My grand daughter has a 2013 Prius with about 190k miles. It has recently started experiencing the idle rattle often associated with head gasket failures and/or EGR issues. Originally when the problem started there were no codes but then there was a misfire code (generic). I replaced the spark plugs (they appeared to be original) and it was okay for a short time. The rattle returned and the check engine light came on with codes for random misfire on cylinders 1, 2, and 4. I cleaned the intake manifold and EGR tube - the tube was not too bad but the EGR ports in the manifold were basically plugged. There was a pool of oil-water (?) mix in the bottom of the intake when the throttle body was removed. I replaced the PSV valve while the intake was off. After the intake was reinstalled the rattle returned so I am looking for alternative corrective actions to consider. I should acknowledge that there is some coolant loss but no indication where the coolant is going. The original spark plugs didn't show any indicators and other than the potential of coolant mixing with the oil in the intake it's not apparent where the coolant is going (it isn't going fast). The head gasket seems the next likely problem area but I don't understand how a head gasket failure would affect 3 of the 4 cylinders so I don't want to jump down that rabbit hole until I have a better sense of potential success. I do not believe that the engine has ever over heated but reporting of those type of details can be sketchy from my grand daughter. I thought about the potential that the coolant passing through the throttle body may be a path of leakage that would affect multiple cylinders but I haven't found any information regarding this potential failure so it seems remote. I would appreciate any guidance from the community as I need to decide on an action plan that can be executed over a short time window as it is her only vehicle for getting to and from work.
I'm not sure that's a useful framing of what you're experiencing. The rattle often associated with head gasket failures is one that rattles at cold starts and then clears up after some moments of idling. When associated with plugged manifold EGR ports, it happens at mid-loads (when EGR is used) and not at idle or full throttle (when it isn't). As the EGR valve is s'posed to be closed at idle, a valve that fails to fully close could give you symptoms then.
Do a borescope inspection of the combustion chambers; with your miles, symptoms, and neglected EGR, that’s where you’ll likely find it. did you clean the EGR valve and cooler? There’s several relevant links in my signature. (On a phone turn it landscape to see signatures)
I did not clean the EGR valve or cooler. I was thinking (perhaps incorrectly) that the EGR tube looked reasonable for build up given the miles. I believe I can remove the EGR valve and cooler without removing the intake manifold but do I need to remove the wiper cowling? The rattle only seems to happen at idle. I hadn't considered the possibility that the EGR valve is not closing compeltely resulting in EGR at idle which isn't a good thing. I saw a video of a test for EGR flow at idle that I could try to confirm if that is the rattle problem. I know the EGR cooler is connected to the cooling system but I don't think I have heard of coolant leakage into the intake system at the cooler. I do not have a bore scope but understand there is a test I can run to evaluate the coolant to see if there are combustion gases in the coolant which would confirm a head gasket leak. Any feedback regarding this approach would be appreciated.
Coolant can leak into any cylinder or any combination of them, but most often into #1 or #2, I hear. The test for gases in the coolant approach typically doesn't reveal head gasket failure until it's severe enough to risk bent connecting rods, etc.
Thanks for the feedback on the coolant chemical test and the information regarding most common cylinders to have head gasket failure. I am still struggling with the idea that I have misfire codes for 3 of the 4 cylinders with the one that did not code being between ones that did. The problem (rattle, perceived to be the precursor to misfire codes) appears to be most prevalent after initial cold start while at idle. At that time the potential for coolant leak would be pretty small (no pressure in the cooling system) and EGR flow should be minimum even if the valve isn't sealing well. I have the strong sense that there is something simple I'm missing but really getting frustrated with the lack of benefit for the efforts put into it so far.
Yeah, the intake manifold can be a separate job. If I recall correctly someone here managed to remove the valve and cooler without removing the windshield wipers, trim and cowl, but swore never again. Top two links in my signature pertain to EGR cleaning. This will be of interest too, a rudimentary workflow. No, there's a fault in your logic: there's multiple ways the head gasket can fail, and with gen 3 Prius it invariably starts as coolant leaking into combustion chamber.
