215/50r17 safe to run?
Discussion in 'Gen 4 Prius Main Forum' started by DonutHands, Apr 4, 2026.
  1. DonutHands
    DonutHands Junior Member
    I know it’s about 1 inch larger diameter than stock. Anyone safely run slightly oversized tires?
  2. JC91006
    16,936
    8,647
    Yes this size is perfectly fine for the Prius. You can do a search for that size on a Prius, you'll see many people have been using that size and didn't have any issues
  3. DonutHands
    Thanks. I searched a ton, couldn’t find anyone saying it was good on a 4th gen. Seems to be stock on Prius V which makes searching difficult.
  4. Mendel Leisk
    42,323
    What?!
    4th gens come from the factory with either 195/65R15 or 225/45R17. The latter is actually slightly smaller outside diameter.
    a 215/50R17 I’d guesstimate to be near identical OD to the stock 15”. Definitely not an inch more.
    this site is good for comparisons:
    Tire Size Comparison
    Doug McC likes this.
  5. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Nice site! Never would have figured both OEM sizes to be basically equal (not that I gave it that much thought), but still….
  6. Mendel Leisk
    42,323
    ugh, fat-finger typo, coupled with the site’s edit limit, please note above correction, for post #4.
  7. PHEVisthefuture
    PHEVisthefuture Junior Member
    83
    25
    Illinois
    I personally have had no issues running slightly different tire sizes on anything I've owned, but be aware - some insurance companies may deny a claim in the event of an accident and a tire size / rim size swap even though from an engineering perspective, it's totally fine.
