2013 Prius Misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by WICruiser, Mar 30, 2026.
  1. WICruiser
    WICruiser New Member
    24
    WI
    My grand daughter has a 2013 Prius with about 190k miles. It has recently started experiencing the idle rattle often associated with head gasket failures and/or EGR issues. Originally when the problem started there were no codes but then there was a misfire code (generic). I replaced the spark plugs (they appeared to be original) and it was okay for a short time. The rattle returned and the check engine light came on with codes for random misfire on cylinders 1, 2, and 4. I cleaned the intake manifold and EGR tube - the tube was not too bad but the EGR ports in the manifold were basically plugged. There was a pool of oil-water (?) mix in the bottom of the intake when the throttle body was removed. I replaced the PSV valve while the intake was off. After the intake was reinstalled the rattle returned so I am looking for alternative corrective actions to consider. I should acknowledge that there is some coolant loss but no indication where the coolant is going. The original spark plugs didn't show any indicators and other than the potential of coolant mixing with the oil in the intake it's not apparent where the coolant is going (it isn't going fast).
    The head gasket seems the next likely problem area but I don't understand how a head gasket failure would affect 3 of the 4 cylinders so I don't want to jump down that rabbit hole until I have a better sense of potential success.
    I do not believe that the engine has ever over heated but reporting of those type of details can be sketchy from my grand daughter.
    I thought about the potential that the coolant passing through the throttle body may be a path of leakage that would affect multiple cylinders but I haven't found any information regarding this potential failure so it seems remote.
    I would appreciate any guidance from the community as I need to decide on an action plan that can be executed over a short time window as it is her only vehicle for getting to and from work.
  2. ChapmanF
    18,916
    I'm not sure that's a useful framing of what you're experiencing. The rattle often associated with head gasket failures is one that rattles at cold starts and then clears up after some moments of idling.
    When associated with plugged manifold EGR ports, it happens at mid-loads (when EGR is used) and not at idle or full throttle (when it isn't).
    As the EGR valve is s'posed to be closed at idle, a valve that fails to fully close could give you symptoms then.
  3. Mendel Leisk
    42,212
    Do a borescope inspection of the combustion chambers; with your miles, symptoms, and neglected EGR, that’s where you’ll likely find it.
    did you clean the EGR valve and cooler? There’s several relevant links in my signature. (On a phone turn it landscape to see signatures)
    #3 Mendel Leisk, Mar 30, 2026
  4. WICruiser
    24
    WI
    I did not clean the EGR valve or cooler. I was thinking (perhaps incorrectly) that the EGR tube looked reasonable for build up given the miles. I believe I can remove the EGR valve and cooler without removing the intake manifold but do I need to remove the wiper cowling?
    The rattle only seems to happen at idle. I hadn't considered the possibility that the EGR valve is not closing compeltely resulting in EGR at idle which isn't a good thing. I saw a video of a test for EGR flow at idle that I could try to confirm if that is the rattle problem. I know the EGR cooler is connected to the cooling system but I don't think I have heard of coolant leakage into the intake system at the cooler.
    I do not have a bore scope but understand there is a test I can run to evaluate the coolant to see if there are combustion gases in the coolant which would confirm a head gasket leak. Any feedback regarding this approach would be appreciated.
  5. CR94
    CR94 Senior Member
    2,806
    1,233
    Northwestern S.C.
    Coolant can leak into any cylinder or any combination of them, but most often into #1 or #2, I hear.
    The test for gases in the coolant approach typically doesn't reveal head gasket failure until it's severe enough to risk bent connecting rods, etc.
  6. WICruiser
    24
    WI
    Thanks for the feedback on the coolant chemical test and the information regarding most common cylinders to have head gasket failure. I am still struggling with the idea that I have misfire codes for 3 of the 4 cylinders with the one that did not code being between ones that did.
    The problem (rattle, perceived to be the precursor to misfire codes) appears to be most prevalent after initial cold start while at idle. At that time the potential for coolant leak would be pretty small (no pressure in the cooling system) and EGR flow should be minimum even if the valve isn't sealing well.
    I have the strong sense that there is something simple I'm missing but really getting frustrated with the lack of benefit for the efforts put into it so far.
  7. Mendel Leisk
    42,212
    Yeah, the intake manifold can be a separate job.
    If I recall correctly someone here managed to remove the valve and cooler without removing the windshield wipers, trim and cowl, but swore never again.
    Top two links in my signature pertain to EGR cleaning. This will be of interest too, a rudimentary workflow.
    No, there's a fault in your logic: there's multiple ways the head gasket can fail, and with gen 3 Prius it invariably starts as coolant leaking into combustion chamber.
    CR94 likes this.
  8. WICruiser
    24
    WI
    Thank you for the on-going input. It can get frustrating when you keep trying "fixes" without real success.
    I am hoping to get an extended time period with the car to complete the EGR system cleaning, cleaning of the mass air flow sensor, and further evaluate the potential for head gasket pending failure. If head gasket replacement is required I am not sure how we will proceed as the cost and time for repairs may exceed my grand daughter's tolerance for needing her car on a daily basis.
  9. Mendel Leisk
    42,212
    Yeah she’d probably need a “loaner”, for head gasket. And it’s definitely a bigger gulp, for a first time DIY’r. (That’d be me as well…)
  10. WICruiser
    24
    WI
    Jumped into the head gasket replacement project. I hope to have it disassembled today for inspection, parts are on order and should arrive Monday with hopes to have it back on the road by Wendesday.
    Removing the EGR cooler is a real challenge but I did get it. Now I need to find that socket (external torx for the studs) I dropped somewhere in the steering unit area.
  11. WICruiser
    24
    WI
    Head has been removed and there is some indication of coolant (at least wetness) on top of #1 and #4 pistons (#1 is worst by far). Pistons in #2 and #3 appear dry. There may be a leakpath on the head gasket for cylinder #1 (black sealing material missing in one small area). Cylinder bores for #2 and #3 look great, need to rotate the crankshaft to look at #1 and #4.
    I perplexed why I was getting misfire codes for cylinder #3 and not sure there is a leak leading to the code for cylinder #4.
    I plan to evaluate the valves for sealing and head for flatness but otherwise clean and rebuild with new head gasket and timing chain parts.
    I also plan to clean and test the EGR valve and cooler.
    Removing the cylinder head with the exhaust manifold still attached to the downstream system is challenging because the studs for the exhaust are fighting the locator dowel pins on the head. I may try to remove exahust system supports down stream to allow the exhaust manifold to move back for easier assembly.
  12. BiomedO1
    4,464
    2,350
    Left Coast
    The ECU is guessing at the misfiring cylinder based on the cam sensor position when the engine is shaking. That's why you also get P0300 codes too; ECU can't figure out which one is missing within 80% accuracy. That's why I don't trust diagnosticians that won't look under the hood.
    Re; timing chain, focus on the chain, tensioner, and any plastic chain guides.
    Re; EGR cooler, plug one end and pressure test for coolant leaks before reinstalling.
    Look at that electric ICE water pump; I'd replace it along with the thermostat.
    Think about installing something like a P10 HUD to monitor ECT and set alarm at 210F; that dummy lamp doesn't light-up until 248+F. Normal operations is between 185F-200F. That's assuming she's looking at her gauge cluster and seeing it light-up. That may be part of the reason why the head gasket blew without an overheat. She could've been running that engine at 245F all day long. That's hot enough to break things, but not hot enough to set-off that trouble lamp.
    Hope this helps......
  13. WICruiser
    24
    WI
    Thanks for the additional input. I did not know what temperature the alarm for coolant is and while I don't believe it ever was illuminated I agree that it could have been running hotter than normal a long time. I wasn't planning to replace the water pump and thermostat but given your input I may (although a lot of the aftermarket stuff is junk and may be worse than the old original).
    I did order a timing chain kit that includes the chain, tensioner, and guides so that is part of the plan.
    BiomedO1 likes this.
  14. BiomedO1
    4,464
    2,350
    Left Coast
    Here's a thread for you to read and you can make an informed decision. This guy was lucky and his actually threw codes - most don't.
    Would you worry? Long trip planned and.... | PriusChat
    That's the problem with these cars with only a dummy lamp, at least with a gauge you have a chance of avoiding this issue.
  15. WICruiser
    24
    WI
    EGR cooler is basically totally blocked. Really struggling to get it cleaned out. The ends are now clean but the channels, especially on the inet end are still packed solid. I considered buying a new one but the price tag settled that.
    Has anyone run EGR with the cooler removed? I don't think it would be that hard to bypass the coolant connections and ither replace the cooler with a tube or gut the cooler and mount it in place. I have seen threads about EGR delete but this would still have EGR just not "cooled".
  16. BiomedO1
    4,464
    2,350
    Left Coast
    A clogged EGR cooler is basically an EGR delete. This depends on your states emission control inspection laws.
    Have you tried soaking it, submerged in a bucket of carbon/degreaser for a day or two? That usually does the trick. 40+ years ago, when I was working in a burger joint - we used to have this purple stuff that stripped all the crud off of the stainless steel components of the meat patty broiler. Don't know if that stuff is still around or if it's been outlawed by the EPA. A half hour soak in that stuff would strip-off all the burnt meat drippings. It came out shiny and new.
    #16 BiomedO1, Apr 5, 2026
  17. rjparker
    10,923
    6,853
    You certainly have a hg leak. The misfire detection is not accurate on this hybrid when the transaxle damper is slipping. The rest of your symptoms match thousands of other gen3 hg failures.
    You don't want uncooled exhaust gasses straight into the intake and it would probably code. Blocking the egr path has been done and results in no real driveability problems but this will code as well. Perhaps a bigger problem than the code is the check engine light would always be on, potentially masking future issues.
    I would buy a new one. This new ebay unit is about $200 with quick delivery.
  18. Mendel Leisk
    42,212
    I got nowhere fast, using copious brake cleaner.
    Try lye solution. Stopper one end, pour in solution, prop cooler in corner of laundry sink for about an hour, rinse and repeat as needed. NaOH (lye) or KOH will do, the latter is more readily available, being a soap making staple, and maybe more affective too.
    another cooler source :
    https://www.amayama.com/en/part/toyota/2560137010
    It’s showing roughly $204 CDN for me. In past purchases that’s it, no extra tax or duty. That may have changed though, with the current international trade climate.
    #18 Mendel Leisk, Apr 5, 2026
  19. rjparker
    10,923
    6,853
    1-4 day delivery?
  20. Mendel Leisk
    42,212
    Typically a week to ten days for me.
