P0A40 Error.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by anels42, Feb 13, 2025.
  1. anels42
    anels42 New Member
    Kalamazoo, Michigan
    Hello,
    Got my 2007 Prius just over a year ago. It has 225,000 miles on it, It's been driving fine, but I drove through a snowstorm yesterday, and when I got home I turned the car off. When I turned it back on, my check engine light turned on. My dad took it for a drive around our block, but when he got back, the car stopped at the end of our driveway. We have not been able to get the car to move since, except at one point last night, but we can't get it back to that point. When we coded the car, we got error code P0A40. We thought maybe it could be a battery issue, and when we took the battery out and brought it to an auto parts store, they said the battery was pretty much shot, so we bought a new one. No dice. Any ideas? We know it could be a transaxle issue, but we're hoping for a simple solution so that we may not have to have it towed to a dealer.
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    There are problems in the car and it is necessary to understand what these problems are. The most important thing is to diagnose correctly. Tell us how or with what scanner you installed the P0A40 code.
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a3f243.pdf
    This is a hybrid system error, as a rule, a red triangle appears on the instrument panel and a red car with an exclamation mark on the MFD. You say that a check appeared on the instrument panel.
    But no errors were found for the engine.
    And there is no need to make sudden movements to empty your wallet.
    Batteries are expensive now, but the reason may be completely different.
  3. bisco
    52,803
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    Well, that code is for a circuit fault with the (drive)motor position sensor - aka the "resolver". It could be a problem in the transmission, but I would suggest looking over the external wiring first. There could be rodent damage or something.
    Anything from the (6 wire) connector on the trans to the hybrid control ecu in front of the lower glove box could be involved.
    Brian1954 and MAX2 like this.
  5. Perfxctpisces
    Perfxctpisces New Member
    Chicago
    Did you ever get this figured out? Something similar happened to me except it was a rain storm instead of snow
  6. bisco
    52,803
    See post #4
