2003 Prius with P3191
Discussion in 'Generation 1 Prius Discussion' started by Iris_TheRainbow, Apr 5, 2026 at 2:46 PM.
  1. Iris_TheRainbow
    Iris_TheRainbow New Member
    Sunday
    Illinois
    2003 Prius
    Hello!
    I just bought a Gen 1 Prius because it had a battery that was less than 2 years old for basically nothing, drove it home 140 miles just fine, besides partway home the display started flashing white when I took a break, but that went away after a bit of driving. It needed some stuff done, nothing outside the realm of what I was capable of, (tires, a new hood and bumper, probably a bearing, its got some rust, including a small exhaust leak).
    Unfortunately, I am an idiot and left a cheap handheld code reader plugged into the OBD2 port for 2 days or so, and when I got back to the car the 12v battery was pretty flat. Turning the key did nothing. I went and jumped it, car started up but with the triangle of death and the display. I had lost my nicer prius aware OBD2 reader, so I ordered a new one and unplugged the 12v battery and left it on a trickle charger overnight. The issue came back when I tried again, I did the same thing until I got the code reader, then drove the car around my neighborhood until I got the triangle again, watching the DR Prius app on my phone, the battery was looking healthy, charging and discharging as expected. engine was running great. It didn't show up until I stopped for coffee, then when I got back to the car and started it, the engine started (I am almost positive it actually did because of the exhaust leak), then the engine just shut off, way more rough than usual, and the P3191 code came up. The display is now really dim and still flashing.
    Being a code for the engine not starting, this feels really odd. It was running fine, it started up when the code showed up. The 12v battery sits at ~12.6v when the cars not running. I'd love some help trouble shooting it, I do have access to a nearly complete junkyard 2002, that as far as I can tell was just put there because its battery went bad and the owner couldn't afford to replace it, so if it needs parts thats not a huge worry.
  2. Trombone
    Trombone Active Member
    359
    124
    Allentown, Pennsylvania
    2002 Prius
    Clean the MAF sensor and possibly also the throttle body.
  3. Iris_TheRainbow
    Sunday
    Illinois
    2003 Prius
    Is there something specific to look for on the map sensor/throttle body? Just like black gunk?
    I’ll give that a try when I get home. I drove it around more this morning and didn’t have it comeback, and I drove it the most I have since the issue started happening, so I am starting to wonder if it was a fuel problem, since it’s not happened since I went from low to half full on the fuel tank
  4. Trombone
    359
    124
    2002 Prius
    The MAF sensor is located at the front of the hood under the engine air filter box; it's held in by two Philliips head screws. Remove and clean with dedicated MAF sensor cleaner only (I use CRC brand). Spritz all of the orifices but do not contact any part of the sensor! Let dry thoroughly and re-install. Check the engine air filter while you're at it; replace as needed. If the throttle body is visibly dirty, you'll need to remove the air filter box in order to properly clean surfaces (butterfly and throat) with dedicated throttle body cleaner and shop rags.
    #4 Trombone, Apr 6, 2026 at 5:28 PM
  5. Iris_TheRainbow
    Sunday
    Illinois
    2003 Prius
    I pulled the MAF sensor and it was pretty clean looking, the bulb thing had a bit of black sludge on it that came right off with the MAF cleaner. The throttle bodys a little darkened but doesnt seem to have much built up on it.
    The air filter is basically brand new.
    I drove it even more today with no problem
  6. dolj
    dolj Senior Member
    8,563
    4,350
    Wellington, New Zealand
    Are you sure about that? In the Gen 2 they are Japanese Industrial Standard (JIS) star-head screws.
    You have to spray the MAF (mnice person airflow)sensor wires to clean them. These wires are inside an orifice that is perpendicular to the airflow.
  7. ChapmanF
    18,569
    The "MAF sensor" is really a combination MAF and intake-air-temperature sensor. The bulb thing is the temperature sensor. The MAF is sensed by two fine wires that you never even see unless you look way down a passage in the sensor. Those are the things to carefully spray.
  8. Trombone
    359
    124
    2002 Prius
    [/Quote]dojl said, "Are you sure about that? In the Gen 2 they are Japanese Industrial Standard (JIS) star-head screws."[/Quote]
    We're talking Gen 1 here, not Gen 2. And yes, in my 2002 Gen 1, they are Phillips-head.
    #8 Trombone, Apr 7, 2026 at 10:44 AM
  9. ChapmanF
    18,569
    Here in the US, if I really wanted to own a JIS screwdriver, I'm not sure I could easily get one anywhere except mail-order from Vessel.
    So I keep using my Phillips screwdrivers that I can get at any hardware store, and they keep doing the trick.
  10. Trombone
    359
    124
    2002 Prius
    OK, guess I didn't know there was a difference. P-head works just fine for me too.
