Sluggish Acceleration and MPG Reduction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by EllenS2011, Apr 17, 2026 at 12:30 PM.
  1. EllenS2011
    EllenS2011 New Member
    Today
    Ohio
    I drive a 2015 Prius with about 125k miles on it. Oil is replaced every 5k miles, spark plugs/inverter coolant/transmission fluid/all air filters replaced 11 months ago. I've seen online that possible solutions may be EGR cleaning/replacement, battery fan cleaning, and/or battery replacement. Any other ideas or thoughts?
  2. JC91006
    JC91006 Senior Member
    16,844
    8,612
    Have you driven other Prius cars to compare?
    One thing that can help with a 2015 is you don't use the ECO setting on the drive selector. Use normal or power setting.
  3. BiomedO1
    4,261
    2,234
    Left Coast
    FWIW: Your better off having a very good mechanic run diagnostics on the car; than spending money on guesses from the peanut gallery. If this is your first time behind the wheel of that vintage hybrid - they're all pretty gutless. IMHO; they start driving more like a regular car in the gen4 and gen5 versions; but your still going to be left behind at a stop light by a 60's VW bug.......
    #3 BiomedO1, Apr 17, 2026 at 5:11 PM
