Sluggish Acceleration and MPG Reduction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by EllenS2011, Apr 17, 2026.
  1. EllenS2011
    EllenS2011 New Member
    Ohio
    I drive a 2015 Prius with about 125k miles on it. Oil is replaced every 5k miles, spark plugs/inverter coolant/transmission fluid/all air filters replaced 11 months ago. I've seen online that possible solutions may be EGR cleaning/replacement, battery fan cleaning, and/or battery replacement. Any other ideas or thoughts?
  2. JC91006
    16,876
    8,619
    Have you driven other Prius cars to compare?
    One thing that can help with a 2015 is you don't use the ECO setting on the drive selector. Use normal or power setting.
  3. BiomedO1
    BiomedO1 Senior Member
    4,374
    2,301
    Left Coast
    FWIW: Your better off having a very good mechanic run diagnostics on the car; than spending money on guesses from the peanut gallery. If this is your first time behind the wheel of that vintage hybrid - they're all pretty gutless. IMHO; they start driving more like a regular car in the gen4 and gen5 versions; but your still going to be left behind at a stop light by a 60's VW bug.......
    #3 BiomedO1, Apr 17, 2026
    52,558
    clean the throttle body. how many mpg's have you lost, and how are you measuring it?
    make sure all the wheels spin freely. how is the 12 volt health?
