Changing brake fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mhdriver, Mar 2, 2026.
  1. ASRDogman
    ASRDogman Senior Member
    7,823
    3,985
    That is not true. It doesn't leak, unless something is damaged.
    Brake fluid is inside the caliper behind the seal. It doesn't leak past the seal unless the seal
    and/or caliper wall are damaged or cracked.
    The puck moves very little.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,499
    Taylors, SC
    Not true. All rubber seals are wetted with a thin fluid film of lubricant for them to funcas designed. New caliper seals are assembled with a thin film of brake fluid.
    Otherwise, heat will "glue" the lip of the seal to the metal piston.
    It's like coating the rubber seal of the oil filter with a thin film of oil.
    #22 Georgina Rudkus, Mar 7, 2026
  3. mhdriver
    mhdriver Member
    158
    61
    florida
    Well, I ended up doing it like the Carcarenut on YouTube. Drained the reservoir with a syringe. The tubing with the syringe was surprisingly too large in diameter to slide down into the reservoir properly. Ended up finding a straw to slide into the tubing and then down into the reservoir. Got the little hand pump to attach to the bleeding nipples, ran through a few cycles until the fluid coming out was tested good. Did all 4 brakes without difficulty. I disconnected the car battery before I started the whole process. Bought a tester on Amazon.
    All in all, as easy as an oil change.
  4. ChapmanF
    18,548
    Or, when we're following the repair manual, with a bit of lithium-soap-thickened glycol grease.
  5. Mendel Leisk
    41,906
    I gather you didn't put the car in invalid mode? Have a look at brake fluid replacement link in my signature.
    (on a phone turn it landscape to see signatures)
  6. mhdriver
    mhdriver Member
    158
    61
    florida
    No, I didn't. The Car Care Nut says to disconnect your battery and do it the way I did it. He says that's how the dealership actually does it. It was easier by far imo. Brakes working great.
  7. ASRDogman
    7,823
    3,985
    How did you bleed the rear brakes? Since they are electric?
  8. ChapmanF
    18,548
    Maybe mhdriver was just doing "fluid replacement" rather than "air bleeding"? You can sort of get away with those folk methods then.
    We have circled back around to this thread's post #2.
