Replacement options for broken glass for side mirror. Heated?
Discussion in 'Gen 3 Prius Main Forum' started by M123, Mar 27, 2026.
  1. M123
    M123 Junior Member
    New York State
    The passenger side mirror on my 2013 Prius 2 is cracked. I'm thinking through options for replacement.
    First, any way to tell for sure if it's heated? I assume it is, based on the model and year, but not 100% sure. I tried turning on the rear defrost to see if it heated up, but to the touch I can't tell.
    Option 1: Buy a Burco glass replacement, not heated, and attach it to the current broken mirror.
    Option 2: Buy a Bruco heated replacement, break the broken glass out of there, and install.
    Option 3: Buy a complete replacement mirror, take the door panel apart, and install.
    Thoughts?
  2. ChapmanF
    18,666
    Option 4: Buy the replacement mirror glass from Toyota, pop out the old broken one, pop in the new one, move on to next project. (y)
    Full disclosure: I've never had to do this on gen 3. You can read this post about how it worked in gen 1. I'm pretty confident it's very similar for gen 3.
    That linked post was in a thread where someone needed to replace the mirror's color cover, which it doesn't sound like you need, so you can disregard the extra words about that.
  3. Tombukt2
    13,547
    2,440
    Aren't all the Gen 3s heated by default I thought. And heater pad are part of glass or glued on so we'll . All the Gen 3s I've seen are heated and have two pins on the back to connect to the electric system
  4. ChapmanF
    18,666
    Yes, when you buy the right glass part number at a Toyota dealer, you'll end up getting the right glass. When it's heated, there will be an electrical connector on it.
  5. Tombukt2
    13,547
    2,440
    Well you can go to the wrong place and buy the mirror both heated and unheated I thought it was all of em . The place I go to has them both and I think you can get both of the plates online fairly inexpensively
  6. PriusCamper
    PriusCamper Senior Member
    13,166
    5,323
    Pacific Northwest, USA
    Replacement side rear mirrors assemblies for Toyota are super cheap online, like only $30... Or go to a wrecker and it's like three easy bolts to remove the whole assembly and probably cost $40. The plastic cover on the back of the mirror that's usually same color as your car just pops off and you can put it on the new one.
  7. M123
    M123 Junior Member
    New York State
  8. ChapmanF
    18,666
    I've bought online glass plates before that really were just the glass plate.
    When you buy it from Toyota, it's the glass plate mounted in the thin plastic frame with the clips allowing you to pop it right into place in the mirror once you have popped the old one out.
    If you get a plain glass plate, you then have to separate the frame and its adhesive from the old broken glass and transfer it to the new one, which is more work.
  9. M123
    M123 Junior Member
    New York State
    Interesting, @ChapmanF. Does this video illustrate the correct popping motion -- - YouTube ? Basically, reach behind the mirror and pull?
  10. M123
    M123 Junior Member
    New York State
  11. M123
    M123 Junior Member
    New York State
    Interesting! Does this video illustrate the correct popping motion -- - YouTube ? Basically, reach behind the mirror and pull?
  12. M123
    M123 Junior Member
    New York State
    Argh, sorry for the multiple copies of the same post-- computer was being buggy!
  13. ChapmanF
    18,666
    Did you follow the link I gave in post #2?
    That photo shows the frame from the back (it's from gen 1, though, so might not be identical), showing the snappy clips at the bottom and the tilty clips at the top.
    My approach is to slide a screwdriver right up below where the snappy clips are, and give a little twist to pop them loose. I've never tried just grabbing the bottom edge and yanking, but then, if the glass is already busted, maybe no reason not to try.
    Edit: looked in the gen 3 manual, they suggest a wider "molding remover" tool at the bottom edge, essentially the same as a yank. After putting some protective tape on the lower lip of the housing where the tool would bear against it.
    Once you have it popped out, if it's heated, you find a couple little electrical connectors to unhook. and if it isn't, you don't.
    #13 ChapmanF, Mar 28, 2026
  14. PriusCamper
    13,166
    5,323
    Or even better you could DIY install a fun house mirror and just glue it on top of the old mirror so "objects in mirror will appear funnier than they actually are."
  15. ChapmanF
    18,666
    That's an idea you've got me seriously considering right about now.
  16. PriusCamper
    13,166
    5,323
    Probably better to not look in the rear view mirrors and send a self driving car into the future with modified headlights that can project Princess Leia's message and map of death star vulnerabilities in hopes Obi Wan Kenobi can do something about what we're up against. Maybe the Rebel Alliance still has a chance?
  17. M123
    M123 Junior Member
    New York State
    I'm confused by two very similar part numbers, with a big difference in price. Toyota's website led me to this part: Right Hand Mirror Outer #87931-47170 | Autoparts.toyota.com . I called the dealer and they say I should get this part: Right Hand Mirror Outer #87931-47180 | Autoparts.toyota.com . I put in the VIN number for my vehicle, and the website says both of them are an "exact fit." I asked the parts guy at the dealer about the difference, and he said he didn't know, thought it was for some other vehicle, but it wouldn't be an "exact fit" if that's the case.
  18. ASRDogman
    ASRDogman Senior Member
    7,888
    4,013
    You should remove the broken mirror and see if there is an electrical connect on it.
    That's likely why there are two numerals. One is with and one is without. Either
    will fit. What is the price difference?
    UPDATE: There might be a part number on the back of the mirror, if it hasn't broken apart.
    But you might still be able to read it, or enough of it to get the correct part.
    You could always take it to Toyota so they can look and see which one you need.
    #18 ASRDogman, Mar 31, 2026
  19. ChapmanF
    18,666
    For situations like that, it's possible to do a search for the part number and look at other sources that include a better description of the part. For example, try these two links, and scroll down to Description on each one:
    2010-2014 Toyota 2010-2014 Toyota - Mirror Glass 87931-47170 | Sparks Parts
    2010-2015 Toyota 2010-2015 Toyota - Door Mirror Glass (Right) 87931-47180 | Sparks Parts
    Toyota's own former parts website did provide such information, but they have extirpated it from their new site, possibly because it used to result in informed customers showing up at dealerships and knowing what they wanted.
    Brian1954 likes this.
  20. M123
    M123 Junior Member
    New York State
    Mirror replaced. It was the heated one. Successful project! Thanks PriusChat!
