Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. ASRDogman
    ASRDogman Senior Member
    7,883
    4,012
    At least you caught it! Did you have to do all 4? Or just the one.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,752
    1,780
    Bay Area
    I did all 4, took me 20-30 mins, wasn’t too bad. the other 3 wasn’t too obvious besides the right front one, which became flat at around 20psi or so. It was a slow leak that wasn’t obvious to the naked eye.
    it’s fixed now so it’s good to go.
    Danny3xd () and ASRDogman like this.
  3. NutzAboutBolts
    1,752
    1,780
    Bay Area
    Just finished resealing my timing cover leak. Going to recheck in 10k miles to see if it’s still leaking or not.
  4. Mendel Leisk
    42,004
    What did you use?
  5. NutzAboutBolts
    1,752
    1,780
    Bay Area
    what do you mean?
  6. Mendel Leisk
    42,004
    What form-in-place gasket?
  7. NutzAboutBolts
    1,752
    1,780
    Bay Area
    Toyota’s FIPG. It’s the white tube. This time I let it cure for 24 hrs before I put in the oil and I added more fipg at the leak spot lol.
  8. ASRDogman
    7,883
    4,012
    Guess it was the timing cover then.... Bummer!
    I remember when I did mine, I read where each bolt when, and which one to put in first.
    I read several times, just to be careful. Guess I did good, because it's not leaking!
  9. NutzAboutBolts
    1,752
    1,780
    Bay Area
    I think I didn’t put enough fipg at that area. Everywhere else was fine besides that spot by the timing chain tensioner for some reason. I’m gonna recheck in 10k miles and see if it’s still seeping out from there. Overall my car isn’t burning oil, it was just seeping from that spot. So losing 1 1/4 quart of oil is pretty good within 10k miles with a seepage.
  10. ASRDogman
    7,883
    4,012
    I think Toyota says to put a larger amount in the area where the head meets the block.
    I'm sure you'll be fine, no more leaks....
  11. NutzAboutBolts
    1,752
    1,780
    Bay Area
    yeah but that’s the thing, it wasn’t that area… it was right below the timing chain tensioner where the 14mm #2 bolt was at on the timing cover. I added an extra dab around the bolt hole and underneath it as well since it was leaking from there.
  12. Mendel Leisk
    42,004
    Toyota recommends a horizontal bead of sealant at each of the engine seams. My take: apply the regular bead to the timing chain cover, and apply those horizontal beads directly on the seams, on the engine face.
    They also show a thickening of the regular bead, at certain points, and while they don’t clarify, it looks to be at those seams. Just saying to thicken the reg beads at the horizontal engine seams would be simpler, compared to the dimension laden drawings they provide. (See attached)
    Gasket Masters was using and advocating Permatex Ultra Black. Compared to what Toyota specs in Repair Manual, it has a much longer cure time, maybe better for DIY.
    If you google the above name the AI summary is interesting, saying in part:
    Usage Instructions
    1. Prepare: Ensure surfaces are clean, dry, and free of oil/grease.
    2. Apply: Apply a continuous, uniform bead to one surface, surrounding all bolt holes.
    3. Assemble: Assemble parts immediately while the silicone is still wet.
    4. Tighten: Finger-tighten until material begins to seep out, then let it set for two hours before re-torquing.
    #652 Mendel Leisk, Apr 9, 2026
  13. ASRDogman
    7,883
    4,012
    Maybe some dirt got in there when you put the cover on, or maybe when installing it you
    accidentally removed some of the sealer. It's easy to do. I was worried about it when I installed
    the cover. Not much room to do it.
    Main thing is you found it and fixed it.
    NutzAboutBolts likes this.
  14. NutzAboutBolts
    1,752
    1,780
    Bay Area
    If you have louder than normal engine noise after doing a timing cover reseal, make sure you didn’t squish your valve cover gasket and having oil leaking out In the front by the intake manifold.
    Ask me how I know? :ROFLMAO::ROFLMAO:
    all fixed an no more louder than normal engine noise. (y)
  15. ASRDogman
    7,883
    4,012
    It just wasn't your day was it? :oops:(y)
    But you were in a hurry to get it done...
    Overall, it was minor stuff. At least you didn't forget to put the head gasket one! :eek::eek:o_O:ROFLMAO::ROFLMAO:
  16. NutzAboutBolts
    1,752
    1,780
    Bay Area
    :ROFLMAO: Yeah I had loud engine noise and lack of power as if it was the time my inverter IPM failed on me.
    Glad this was a minor set back, I thought it was going to be too much fipg applied on the timing cover and some how the fipg got dislodged into the oil passages, that would’ve been bad.
    Overall this took me 1 hr to fix. Didn’t have to remove a lot to remove the valve cover. (y)
    ASRDogman likes this.
  17. Mendel Leisk
    42,004
    Comparable to forgetting the oil fill cap? Harder to fix though. Don't ask how I know about that.
  18. NutzAboutBolts
    1,752
    1,780
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO: Hopefully there wasn’t any major damage to your engine bay :whistle:
  19. ASRDogman
    7,883
    4,012
    No damage to mine.... No oil leaks, except the rings... :whistle:
  20. Mendel Leisk
    42,004
    This was with an Accord; it survived. I make a point to always put the filler cap at the hood latch now, where it’s more visible and prevents hood from latching. :unsure:
