Dr Prius Minimum Batt Temp?
Discussion in 'Gen 2 Prius Main Forum' started by speedway dave, Mar 24, 2026.
  1. speedway dave
    speedway dave Junior Member
    Indy
    Dr Prius App Question: Does anybody know what the minimum battery temperature is to be able to run the Full Battery Test? I get errors that the temp is too low (77 degrees) and the test aborts. TIA
  2. pasadena_commut
    pasadena_commut Senior Member
    3,050
    950
    Southern California
    (I don't know the answer because it is hotter than 77F here during the day at least 3/4 of the year, and the pack is typically at least 90F, even with very little activity.)
    Drive the car around for a while and the battery temperature should get above 100F, then try it again. If it is really cold out close the windows and maybe turn on the heat.
