Changing brake fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mhdriver, Mar 2, 2026.
  1. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    That is not true. It doesn't leak, unless something is damaged.
    Brake fluid is inside the caliper behind the seal. It doesn't leak past the seal unless the seal
    and/or caliper wall are damaged or cracked.
    The puck moves very little.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    Not true. All rubber seals are wetted with a thin fluid film of lubricant for them to funcas designed. New caliper seals are assembled with a thin film of brake fluid.
    Otherwise, heat will "glue" the lip of the seal to the metal piston.
    It's like coating the rubber seal of the oil filter with a thin film of oil.
    #22 Georgina Rudkus, Mar 7, 2026
  3. mhdriver
    mhdriver Member
    162
    61
    florida
    Well, I ended up doing it like the Carcarenut on YouTube. Drained the reservoir with a syringe. The tubing with the syringe was surprisingly too large in diameter to slide down into the reservoir properly. Ended up finding a straw to slide into the tubing and then down into the reservoir. Got the little hand pump to attach to the bleeding nipples, ran through a few cycles until the fluid coming out was tested good. Did all 4 brakes without difficulty. I disconnected the car battery before I started the whole process. Bought a tester on Amazon.
    All in all, as easy as an oil change.
  4. ChapmanF
    19,045
    Or, when we're following the repair manual, with a bit of lithium-soap-thickened glycol grease.
  5. Mendel Leisk
    42,365
    I gather you didn't put the car in invalid mode? Have a look at brake fluid replacement link in my signature.
    (on a phone turn it landscape to see signatures)
  6. mhdriver
    mhdriver Member
    162
    61
    florida
    No, I didn't. The Car Care Nut says to disconnect your battery and do it the way I did it. He says that's how the dealership actually does it. It was easier by far imo. Brakes working great.
  7. ASRDogman
    8,067
    4,089
    How did you bleed the rear brakes? Since they are electric?
  8. ChapmanF
    19,045
    Maybe mhdriver was just doing "fluid replacement" rather than "air bleeding"? You can sort of get away with those folk methods then.
    We have circled back around to this thread's post #2.
  9. Mendel Leisk
    42,365
    You've done the official non-Techstream method as well then, for comparison? Doing that took me about an hour, excluding raising/lower the car, and removing/installing wheels. And it went smooth.
    I'm a little incredulous, that dealerships, having full, legal techstream, would resort to what @ChapmanF calls "folk methods". ;)
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,981
    Texas Hill Country
    Believe it or not, dealer techs find ways to speed up their jobs. Especially since they are paid by the job and not by the hour. For example, a timing chain cover reseal is engine out by the book. It pays way more per hour if they do it in the car. Which means they get more jobs per day and make more money.
    Price a standard maintenance brake bleed versus a replacement brake booster and stroke simulator bleed. Two quite different prices. You get the maintenance bleed every time unless you have done a diy brake booster swap and need help with the "replacement" booster bleed.
    Vacuum bleeding is a one man fluid replacement method. It is not intended to bleed every brake booster internal passage as needed after parts replacement.
    Dealer techs typically use the vacuum method for standard fluid replacement. Most will use a powered vacuum tool for speed and efficiency rather than a hand vacuum pump.
    As noted, you don't want the brake booster pump to operate while attached to a vacuum canister. Some just keep the doors closed while its on the lift, others disconnect the negative battery terminal or they pull the fuse box 12v white cable.
    BiomedO1 and Mendel Leisk like this.
  11. mhdriver
    mhdriver Member
    162
    61
    florida
    Followed this exactly.
  12. Mendel Leisk
    42,365
    N’’mind.
  13. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    Yep; that gets most, but not ALL brake fluid out. If you get air into the system - let the reservoir "run dry"; you'll need a scan tool to push that air out.
  14. Mendel Leisk
    42,365
    The @NutzAboutBolts video is good. My only exceptions, I did the order per repair manual (start with right/front and go around counterclockwise), and no vacuum.
  15. mhdriver
    mhdriver Member
    162
    61
    florida
    I ran two quarts of brake fluid through the whole system. In the end, the fluid I was taking out was as good as what I was putting in. You had absolutely better pay attention to the level in the reservoir. This couldn't have been any easier. I love the Car Care Nut channel.
