously largely assisted by the EV side, it fee's like the EV side just falls flat on it's face, which is clearly illustrated in Mojo's videos. How can anyone be in denial about this with such concrete evidence? Especially after his EV button install that CLEARLY restored (mostly) the electric locomotion we're talking about having been lost after 12v disco? I knew before seeing this video and seeking out others that may be experiencing this problem that something like this was going on, my car felt THAT different and in town MPG took a pretty big hit. My driving habits didn't change, the car did.
    I'm going to put on my tinfoil hat and question if perhaps there are shills for toyota in this thread trying to trivialize what is a obviously a pretty serious and maybe not all that uncommon an issue.
  12. VelvetFoot
    VelvetFoot Senior Member
    1,331
    519
    New York State
    2026 Prius
    I wonder if can be related to how long the 12v battery was disconnected?
    As in, how long has that capacitor thingy been in existence? :)
  13. Paul Gregory
    Paul Gregory Senior Member
    2,263
    603
    Alberta
    2024 Prius Prime
    XSE
    The generator-driven electric motor design will always be far less efficient than the Prius hybrid drive. The Prius eliminates several inefficiency bottlenecks by coupling the drive motors directly to the wheels.
    That is why fuel economy numbers that rival that of the Prius are bogus.
  14. dolj
    dolj Senior Member
    8,606
    4,367
    I know exactly what you are talking about here, I have experienced it, and you sure do know when this is happening. I didn't do anything to my car, except made sure I was always in Stage 4 in the warm-up cycle. Eventually the car just was back to normal. As I was reading along with this thread when the thread was much younger, I remember thinking that what the OP was saying and demonstrating was like the car was stuck in Stage 2 or 3a—I can't remember which—so that is why I point people the 5 stages of hybrid warm-up. I'm just an owner trying help another owner.
    VelvetFoot likes this.
  15. Fitch
    Fitch New Member
    Big Spring, TX
    I think I get what you're saying. Are you suggesting that during this relearning process or whatever you want to call it, you feel like making sure you get to stage 4 frequently is very important?
  16. dolj
    dolj Senior Member
    8,606
    4,367
    I couldn't really say for certain. But if fuel economy is your goal then getting into stage 4 as soon as it is ready to click over, every time, is the goal. Given I did not do anything to the car, I conclude there was nothing wrong with the car, per se.
    I can tell with a reasonably high level of confidence that driving style is a factor in the car setting itself up for best economy. I do not use any unusual hypermiling techniques, except pulse & glide, and I do not do anything that annoys other road users. I just use all the old school economy techniques like long slow stopping for traffic lights, maximizing re-gen on downhills (i. e., not using 'B'**, just pressing the brake pedal enough to control speed to increase regen.), allow a good following distance on the freeway of 4 to 6 second spacing, etc. More is better. I have been practicing P&G for so long, it is second nature now and very easy for me. I even catch myself doing it in non-hybrids.
    I can tell you with a high level of confidence, that with the driving scenario of a postal delivery driver, it will be impossible to have good fuel economy. Whether that contributes to being stuck in this mode, I am less confident. I am a sample of one and it only happened once in my personal car a long time ago. I experienced it a second time when I drove an acquaintance's car to try and show him how to pulse and glide. His car was behaving this way and It was very hard to demonstrate that technique.
    ** There are no descents long enough in my locale to warrant using 'B' which is the major factor in not using 'B'
    #176 dolj, Mar 8, 2026
  17. chornd
    chornd New Member
    Manitoba
    I'm working on this issue with my car. My current theory is that the car is confused about the battery's SOC. For my car it exits recirculation mode and starts trying to charge the battery when SOC drops to 57%. Which means most of the SOC on the display is unusable. I still have full EV behavior that can gently accelerate the car from a stop to 60 kph without the engine turning on, but I can only access it by force charging the car to 65%+ SOC. According to dr prius, my traction battery is in excellent condition but its voltage is too low for what the car is reporting.
    So I suspect the battery is stuck in this state where the car thinks it's weak and needs to be babysat at high SOC, when in reality the car is confused and the battery is actually very low SOC. The behavior where it won't let me use the full authorized battery discharge rate seems like it's because the car sees voltage droop and freaks out, which is understandable if the battery is secretly at 40% SOC but the car just doesn't realize it.
    I'm waiting to try fixing this when it warms up outside, since the engine needing to constantly kick on to heat itself back up every 30 seconds would ruin the science-ness of me trying to reset the messed up behavior.
    For both mojo and the guy with a properly working car, I'd like to know what SOC threshold your vehicle is treating as the "critically low" point where it decides the battery needs to be charged and switches to normal mode. Just in case you're unaware, you can check with hybrid assistant: Get the car into a situation where you're cruising with the dingle ball in the dingle hole on the app. Normal mode is easily identified because the engine is running at 1900+ rpm and feeding ~4 kw to the battery. Compared to recirculation mode where it's more like 1200 rpm and constantly fluctuating between using and feeding the battery at very low kw.
    #177 chornd, Mar 27, 2026
