The passenger side mirror on my 2013 Prius 2 is cracked. I'm thinking through options for replacement. First, any way to tell for sure if it's heated? I assume it is, based on the model and year, but not 100% sure. I tried turning on the rear defrost to see if it heated up, but to the touch I can't tell. Option 1: Buy a Burco glass replacement, not heated, and attach it to the current broken mirror. Option 2: Buy a Bruco heated replacement, break the broken glass out of there, and install. Option 3: Buy a complete replacement mirror, take the door panel apart, and install. Thoughts?
Option 4: Buy the replacement mirror glass from Toyota, pop out the old broken one, pop in the new one, move on to next project. Full disclosure: I've never had to do this on gen 3. You can read this post about how it worked in gen 1. I'm pretty confident it's very similar for gen 3. That linked post was in a thread where someone needed to replace the mirror's color cover, which it doesn't sound like you need, so you can disregard the extra words about that.
Aren't all the Gen 3s heated by default I thought. And heater pad are part of glass or glued on so we'll . All the Gen 3s I've seen are heated and have two pins on the back to connect to the electric system
Yes, when you buy the right glass part number at a Toyota dealer, you'll end up getting the right glass. When it's heated, there will be an electrical connector on it.
Well you can go to the wrong place and buy the mirror both heated and unheated I thought it was all of em . The place I go to has them both and I think you can get both of the plates online fairly inexpensively
Replacement side rear mirrors assemblies for Toyota are super cheap online, like only $30... Or go to a wrecker and it's like three easy bolts to remove the whole assembly and probably cost $40. The plastic cover on the back of the mirror that's usually same color as your car just pops off and you can put it on the new one.
Thanks! Toyota tells me the part number is #87931-47170 -- Right Hand Mirror Outer #87931-47170 | Autoparts.toyota.com -- as best I can tell it's not heated?
I've bought online glass plates before that really were just the glass plate. When you buy it from Toyota, it's the glass plate mounted in the thin plastic frame with the clips allowing you to pop it right into place in the mirror once you have popped the old one out. If you get a plain glass plate, you then have to separate the frame and its adhesive from the old broken glass and transfer it to the new one, which is more work.
Interesting, @ChapmanF. Does this video illustrate the correct popping motion -- - YouTube ? Basically, reach behind the mirror and pull?
Interesting! Does this video illustrate the correct popping motion -- - YouTube ? Basically, reach behind the mirror and pull?
