Best way to connect a electronic mouse repeller under the hood?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by HappyHybrid, Mar 25, 2026.
Tags:
  1. HappyHybrid
    HappyHybrid Junior Member
    42
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Hi folks,
    I was a member of Prius Chat when I had my 2007, got out when it died and I temporarily got a RAV4 hybrid, but a year ago Jan, traded that in for a 2024 Prius Prime. So I'm back! :)
    After my dashboard started flashing with all sorts of error messages on Monday, I took it to the dealership today and found that rodents of some sort have chewed through the wiring and caused all sorts of havoc.
    After I get it back, am planning on trying one of those electronic things (a near perfect 5 start rating on Amazon) that goes under the hood, but not sure where to connect it. Another site said connect to the 12v battery, but they realized that for the prius, the 12v is in the back, so that wouldn't work, and then suggested getting a fuse tap to connect that in the front and then connecting the device to that.
    Just looking for the best way to connect the anti mouse device under the hood. I've used other sonic things to keep cats from my deck, which seemed to work, so given the ratings of the one on Amazon, I'm hopeful that it will work as well.
    Suggestions? TIA
  2. VelvetFoot
    VelvetFoot Senior Member
    1,259
    493
    New York State
    2026 Prius
    Wow that's a bummer and potentially big bucks.
    There's a fusebox under the hood that has a line that goes direct to the battery.
    Maybe someone with knowledge will chime in.
    I would opine that the device should have its own fuse and that you want to be careful with powering that thing for any amount of time because the battery is small. Calculations should be made and maybe use a protective low voltage shut off device like with hardwired dashcams.
    Did this happen over the winter? I wonder if the charging may have created attractive warmth.
    Good luck.
  3. HappyHybrid
    42
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    The dash messages started on Monday, it was working fine on Saturday when I went to work in the AM and then to the movies in the afternoon afterwards. So don't know if they just started on it and did all the damage in one night, or this has been a long term thing and they finally just chewed far enough in to screw up the connection over Sunday. There wasn't any damage when AAA had the hood up to give me a jumpstart in December when my aux battery kept dying, or when Toyota had it then to replace said aux battery.
    Thankfully, apparently my comprehensive coverage on the car actually covers rodent chewed engine wires. So since my policy has a zero deductible for that, the doesn't appear to be costing me anything except maybe an increase in my insurance rates in 6 mo. Which is good, since the estimate my Toyota guy showed me this morning was $3100, to replace the whole of something.
    And Toyota sent me home in a really nice loaner (2026 Camry HEV). Probably would have been different had I gotten a rental from Allstate and they'd sent me to Enterprise again. First rental I got from THEM was a gas guzzling Dodge Grand Behemoth which I traded back to them for something a little more sized for one person after the first day. But I can deal with a week or so of Camry hybrid. :)
    bisco and VelvetFoot like this.
  4. HappyHybrid
    42
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Info from Amazon about the unit I'm looking at, if this helps
    Step-by-Step DC Connection:
    • 1. Locate the 12V Power Source - Use your Prius Prime's fuse box or auxiliary power outlet under the hood
    • 2.Connect the DC Cable - The included DC cable connects directly to your car's 12V electrical system
    • 3.Secure the Connection - Ensure a solid connection to prevent disconnection while driving
    Prius Prime Specific Notes:•
    • Your hybrid has both a 12V auxiliary battery and the main hybrid battery - connect to the 12V system
    • The device draws minimal power and won't affect your hybrid battery performance
    • The intelligent vibration sensor automatically puts the device on standby when you start the car
  5. VelvetFoot
    1,259
    493
    New York State
    2026 Prius
    I've experienced that. I'd put a smiley face, but it's not funny when it happens.
    @Paul Gregory posted a picture of the inside of the fusebox under the hood in regards to connecting a battery maintainer. I've run across websites that have fusebox diagrams for various cars (NOT Toyota, lol, unless you pay I suppose.). Maybe there's a diagram under the fuse cover. Ideally you'd want someone who knows what he's talking about to comment.
    Do you have a link to the product, for interest's sake? That Amazon description sounds like a robot did it.
    I'm assuming your car is parked outside with no access to 120v?
    I've got no experience with rodents. Well, one-there was a mouse nest under the hood in my VW TDI Beetle, and that was parked in my garage. No chewage.
  6. HappyHybrid
    42
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Here's the amazon listing. Funny you mentioned that it sounded like a robot did it. It's what Rufus spit out when I asked it. :D
    http://www.amazon.com/dp/B0FQJH1DF7
    I went ahead and ordered them, will be here tomorrow. Going to try one under my kitchen sink where they keep getting in through a hole in the back of the cupboard and rooting around in the garbage bin under there. I'll know even before I get the car back if they repel the mice or not.
  7. VelvetFoot
    1,259
    493
    New York State
    2026 Prius
    That cat face is pretty cute, with the led eyes.
    Very flexible power options.
  8. bisco
    52,432
    thanks! we've been lucky for 20 years, but I still worry. I think I'll get one for when we're away, and check my insurance policy, that's great coverage! and a free loaner for non warranty work is amazing.
    be careful of draining the battery, prime is pretty weak. I would check the voltage regularly, even though it says low draw. or connect a battery maintainer if you have an outlet available.
    please let us know how it is working, all the best!
  9. Mendel Leisk
    41,962
    Consider meshing the cabin air intake too; it can be a big mess if they get inside there. And the engine air intake. And the air exits, typically at the back corners of the hatch.
    Can you get the car into a tight garage?
  10. HappyHybrid
    42
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    No garage at my house, I cringe every time we get really gusty days, since the yard is full of oak trees and branches frequently snap off and fall. (Currently have a claim in with Allstate for one that poked a hole through my roof and through the side of my house a month ago. Also had the prior RAV4 out of commission for 3 months when a HUGE branch took out the entire back window.)
    I'm making notes of all the things to try. Hopefully the mouse repellents will work if I can figure out how to hook them up.
    VelvetFoot and Mendel Leisk like this.
  11. HappyHybrid
    42
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Doesn't work so far. Mice made a mess out of my under the sink garbage bag overnight, so I'm going to try it for 24 hours with the 4 AA batteries and see if it works that way. If THAT doesn't work, I'm sending it back to Amazon.
  12. VelvetFoot
    1,259
    493
    New York State
    2026 Prius
    did you have it plugged in?
  13. Mendel Leisk
    41,962
    You've got a serious problem. They're getting in somewhere, maybe multiple points. While catching/deterring them is good, finding the entry points is paramount.
    We had mice getting into our crawlspace (then up into the living quarters, through gaps), through foundation wall shortcomings (thanks City of Coquitlam for toothless inspection during construction phase!), and one time rats through one of the crawl space vent grills. I found and closed all the concrete gaps, put rodent mesh over the crawlspace vents.
    To find possible entry points from crawl space to living quarters, I went around the crawl space with a pit lamp, while my wife watched from above, for light getting through. Found and sealed several shortcomings.
    In the living quarters, found several near-inaccessable points that made perfect mice lairs (webcam helped with this). One was behind the built-in dishwasher: pulled it out, cleaned up the mess, and put it all back but with rodent mesh at the egress points.
    For the car, maybe some sort of temporary enclosure? There's no stopping them getting into the engine bay otherwise.
    A webcam that detects motion and lists events is good. Plus copious traps. Keep a list of where they are; it's easy to lose track.
    #13 Mendel Leisk, Mar 29, 2026
  14. HappyHybrid
    42
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    Was using a new USB power pack, that might turn out to be the issue. It doesn't seem to want to charge fully. Once I put batteries in in the rodent thing, the eyes lit up and it has sonic'd multiple times. So I rebaited my garbage with some things that are easy to ID if they pull them out and we'll see what it does today and tonight.
    VelvetFoot likes this.
  15. VelvetFoot
    1,259
    493
    New York State
    2026 Prius
    Does it go off when it detects motion on the AA's? Under the hood-vibration? All to conserve battery.
  16. HappyHybrid
    42
    Raleigh, NC
    2024 Prius Prime
    XSE Premium
    It's supposed to. They're supposed to shut down when they sense vibration, and then restart a couple of minutes after the car is parked.
    Doesn't matter though, I just processed a return for them at Amazon. The one I was testing in the house worked for about a week, and then I could hear them rummaging around in the space right next to it, while it was running. The second one I tested outside underneath the bird feeders where I've actually seen mice hang out. Saw one sitting right next to it last night. So boxed them up for the return. Nice surprise, Amazon is not requiring that I send them back, they've already processed a refund to my giftcard balance. So still looking for something to prevent this from happening again, once I get the Prius back. Took a bit of time to get Allstate to approve and pay for the repair, now waiting on parts, Toyota says it should be about another week and a half or so. So still driving the Camry HEV loaner. Hope they don't expect me to wash it before it comes back, LOL, I got it right at the start of The Pollening here in Raleigh, and now the hangy downs from the trees have started, so the Camry is FILTHY.
