Changing brake fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mhdriver, Mar 2, 2026.
  1. ASRDogman
    ASRDogman Senior Member
    7,808
    3,980
    That is not true. It doesn't leak, unless something is damaged.
    Brake fluid is inside the caliper behind the seal. It doesn't leak past the seal unless the seal
    and/or caliper wall are damaged or cracked.
    The puck moves very little.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,497
    Taylors, SC
    Not true. All rubber seals are wetted with a thin fluid film of lubricant for them to funcas designed. New caliper seals are assembled with a thin film of brake fluid.
    Otherwise, heat will "glue" the lip of the seal to the metal piston.
    It's like coating the rubber seal of the oil filter with a thin film of oil.
    #22 Georgina Rudkus, Mar 7, 2026
  3. mhdriver
    mhdriver Member
    157
    61
    florida
    Well, I ended up doing it like the Carcarenut on YouTube. Drained the reservoir with a syringe. The tubing with the syringe was surprisingly too large in diameter to slide down into the reservoir properly. Ended up finding a straw to slide into the tubing and then down into the reservoir. Got the little hand pump to attach to the bleeding nipples, ran through a few cycles until the fluid coming out was tested good. Did all 4 brakes without difficulty. I disconnected the car battery before I started the whole process. Bought a tester on Amazon.
    All in all, as easy as an oil change.
  4. ChapmanF
    18,536
    Or, when we're following the repair manual, with a bit of lithium-soap-thickened glycol grease.
  5. Mendel Leisk
    41,893
    I gather you didn't put the car in invalid mode? Have a look at brake fluid replacement link in my signature.
    (on a phone turn it landscape to see signatures)
