Front Brake Dusk Shield
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lindylex, Mar 2, 2026.
  1. lindylex
    lindylex Junior Member
    Earth
    Anyone know where I can source both front brake dusk shields for a 2010 Prius?
    Thanks in advance.
  2. lindylex
    Earth
    Never mind, I think I found them.
    Splash Shield - Toyota (47781-47030)
    Splash Shield - Toyota (47782-47020)
  3. Tombukt2
    13,545
    2,440
    Yeah I throw a bunch of them away it seems like every few months to 2 years
  4. Mendel Leisk
    41,997
    I always like to comparison shop. On my doorstep, all-in (so far they've never charged more, say sales tax, duty, whatever) from Japan through Amayama, $47.70 CDN:
    (One of their warehouses is in United Arab Emirates, which might be dicey right now...)
    And cash-n-carry, the discounted price from nearest-to-me US dealership, sourced through Toyota USA parts site, $57.45 USD:
    #4 Mendel Leisk, Mar 3, 2026
  5. lindylex
    Earth
    Things are so bad on this car that currently there is none. The drives side is completely rusted away and the passenger side has seen better times. If I can I will try to get a photo.
  6. lindylex
    Earth
    I looked at this website as a source for these parts. Thanks for your insights on sourcing. I found them on the following website toyotaofnashua for $26 USD as of March/2026.
  7. Tombukt2
    13,545
    2,440
    You just do your hubs and throw them out put calipers and stuff together and go . I've had cars like this for 40 years no brake dust shields on disc brakes . Very uneventful it's just the way it is and it's fine air flow thru wheels is great too. Looks better too .
  8. Mendel Leisk
    41,997
    Yeah, $26.28 USD apiece, before shipping and taxes. For the two, that's 52.86. With shipping and taxes, another $15?
    From Amayama, those would land on my doorstep, everything paid, for $47.70 CDN, with exchange rate of .73, that's $34.82 USD. Delivered, for the pair, all-in.
    I am biased, admittedly: being in Canada, I've found it easier to ship stuff from Japan than US.
    Tombukt2 likes this.
  9. Cornvalue
    Cornvalue New Member
    24
    Internet
    Business Ed. Plus
    I want a dawn shield.
    A dust shield is a great idea. But lacks benefit.
    But I have multiple cars lacking this. Just check back of rotors for lack of rust, it’s easier without that stupid shield that often create noise due to contact with rotor.
    It’s not called for.
    CR94 likes this.
  10. Tombukt2
    13,545
    2,440
    More than a dust shield that's a rock and debris shield to keep small rock and particulate matter smacking into rotor at speeds . Not that this is that serious we don't all live on rock roads etc . But yes it's easier to see the back of the rotor laying under car without it. I haven't run them on cars since the mid 80 no issues yet
    Cornvalue likes this.
  11. lindylex
    Earth
    To understand the damage of not having a brake dusk shield one must look at the issue longitudinally and the right conditions. Particles over time will expedited the erosion of brake pads and rotors. These parts not extra they are meant for a purpose.
    Why would they cause noise concerns? If they are not bent and rubbing against the rotor there should not be any noise issue. If they are bent one should unbend them and check to see if there is any damage from something getting caught between them and the rotor or possibility of a non elastic impact(s).
    #11 lindylex, Mar 4, 2026
  12. Tombukt2
    13,545
    2,440
    That particulate matter and all that mess you're talking takes a long time to happen I've got a 25-year-old Corolla sitting right here with the brakes done exactly like this cross drill slotted dimpled rotors they still not rusted look like almost new the surfaces are baby butt smoove. Running pure silicone for fluid it's purple. Crack open any one of the Caliper not a speck of rust or corrosion on the pistons or notes almost 26 years untouched
  13. ASRDogman
    ASRDogman Senior Member
    7,878
    4,011
    mmmm Why doesn't that happen on motor cycles then?
  14. Mendel Leisk
    41,997
    Editorially curious: are you using a translation function, or AI?
    As has been mentioned, it’s a dust shield, for “dust” particles.
    It’s always helpful to disclose your location, at least country, especially when you’re looking to buy parts. Saying you’re on “earth” is a little too vague?
    #14 Mendel Leisk, Mar 6, 2026
  15. Cornvalue
    24
    Internet
    Business Ed. Plus
    This whole site seem like AI soon.
    Dust shield cause noise due to gravel getting stuck between the shield and the rotor.
  16. Tombukt2
    13,545
    2,440
    Yep I've got tons of Big bore scooters and an MP3 no problemwith brakes ever and lotsa bikes use silicone fluid in brakes too .
  17. Mendel Leisk
    41,997
    Google’s AI says they’re important, searching:
    are brake dust shields necessary
    big hurdle: replacement typically requires removal of wheel bearing, which can be a handful. Doubly so if your earthly location uses road salt.
  18. lindylex
    Earth
    This is how I write. English is my first language. For some, the way I write might seem pedantic. It is a curse or blessing from reading much.
    Your tip with needing to remove the wheel bearing was perfect. That I did not forecast. The car I am going to work on is very rusty and should make for a fun time.
  19. lindylex
    Earth
    All done and the first time around I tried to save the front wheel hub. I was successful but it took to long. I used a combination of heat, air hammer and final resort partial hub removal tool. The second time around with the same vehicle different weekend I continued this job. Instead of fighting I replaced both front wheel hubs and with the hub removal tool it took 5 hits and under 3 minutes to setup the tool and remove a wheel hub verses 90 minutes of being kind to the first hub trying to not remove it.
    Attached are before and after photos. I coat the brake backing plates with high temperature grease to create a barrier that protects the metal from the corrosive effect of salting the streets.
  20. ChapmanF
    18,658
    The idea of that much grease that close to some brakes makes me anxious.
