Super deep-cleaned EGR cooler: Odd! Is this normal?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by franksrental, Jan 11, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    7,843
    3,994
    It will depend on how bad it is.
    My pressure washer cleared out my spare cooler. But the oven CLEANER actually
    CLEANED it. It was not really clogged.
    My original one was clogged when I took it off. Took a few times to clear it out.
    But after the initial clearing/cleaning, it's been easy to clear/clean it.
  2. franksrental
    franksrental Junior Member
    29
    usa
    SOLVED!!!
    THANK YOU RJ AND THANK YOU EVERYONE!
    OK I SUCCEEDED and I see the light through all the holes!!!
    What worked?
    16 gauge closet wire you can buy at Lowes 200 feet for $7, . Rotated by my Ryobi drill at slow speed.
    Please notice that HOURS SPENT with carburator cleaner, parts cleaner, soaking in purple cleaner, WASTE OF TIME. You gotta start with the 16 gauge closet wire. Unless your EGR is barely dirty...carbon+oil make a barrier that cannot be pierced by regular cleaner. Lye? Maybe but I it's coming in the mail on Wednesday so I won't know. Meantime Houston we have a solution. Once the holes are exposed, ONCE THE HOLES ARE EXPOSED, ONCE THE HOLES ARE EXPOSED, THEN, you can use carb cleaner or what not. OTHERWISE WASTED TIME...
  3. ASRDogman
    7,843
    3,994
    It is important to give ALL information at the begining... So you can get the best answers.
    Doing a search on prius chat about egr cooler cleaning would have brought up all the answers.
    Most stores have drain cleaner.....
  4. franksrental
    29
    usa
    ASRDM good point, sorry I wanted to make a shorter post. Anyway you are saying that soaking in drain cleaner would have worked without sticking the wire in the holes?
  5. ASRDogman
    7,843
    3,994
    I'm not saying that....
    Each cooler is different. There are different methodes to use.
    Since YOURS was a spare, you could have let it sit and soak for weeks if you wanted too.
    There was no hurry to clean it, from my understanding.
    Some need to use a wire in a drill to clear the passages, I didn't.
    My main point was to give all information up front. You made it sound like you needed
    to clean out the cooler fast because you needed it to get the car running.
    It's like telling the doctor you hurt. And the doctor has to try to figure out where and why.
    And says take 2 aspirins and call me in the morning.
    And the next day you finally say, your leg. And it started after you got stabbed with a knife...
    :eek::eek::eek:(y):whistle:
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Really clogged EGR coolers (rock hard carbon, and oily goop) usually require busting through the channels with the wire so that any cleaners can get into the channels to do their thing.
    Tip, after using lye, oven cleaner, flushing with near boiling hot water is most effective. In soap making, lye plus oil makes soap. In the EGR cooler cleaning, lye plus oily deposits converts the oils and grease into soap-like stuff that can be dissolved more easily with the hot water.
    Edit: This is why most drain cleaners tell you to pour very hot water down the drain after treatment with the sodium hydroxide in the cleaner.
    SM-G781V ?
    #26 xliderider, Jan 12, 2025
    franksrental and Prodigyplace like this.
  7. Mendel Leisk
    41,942
    I can’t see the EGR cooler being very oily though. It’s fed by exhaust, I think only dry carbon in that.
  8. xliderider
    8,140
    3,277
    Honolulu, HI
    The residue in the EGR pipe coming out of the cooler and before the intake manifold was pretty oily.
    SM-G781V ?
    franksrental and Mendel Leisk like this.
  9. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    I disagree, provide vague and non detail descriptions makes it funnier for us to throw out random guesses.
    franksrental likes this.
  10. Mendel Leisk
    41,942
    An update: we had a bottle of “lye” crystals, an Amazon purchase for a soap making project (which so far hasn’t happened), that turned out to not be lye (sodium hydroxide, NaOH), was in fact this:
    (Caustic Potash, Potassium hydroxide, KOH)
    Which after my initial dismay, with a little reading, I see is similar in efficacy, even more caustic, easier to dissolve in water as well.
    I had the EGR pipe out a few days back (cleaning oil catch cans, throttle body, PCV valve and intake manifold), so thought I’d try the pipe with KOH solution. Even at just 10% by weight solution, quite effective after about a minute:
    I think 20~30% would even more effective. 40% is approaching saturated, fwiw.
    Again, read up on this stuff, it’s strongly caustic, handle with care and take appropriate safety precautions.
  11. rjparker
    10,575
    6,633
    Dang, all this time lying about lye.
  12. Mendel Leisk
    41,942
    Lye will work as well, if you can find it.
    BTW, are you having a rough day or something?
