215/50r17 safe to run?
Discussion in 'Gen 4 Prius Main Forum' started by DonutHands, Apr 4, 2026 at 12:10 PM.
  1. DonutHands
    DonutHands Junior Member
    I know it’s about 1 inch larger diameter than stock. Anyone safely run slightly oversized tires?
  2. JC91006
    JC91006 Senior Member
    16,833
    8,603
    Yes this size is perfectly fine for the Prius. You can do a search for that size on a Prius, you'll see many people have been using that size and didn't have any issues
  3. DonutHands
    Thanks. I searched a ton, couldn’t find anyone saying it was good on a 4th gen. Seems to be stock on Prius V which makes searching difficult.
  4. Mendel Leisk
    41,925
    What?!
    4th gens come from the factory with either 195/65R15 or 225/45R17. The latter is actually slightly smaller outside diameter.
    a 215/50R17 I’d guesstimate to be near identical OD to the stock 15”. Definitely not an inch more.
    this site is good for comparisons:
    Tire Size Comparison
