Dr Prius Minimum Batt Temp?
Discussion in 'Gen 2 Prius Main Forum' started by speedway dave, Mar 24, 2026 at 2:32 PM.
  1. speedway dave
    speedway dave Junior Member
    Indy
    Dr Prius App Question: Does anybody know what the minimum battery temperature is to be able to run the Full Battery Test? I get errors that the temp is too low (77 degrees) and the test aborts. TIA
