Replaced fuse box housing - transmission "P" lock mechanism appears
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TechBill, Apr 5, 2026 at 5:21 PM.
  1. TechBill
    TechBill New Member
    Missouri
    Brought a rebuilt 2007 Prius and have been driving it for about a month while replacing a few parts.
    The fuse box housing was cracked from previous hood damage, so I picked up a replacement fuse box from a junkyard. I did not swap the actual fuse box electronics or connectors, only the plastic housing.
    The process was simple. I unclipped all connectors from the damaged housing, slid everything out, and snapped it into the replacement housing. Everything went back exactly where it was.
    After finishing, I reconnected both the 12V and hybrid battery.
    The car powers up fine, but now I get a red triangle warning and a message on the display saying there is a problem with the transmission "P" lock mechanism.
    Here’s the strange part. There is no check engine light and no trouble codes showing. The car shifts into Drive, Reverse, and Park normally and drives perfectly fine.
    I have checked all fuses and everything looks good.
    Has anyone run into this before or have any idea what could cause a "P" lock warning when everything seems to function normally?
    Thanks in advance.
  2. ChapmanF
    18,569
    Can you get access to a scan tool and tell us what P lock warning you have?
  3. Tombukt2
    13,480
    2,423
    Codes aren't displayed until you plug in tool.
  4. Tombukt2
    13,480
    2,423
    Two or three restarts it'll probably go away
  5. TechBill
    TechBill New Member
    Missouri
    I plugged in Techstream and here’s what I found so far.
    The initial codes were B1210 and B1271, which appear to be related to the Gateway. From what I understand (and what AI suggested), these don’t directly cause the “P” warning but may indicate the ECU isn’t fully satisfied with system conditions.
    I then checked the Hybrid Control system and found code P0A0D (High Voltage System Interlock Circuit High). I’m not entirely sure how to interpret that yet, especially since the car still drives fine in both Drive and Reverse.
    One thing I did notice while testing: a few times when I shut the car down and restarted it, all the warning lights came on and the car would not go into Drive or Reverse. After shutting it down again and waiting a bit, it would start normally and drive, but the “P” warning still shows.
    Still scratching my head on this one. Any thoughts would be appreciated.
  6. Brian1954
    Brian1954 Senior Member
    2,415
    970
    South Central PA, USA
    In Techstream, click on Health Check and post a picture of the results.
  7. TechBill
    TechBill New Member
    Missouri
  8. Tombukt2
    13,480
    2,423
    Usually with this p lock nonsense it has to do with 12 V. Make sure daum sure it's correct. Everybody says it is and then a week later comes back and says oh it was my 12-volt so be sure . a blue wire in the fuse box. There are posts about it that people jump a wire from P lock fuse to blue wire under cover top left in fuse box . Lotsa post about it.
  9. ChapmanF
    18,569
    That health check isn't showing any current trouble codes, only historical ones.
    More concerning, that health check isn't even showing nearly enough ECUs. In a gen 2 there should be around a dozen. Somehow, Techstream here is not even talking to the engine or HV or brake/skid or transmission control ECUs, for example. (The transmission control ECU is the one that would have the codes related to P lock.)
    Somehow, that needs to be gotten to the bottom of.
    Brian1954 likes this.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,000
    NJ-USA
    Was the car powered on to ready or ignition ON? I believe those 5 ecu's are the ones that will report even if the ignition is off.
  11. TechBill
    TechBill New Member
    Missouri
    I can't remember but I will run the test again with car ready on and report back.
    Thanks
  12. Pubrica
    Pubrica Junior Member
    South Torrance, CA
    If you are able to drive car now, better to make few time driving cycle or more time need to drive, Some time, those problem will disappear or continuing that has problem. Good luck and Have to post my problem that relate to front fuse box.
    TechBill likes this.
  13. TechBill
    TechBill New Member
    Missouri
    Still at work, but on my lunch break I did a little research and it looks like this might be a common issue with the P lock and fuse box. Some people are finding corrosion on the terminal for the 7.5 fuse that feeds the P lock.
    A few said they fixed it by adding a jumper wire from the fuse to the connector that goes to the P lock module.
    When I get home, I’m going to check the voltage on that wire to see if it’s getting power.
    Has anyone else run into this issue, and was that the cause?
    Thanks
  14. pasadena_commut
    pasadena_commut Senior Member
    2,870
    861
    Southern California
    I'm wondering if the car had that jumper wire and somehow it didn't make it into the new fuse box case.
