2003 Prius with P3191
Discussion in 'Generation 1 Prius Discussion' started by Iris_TheRainbow, Apr 5, 2026.
  1. Iris_TheRainbow
    Iris_TheRainbow New Member
    22
    Illinois
    2003 Prius
    Hello!
    I just bought a Gen 1 Prius because it had a battery that was less than 2 years old for basically nothing, drove it home 140 miles just fine, besides partway home the display started flashing white when I took a break, but that went away after a bit of driving. It needed some stuff done, nothing outside the realm of what I was capable of, (tires, a new hood and bumper, probably a bearing, its got some rust, including a small exhaust leak).
    Unfortunately, I am an idiot and left a cheap handheld code reader plugged into the OBD2 port for 2 days or so, and when I got back to the car the 12v battery was pretty flat. Turning the key did nothing. I went and jumped it, car started up but with the triangle of death and the display. I had lost my nicer prius aware OBD2 reader, so I ordered a new one and unplugged the 12v battery and left it on a trickle charger overnight. The issue came back when I tried again, I did the same thing until I got the code reader, then drove the car around my neighborhood until I got the triangle again, watching the DR Prius app on my phone, the battery was looking healthy, charging and discharging as expected. engine was running great. It didn't show up until I stopped for coffee, then when I got back to the car and started it, the engine started (I am almost positive it actually did because of the exhaust leak), then the engine just shut off, way more rough than usual, and the P3191 code came up. The display is now really dim and still flashing.
    Being a code for the engine not starting, this feels really odd. It was running fine, it started up when the code showed up. The 12v battery sits at ~12.6v when the cars not running. I'd love some help trouble shooting it, I do have access to a nearly complete junkyard 2002, that as far as I can tell was just put there because its battery went bad and the owner couldn't afford to replace it, so if it needs parts thats not a huge worry.
  2. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    Clean the MAF sensor and possibly also the throttle body.
  3. Iris_TheRainbow
    22
    Illinois
    2003 Prius
    Is there something specific to look for on the map sensor/throttle body? Just like black gunk?
    I’ll give that a try when I get home. I drove it around more this morning and didn’t have it comeback, and I drove it the most I have since the issue started happening, so I am starting to wonder if it was a fuel problem, since it’s not happened since I went from low to half full on the fuel tank
  4. Trombone
    389
    130
    2002 Prius
    The MAF sensor is located at the front of the hood under the engine air filter box; it's held in by two Philliips head screws. Remove and clean with dedicated MAF sensor cleaner only (I use CRC brand). Spritz all of the orifices but do not contact any part of the sensor! Let dry thoroughly and re-install. Check the engine air filter while you're at it; replace as needed. If the throttle body is visibly dirty, you'll need to remove the air filter box in order to properly clean surfaces (butterfly and throat) with dedicated throttle body cleaner and shop rags.
    #4 Trombone, Apr 6, 2026
  5. Iris_TheRainbow
    22
    Illinois
    2003 Prius
    I pulled the MAF sensor and it was pretty clean looking, the bulb thing had a bit of black sludge on it that came right off with the MAF cleaner. The throttle bodys a little darkened but doesnt seem to have much built up on it.
    The air filter is basically brand new.
    I drove it even more today with no problem
  6. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Are you sure about that? In the Gen 2 they are Japanese Industrial Standard (JIS) star-head screws.
    You have to spray the MAF (mnice person airflow)sensor wires to clean them. These wires are inside an orifice that is perpendicular to the airflow.
  7. ChapmanF
    19,016
    The "MAF sensor" is really a combination MAF and intake-air-temperature sensor. The bulb thing is the temperature sensor. The MAF is sensed by two fine wires that you never even see unless you look way down a passage in the sensor. Those are the things to carefully spray.
  8. Trombone
    389
    130
    2002 Prius
    We're talking Gen 1 here, not Gen 2. And yes, in my 2002 Gen 1, they are Phillips-head.
    #8 Trombone, Apr 7, 2026
  9. ChapmanF
    19,016
    Here in the US, if I really wanted to own a JIS screwdriver, I'm not sure I could easily get one anywhere except mail-order from Vessel.
    So I keep using my Phillips screwdrivers that I can get at any hardware store, and they keep doing the trick.
  10. Trombone
    389
    130
    2002 Prius
    OK, guess I didn't know there was a difference. P-head works just fine for me too.
  11. Iris_TheRainbow
    22
    Illinois
    2003 Prius
    I did spray every hole from every angle I could.
    Thing got really confusing today. I accidentally pulled off the 12v battery negative terminal, and the first time I tried to start it after it was put back on, the same P3191, engine starts then dies hard thing happened again. Cleared it by disconnecting the battery again, it drove fine and has driven 20 miles in the city since then with no issues starting it (have been watching the engine RPM with an app on my phone and it never has problems starting.
    I'm starting to lean towards just keeping a 10mm wrench in the trunk and my ELM327 thing on my glove box and driving it as it is.
  12. Iris_TheRainbow
    22
    Illinois
    2003 Prius
    I'm pretty sure they're JIS, that would be expected of a Japanese company, and they fit perfectly with my jis driver. the bottom screw is a pain in the nice person. If I didn't have a flexible shaft for my iFixit driver, I would've had to take the top part of the radiator cradle off.
  13. Trombone
    389
    130
    2002 Prius
    Bottom screw is a bugger alright. I have a stubby P-head screwdriver that fits in there. At least, I think it's a P-head; it came with a knocked-down piece of furniture from---you guessed it---China! Maybe it's a Chinese version of a Japanese JIS-modified copy of a P-head. Who the heck knows? As long as it works....
  14. dolj
    dolj Senior Member
    8,646
    4,397
    I agree, as long as you're careful. Even so, I still manage to mangle enough JIS star-heads using a P-driver, that I prefer using a JIS-driver. So, there's that.
    #14 dolj, Apr 7, 2026
  15. Iris_TheRainbow
    22
    Illinois
    2003 Prius
    Honestly, I've found that JIS bits tend to be better even in normal philips head screws. I just always use my JIS when I have the right size
  16. ChapmanF
    19,016
