Explain these battery codes for me
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bk2049, Apr 15, 2026.
  1. bk2049
    bk2049 Junior Member
    71
    Ohio
    Had P0A80 code and battery was replaced. Code came back shortly after the new battery was put in. I'm trying to figure out if the cause of the code was actually the battery or if something else triggered it. I have no idea how to interpret these readings. Can you guys tell me what these two pictures tell me about the batteries?
  2. Brian1954
    Brian1954 Senior Member
    2,476
    990
    South Central PA, USA
    The P0A80 code is caused by a problem with the hybrid battery. Where did you buy the "new" hybrid battery from and how much did you pay for it? I hope it came with a good warranty. How many miles on the car?
  3. PriusCamper
    PriusCamper Senior Member
    13,166
    5,323
    Pacific Northwest, USA
    Which battery did you replace? The 12v or the Hybrid Battery?
  4. ASRDogman
    ASRDogman Senior Member
    7,886
    4,013
    Was it a NEW battery pack, or refurbished? HUGE difference.
    Did you replace it, or have someone do it?
    Is it the Sodium Ion pack from Jack?
    Who diagnosed the issue? How did they do it? Where there other codes?
    Other issued can trigger that code and it not be the hybrid battery.
    Where all the codes cleared before and after replace the battery?
    Was/is the 12v battery FULLY charged?
  5. bk2049
    71
    Ohio
    Well over 200k on car. Greenbean. They installed. The middle option: Hybrid Battery Options for Prius 2010-2015 | Green Bean Battery. Yes warranty. Yes other codes were B1423 and B1498 (when engine was replaced 3-4 years ago, they somehow messed up the a/c, so it hasn't worked since) and C1259 and C1310 (not currently active, but were stored a month or so ago). TBH, the C codes now have me worrying about the inverter as the issue rather than the battery, which is why I'm asking.
    Where all the codes cleared before and after replace the battery? I am not sure. They did the replacement and I'm obviously pretty ignorant of these things.
    Was/is the 12v battery FULLY charged? Again, I'm not certain.
    What can you tell me about the battery readings? Are they bad enough to trigger the P0A80 code or is likely the inverter or something else?
  6. bk2049
    71
    Ohio
    Hybrid
  7. bk2049
    71
    Ohio
  8. bk2049
    71
    Ohio
    Sorry, ASRDogman. I think I replied to some of your questions in the wrong post, but I think I answered them above. Can you share any insight on the readings or the situation? Thank you.
  9. ASRDogman
    7,886
    4,013
    Which did you get? They have 3 options....
    I believe they've been burned enough with the used batteries, they are going with new.
    Sodium Ion is the best pack to get.
    Since they have a warranty, you should contact them and have them come fix it.
    The first photo everything looks fine, but the 2nd one looks like one sell is low.
    Are you sure you got a NEW pack????
    bk2049 likes this.
  10. Brian1954
    2,476
    990
    The C1259 and C1310 codes are not caused by the inverter, they are triggered when you get the P0A80 code.
    If the P0A80 code is a current/active code and not a historical or permanent code, it is time to start a warranty claim with Greenbean. If the code is current, the master warning light (red or orange triangle) will be on and the hybrid battery cooling fan will be running at maximum speed.
    Can you please post a picture of the scanner showing the P0A80 code?
    There is no unusual data show in the first Dr Prius screenshot. It appears that this was taken when the car was in ignition on mode (car not in Ready). The second screenshot looks like the car was in Ready mode and shows a Delta SOC of 33%, which is not good. This is telling you that the battery blocks are not balanced to each other. A healthy battery pack has a Delta SOC of 0%.
    #10 Brian1954, Apr 15, 2026
    bk2049 likes this.
  11. Brian1954
    2,476
    990
    Can you please tell me what other issues can cause a P0A80 code besides the hybrid battery assembly? Maybe I will learn something new today.
    #11 Brian1954, Apr 15, 2026
  12. bk2049
    71
    Ohio
    Thanks ASRDogman. I got the middle option- the one like the original battery. They are coming back out next week. I'm just concerned it's not the battery. When I talked to the tech on the phone he said of the many he's installed he's never had this happen with the new batteries. It's happened with the refurbished, but not new. Unless they are lying (which I don't suspect), the casing is old but the battery is new. That's another reason I'm asking about the scan-- to verify that it's a new battery pack.
  13. bk2049
    71
    Ohio
    Thanks, Brian1954. Yep. It's active. I have the triangle and "check hybrid system" message. I do have them coming back out next week. I just use a FIXD scanner. Here's a screenshot. Thanks for the scan interpretation. If the first shows the battery is fine, do you know why else the P0A80 code would still be active?
    Brian1954 likes this.
  14. Hayslayer
    Hayslayer Active Member
    487
    274
    Based on how many members think they know a lot more than they actually do, I'm guessing low tire pressure, a loose gas cap and low coolant can cause it, but only if the 12v battery is at 11.9 volts on the second Tuesday of the month...........
  15. ASRDogman
    7,886
    4,013
    fixd is likely incorrect.
    Before replacing the hybrid battery, a diagnoses should be done, saving the codes.
    And find out if the battery is actually bad. Many time a weak 12v battery can cause that P0A80 code.
    Because the 12v battery is not supplying enough power/amperage to power up what hybrid system needs
    to activate the hybrid system. A low voltage 12v battery has proven to be many times.
    Sadly, companies don't make money testing and finding only the 12v battery is week. There money
    is in replacing the hybrid battery.
    It's sad you have to wait a whole week! It shouldn't be more than a day.
    I do hope it's something simple for you.
    #15 ASRDogman, Apr 16, 2026
    bk2049 likes this.
  16. ChapmanF
    18,661
    There is a voltage difference between blocks of more than a third of a volt there between highest and lowest, likely the explanation of your P0A80 code.
    (Hey, I just noticed for the first time a typo in that page of the manual: it says there are eight cells in a module, but should say there are six.)
    The "12v battery is not supply enough power/amperage to power up what hybrid system needs to activate the hybrid system" kind of explanation for P0A80 is one that smacks of wishful thinking to me, the kind that can sometimes seem confirmed when the code is forgotten because the 12-volt battery was fussed with, and then doesn't return for a while.
    bk2049 and Brian1954 like this.
