1. Willie Walker
    Willie Walker Junior Member
    35
    Salisbury md
    Thank you for kindness. As of right now running strong. Ac not working any more so I think the high voltage fuse is bad in the inverter.
  2. Willie Walker
    35
    Salisbury md
    Hello I have 2000 miles on the engine I replaced head gasket still no coolant loss. Do you think I am out of the woods or could it still fail? Thanks
  3. rjparker
    10,819
    6,791
    Good sign. How is your oil consumption on this engine?
  4. Willie Walker
    35
    Salisbury md
    It has been on full mark each time I checked it but this morning it was like 3/8 inch down from full point. In the catch can I do keep getting like that beige mayonnaise consistency stuff. I really would love to at least get 300,000 miles out of it. I’m at 259,000 now. I have a brand new set of tires to go on that I got for like $300 low roll resistance that I usually put on it.
  5. Willie Walker
    35
    Salisbury md
    I correct myself it was a quarter inch down. I had to go back and look at what a quarter inch wants to make sure.
  6. Eddie25
    Eddie25 Active Member
    503
    212
    MI
    Random opinion:
    I wouldn't particularly worry about what's showing up in the catch can, just stay on top of emptying it. Oil and coolant levels are really what you want to be concerned about. Just keep an eye on them.
    As far as oil burning I would just live with it unless it was over a quart every 3k miles. Mine got way worse than that but a quick B12 piston soak I did two years ago completely solved it to this day. I wouldn't believe it myself if it didn't happen to me.
  7. Willie Walker
    35
    Salisbury md
    wow I never heard of a B12 piston soak /I can see it now. Don’t know something like that can make that big of a difference. I’ll give that a shot. Thank you so much for your advice. Will do:)
  8. PriusCamper
    PriusCamper Senior Member
    13,308
    5,379
    Pacific Northwest, USA
    If you aren't losing coolant then you fixed it!
    Willie Walker likes this.
  9. Eddie25
    503
    212
    MI
    Like I said, I wouldn't worry about it until you have confirmed it's bad. Best bet for now is just getting data and waiting.
  10. PriusCamper
    13,308
    5,379
    Agreed... PIston soaks are once you exhaust all the other options because it can cause a small amount of damage to seals, gaskets and other non-metal parts.
  11. Willie Walker
    35
    Salisbury md
    hello I know I’m coming back on a different subject. My AC doesn’t work and I’ve checked the high voltage fuse and it does have continuity. Now I’ve taken the six prong plug off the top of the compressor and the ground number five is correct. But what I’m trying to do is find out which color wire is the ignition wire in order to check that there’s voltage going into it. Do you know the color of the wire wires going into the top of the compressor for a Prius 2012. Thank you
  12. Willie Walker
    35
    Salisbury md
  13. BiomedO1
    4,416
    2,325
    Left Coast
    did you check refrigerant pressures or for leaks? there's a pressure cut-off switch to prevent you from frying the compressor, due to low refrigerant. that's the most common problem with cooling systems.
  14. Willie Walker
    35
    Salisbury md
    No I didn’t check that because basically I swapped the engine out twice. And I got a little bit of coolant in the top of the compressor. I did blow that out at the time. But when I do that trick on the AC system it comes up with a code 71 and 72. I was able to check the volts going through wire six I was able to put a needle in the plug to check it so that is fine.Thank you so much for your reply.
  15. rjparker
    10,819
    6,791
    Your focus should be on the orange hv cable between the inverter and compressor.
  16. Willie Walker
    35
    Salisbury md
  17. Willie Walker
    35
    Salisbury md
    I know when I swap the engine out, I never disconnected the high voltage cable to the compressor. The only one that I disconnected was the low voltage.
  18. Willie Walker
    35
    Salisbury md
    is there a way to clear the 72 code out of the AC system. I saw online if you hold the front and rear defrost that it should clear this. But it didn’t work on my 2012 Prius. Is there another way to clear it? I’ve already disconnected the battery for a long period of time that didn’t do it. One post somebody
  19. ChapmanF
    18,848
      File size:
      3.7 KB
  20. rjparker
    10,819
    6,791
    Techstream or any scanner capable of reading the AIR CONDITIONER ecu (CLIMATE/HEAT in Car Scanner app) can also attempt to reset the code. But if the fault is still there the code will be back very quickly.
