Dreaded P0A80 Code - Car Running / Charging Good.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriuSocal, Jan 25, 2026.
  1. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    They were definitely giving out different readings even at static as mentioned above. depending where I placed the probe, it gave out different readings due to the heavy corrosion. Only way to get the proper reading was to probe the tip of the actual battery terminal and thats how I was able to get proper standing voltage readings. I cleaned the front bus bars (top) and haven't done the rear (bottom).
    I a should be getting the new busbar/nuts kit today or tomorrow and will install them and very confident readings will no longer variate. If there was variation in readings due to the corrosion at static, I can only imagine while under load and driving.
    As for the Prolong, I would love to have one of those kits but #1 they are too expensive new andI cannot find a used one at a good price. If you have one or know someone at a good price LMK.
    ASRDogman likes this.
  2. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Are you able to see the serial numbers while they are still on the car? Because, I am not removing the modules at this time. BTW, there is a clear vent tube that goes on the end attached to the long black tubes that is missing the tubing that goes into the back of the seat into the bottom of the car. I have read that latter gen 3 went away with that tube but want to confirm.
  3. ASRDogman
    ASRDogman Senior Member
    8,054
    4,083
    Of course cleaning each post is important also.
    Prolong is a lot less than a new battery, no matter which one you get.
    But, replacing it will mean you won't have to worry about the hybrid battery
    for many many years.
  4. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Agreed.
  5. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    Yes, the serial numbers are on the top of each module.
    PriuSocal likes this.
  6. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    ill check
  7. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I got the serial numbers. most of the cells have the first 9 alpha/digits the same and 3 are totally different numbers. Does that mean those have been replaced? I can tell someone has been in the battery before because some securing bolts are missing and the orange safety screw on top was also missing.
  8. Brian1954
    2,668
    1,066
    Yes, if three of the modules have completely different serial numbers, I would guess that they are replacements. Based on the pictures of the battery pack that you uploaded in post #112, I would guess that modules #14 and #16 are replacements.
    Can you please provide the serial number of one of the common serial numbers and the other three completely different serial numbers? What position are the three different serial numbers located at?
  9. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    13, 14 and 15 from right to left are the ones with the complete different serial numbers and they appear to be in the center
    The 3 different cells start with 152N which indicates a manufacture date of Feb/15/2012 All the other consistent ones are 086L which is a manufacture date of June/08/2010 which is obviously a replacement battery all together and the 3 cells probably replaced after. The similar serial numbered ones are all in sequential order other than the 3 different ones
    Brian1954 likes this.
  10. ASRDogman
    8,054
    4,083
    So most are 16 years old and a few are 14 years old. That's a good run.
    Start saving for the Sodium Ion Hybrid battery now.....
    You got a lot of life out of that pack. And depending on when those older ones were replaced,
    the newer ones are likely putting more stress on the older ones.
    I think they new bus bars will likely help. There is no telling how long the pack will last.
    So you need to decide on what to do next. Purchase the Prolong system and run the pack through
    the complete 4 charge 3 discharge cycles to refresh it and see how it extends the life of the pack.
    It extended mine for a few years. Allowed me to save up for a new one.
    Just remember, it will fail at the worst time.
  11. Brian1954
    2,668
    1,066
    Thank you for the information that I requested. Your 2015 Prius with 260k miles has a battery pack with twenty-five 2010 battery modules and three 2012 battery modules. Very interesting.
    Do you know how long the car sat unused before you bought it?
    IMO, replacing the corroded bus bars will make no difference. I am assuming that all the nuts were tight on the existing battery pack. If they were, the nuts and the flange on the battery terminals were making good contact to the bus bars. This can be seen in the pictures of the bus bars that you provided. There was no corrosion on the bus bar where the nuts was located at and on the other side of the bus bar where the battery terminal flange was located at. You see it all the time in this forum where somebody says that you need to clean the corrosion off the nuts and bus bars. As long as there was good contact between the nut, bus bar, and battery terminal flange, the corrosion, like seen in your battery pack pictures, does not affect the operation of the hybrid battery.
    #131 Brian1954, Apr 19, 2026
  12. rjparker
    11,048
    6,923
    Back in January it was clear the new to you Prius had a "repaired" battery, but it was missed other than "cleaned before" and missing fasteners (info provided later). A lack of knowledge on how to confirm this and a lack of trust lead to 7 pages and counting.
    It will be interesting to see if the bus bars will allow the Confirmation Driving Pattern to clear your permanent code.
    Honestly I hope it does. However, as Brian noted, a gas tight busbar connection usually keeps the voltage drop caused by a bus bar very low.
    As stated before, the Confirmation Driving Pattern stress tests your battery before allowing a code clear. If the battery is weak, it fails.
    If it fails, then its back to the most common issue, worn out modules. Which is expected from a battery that required used replacement modules sometime before it was sold.
    Confirmation Bias is a tough nut to crack for some people. A psychological roadblock unrelated to a Confirmation Driving Pattern.
  13. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I am def going to look into the prolong and try to find a used one for a good price. Is the deluxe kit really needed though? The one that comes with the square box and with electronic readings?
  14. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Yes, its is obvious now that the battery pack is not its original battery pack and was swapped out for an OEM used pack and then 3 modules replaced off that one. The car sat for over a year with just the occasional around the block drive by the prev owner.
    The nuts were tighter on some modules than others. I did read the busbars do burn out though hence the black underneath where the nut sits and that can also provide high resistance and false readings but putting it all back together will tell me more.
  15. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    [QUOTE="rjparker, post: 3606429, member: 41651"]Back in January it was clear the new to you Prius had a "repaired" battery, but it was missed other than "cleaned before" and missing fasteners (info provided later). A lack of knowledge on how to confirm this and a lack of trust lead to 7 pages and counting.
    .[/QUOTE]
    Not sure where it was “clear” to me that the HV battery was repaired anywhere in the last 7 pages as nothing like that is mentioned. You may be confusing it for the 12v battery that I do mention it was replaced and mentioned the HV battery could be original or replacement and service unknown.
    Anyhow, I will be taking another crack at the CDP after the bar replacements if there is no other way to stress the system enough to either clear the permanent code or remain.
  16. Brian1954
    2,668
    1,066
    This is important information that I do not remember reading in any of your previous posts. This could explain some of the codes you reported in post #1 and why the hybrid battery was in poor health, which triggered the P0A80 code. Reconditioning of the hybrid battery should be beneficial. Read the information on Hybrid Automotive's website. You can make your own grid charger and discharger, which would be much cheaper than buying the Prolong system. I sold my used Prolong Deluxe system on eBay back in March. https://priuschat.com/index.php?posts/3599675
  17. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I will look into that info. It would be cool to make my own grid charge/discharger. Is that info on Hybrid Automotive’s site?
    Will also continue to look for a Prolong lol
  18. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I did the voltage drop test using a the following video setup. I used a Philips 9006 Halogen bulb that appears to have a initial draw of 6 or 7 amps and the load test was for 2 minutes total.
    Here are the readings I took. Keep in mind, the 1st column shows the voltage at static before testing and once i immediately hooked up the leads and bulb came on, the reading started 0.6-0.7 volts lower than initial static reading. Last column shows total voltage drop after load test
    My next step after this test is to replace the busbars/nuts and drive the car for a few days and then redo the load test using same steps above and go from there.
    #138 PriuSocal, Apr 19, 2026
  19. Brian1954
    2,668
    1,066
    No, Hybrid Automotive manufactures the Prolong chargers and dischargers.
    There are a few different threads for making your own charger. This is one of them
    https://priuschat.com/index.php?posts/3135066 Do a search and you will find more.
  20. ASRDogman
    8,054
    4,083
    I believe you're suppose to fully charge the pack before doing that test, to get an accurate reading.
    But you have some idea.
    There are different models of dischargers for Prolong, 1 for charging. Make sure you get the one
    for the 3rd Generation Prius. Discharger I have has 3 setting. Each one discharges deeper.
    The other one uses light bulbs. You need 3 different wattages of incandenscent bulbs. And you have
    to watch it.
