Air condition getting the family sick?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius2010owner, Apr 8, 2026 at 5:21 PM.
  1. Prius2010owner
    Prius2010owner Junior Member
    LA
    Wife thinks the air condition is getting the family sick when used.
    I think otherwise, Since I use my car all the time and never have any issues.
    What are possible steps to eliminate any doubt that the air condition system is fine?
    I bought a 2pack air filter from amazon, and have 1 left. But I want to get the most high end hardcore filter available on the market or maybe the OEM filter from toyota? Need suggestions.
    Also read something about maybe the evaporator line isn't functioning properly? How could I tell?
    Any other suggestions?
  2. Mendel Leisk
    41,939
    Any odd smells?
    Water vapour can condense and start growing stuff in there.
  3. frodoz737
    frodoz737 Top Wrench
    4,727
    2,518
    33
    Why does she think this?
  4. Prius2010owner
    LA
    I just ran the AC in my car in my drive way for 20 minutes, and water is indeed coming out the bottom perfectly fine. So I don't think it's a mold issue. I don't smell anything and can go on long drives and be perfectly fine. But the goal is eliminate all possible outcomes.
    She claims there is an odd smell, but she's also a hypochondriac. And trying to figure out why her and the rest of the family is constantly sick.
  5. VelvetFoot
    VelvetFoot Active Member
    1,239
    486
    New York State
    2026 Prius
    Maybe get a cabin air filter that has 'activated carbon impregnated' on the box. Spend a lot of money. Show her box and receipt?
    Hey, I remember when cigarettes with activated carbon filters were advertised on TV. :)
  6. Tombukt2
    13,483
    2,425
    Uh no just harder to pull air thru etc . . . She's talking bout startup smell. Really kinda ole wives tale. Yes they're a smell at start up. But not really related to mold . More of a mildew.
  7. PriusCamper
    PriusCamper Senior Member
    13,099
    5,309
    Pacific Northwest, USA
    She's smelling the moisture on the AC condendser... It's very subtle and only smells when there's moisture is present. When its dry it won't smell (when heater is on) and when AC has been on for a long time and condenser is mostly frozen it won't smell. So pre-cooling the car would help, as well as always keep the AC on, which is bad for MPG and might get too cold, unless you get the venting right.
    Also, buy the least expensive carbon impregnated cabin air filter and change it often...
    Also deep cleaning the interior of the car with the type of cleaner smell that your wife prefers. If that doesn't work get the interior professionally cleaned. If that doesn't work remove the vents and clean them and put some essential oil (that your wife likes the smell of) on the insides of them.
    If that doesn't work there's a foaming spray cleaner designed to spray on the AC condenser that's deep inside the dashboard, though access isn't easy, but I suspect there's threads on here about how to do it.
    I used condenser spray cleaner on my Travel Trailer AC condenser last year and it says it doesn't need to be rinsed after you spray it on, but I used my water pick that I use for my teeth on it and I suspect the rinse helped.
  8. rjparker
    10,574
    6,630
    Use an evaporator foam cleaner injected into the condensate drain. It is made to clear up mold. IMG_1082.jpeg IMG_1086.jpeg IMG_1085.jpeg
  9. bisco
    52,413
    consult with her doctor?
    CR94 likes this.
  10. Tombukt2
    13,483
    2,425
    Evap is inside part that gets cold .condenser is the outside part.in front of car .
    PriusCamper likes this.
  11. PriusCamper
    13,099
    5,309
    Thanks, I always get those reversed...
  12. rjparker
    10,574
    6,630
    The cold Evaporator absorbs heat and condenses water on its surface to reduce humidity in the cabin.
    In cooling mode, water condensation must be drained through a tube to outside.
    Heat pumps (plugin and evs) reverse coil functions in heat.
    Which is why most hvac techs now refer to "inside" and "outside" units, which is clear and independent of function.
    Mold and mildew can grow on the indoor coil and is removed with specialized coil cleaner foam described above. It is effective and does not require direct access to the indoor coil.
