Prius head gasket job - broken cam bolt
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ComfyBag, Apr 5, 2026.
  1. ComfyBag
    ComfyBag New Member
    Iowa
    Hoping someone can help me out here.. I’ve been watching all the videos online and following along the nutsaboutbolts on Yoruba for a head gasket replacement. Everything was going well, but during the reinstall, when I was torquing the first cam bolt, it snapped! Fortunately I was able to back it out but I’m not positive what the part number is for the replacement (2012 Prius V) I did use new head bolts but none of the guides online mentioned purchasing new cam bolts (the 17 gold bolts holding the camshaft cap)
    1. Should I purchase all new bolts?
    2. Does anyone know the Toyota part numbers for the 16 long bolts, and the 1 short bolt?
    thank you in advance, this forum has been a lifesaver.
  2. Mendel Leisk
    42,365
  3. Tombukt2
    13,868
    2,521
    Just replace the cam bolt you mite find at tractor supply . Not mission critical . Just a bolt. As you found out . Junk yard . A shop floor etc .
  4. Mendel Leisk
    42,365
    What torque value? Screen grab from last link in my signature*:
    * on a phone turn it landscape to see signatures
  5. ChapmanF
    19,045
    If you don't get the specific bolt from Toyota, make sure to get the same length and grade so it'll stand up to the same torque conditions.
  6. ComfyBag
    ComfyBag New Member
    Iowa
    Thank you so much! I was torquing to 20ft lbs. I’m thinking my torque wrench was off or malfunctioning.
    Just ordered a new one as well so hopefully it won’t happen again.
  7. ComfyBag
    ComfyBag New Member
    Iowa
    Thanks! I decided to order from Toyota as I need to pick up a new timing tensioner anyway.
  8. cdherman
    cdherman Member
    68
    27
    Kansas City
    I cannot believe that anything in the vague ball park of 20lbs of torque would twist one of those bolts off..... Wow. Agree with new torque wrench. Are you new to this stuff? I ask because most of us who have "wrenched" for a while have a approximate idea of how tight to tighten a bolt and when too much is too much. Not accusing you of being dumb, but experience has its perks........
  9. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    Hopefully better than the last bolts torque conditions...
  10. ComfyBag
    ComfyBag New Member
    Iowa
    no offense taken :) my experience has been limited to brakes/struts/spark plugs in the past.
    Honestly it never felt like the bolt hit any resistance.. I think part of the problem is that the loaner torque wrench I have is this huge 24” breaker bar type and even setting it as low as 20ft lbs was difficult (first marked setting was 25) . I’ve since ordered a smaller 5-45 ft lb torque wrench. Fingers crossed it’s smooth sailing from here.
  11. Mendel Leisk
    42,365
    A Sears employee told me years ago, you don’t want to use a torque wrench near its extremes. 1/2” drives are good for wheel lug nuts, suspensions. 3/8” have lower range, appropriate for brakes, oil changes, and 1/4” (typically incremented inch-pounds, values 12 fold of foot-pounds) are for spark plugs, throttle body hold-down bolts, battery connections.
    I’ve had a 1/2” drive for about 40 years, but in the last decade acquired 3/8” and 1/4”. Made in China, decent quality/accuracy, are about $30~40 CDN. I’ve “tested” them by clamping the fulcrums in a vice, arms horizontally, suspending known weight at calculated distance along the handle, and all 3 where surprisingly accurate.
    There’s “factors” too, well oiled threads for example, will turn (and tension) more.
    did you note in pic I posted above, there’s 20 and 12 foot-pound values? Thelong versus short apparently. You’re more familiar than me, having dealt with these; I’d gather the two kinds of bolts serve different purposes?
