Hello from a CT Owner with Issues
Discussion in 'Newbie Forum' started by SB-CT, Apr 19, 2026.
  1. SB-CT
    SB-CT New Member
    UK
    Hello Forum, signed up as most of the useful information online to do with the Toyota Hybrid system came from this site.
    I own a Lexus CT200 (2017 model, middle facelift). Based in the UK. 96,000 miles on it.
    I'm here for help for a very specific C1202 fault. It's intermittent on and off for the last two months.
    Last year I had the brake booster replaced at the Toyota dealership I bought it from. 50 weeks of zero issues so I suspect that new part was fine and fitted fine. Unfortunately they closed their door on me when I took it back and said as the warranty which the job was done under ended last summer, so did their warranty on that work...
    Unlike when the brake booster went, when my fault this time is ON, I lose ABS / traction and the brake feels like it takes more effort. But cruise control still works as does regen braking so I suspect speed sensors are fine.
    C1202 says brake reservoir malfunction. But the fluid is and remains at the high / correct level.
    Took it to Lexus, that day the fault was NOT on (typical) but still wanted them to check it out. They followed the procedure and said they looked over the system, cables etc and said no issue found, advised me to take out my Nextbase dash cam (new one which can only be powered via the OBD port). I am not convinced that is related.
    The issue has been on and off since. I suspect it's moisture / water related but then yesterday was a hot day and it was on most of the day so even that doesn't check out completely.
    I checked the voltages on the pins, cleaned them out with contract spray and high pressure air to dry them. Voltage / resistance stuff was as expected.
    I'm at a total loss on what to do, or how to further troubleshoot. Though I am not overly familiar with circuit diagrams or electric troubleshooting I do most of my own work (servicing and part repairs when needed) to my cars except bodywork and tyres. So I'd like to give it a try, but my knowledge of hybrid specific stuff is not deep.
    I have had a good search of the forums on here with people troubleshooting C1202 but many of the threads they either have a worse issue such as more brake booster codes and then the threads just stop with not always a solution.
    Can anyone help? Very, VERY grateful for your help. If the forum supports donations and I somehow get this fixed for like say a month straight, would make a big donation!!!
    Alexmercy and bisco like this.
    52,492
    welcome!
    I can't help, but I am curious. have you tried disconnecting the dash cam to see if the light stays off?
    I'm not saying that's the issue, but obd connections do occasionally cause false codes.
    all the best!
    Alexmercy and SB-CT like this.
  3. SB-CT
    SB-CT New Member
    UK
    Thanks for your reply @bisco. I have not tried that for long but Lexus did say that it could be interfering although I’ve had that since last July and the issues didn’t begin until February.
    I held my iPhone under the reservoir yesterday and watched from my Apple Watch live as I pointed it around places I couldn’t see.
    I found something bloody amazing in terms of a breakthrough. The bottom of my reservoir has exposed metal wires which show surface corrosion. They are missing the black plastic protection altogether. I have no idea how this finish could fail other than being exposed to fire level heat or being scraped off by hand. See my photos.
    I found on eBay that nearly every example of this part from way older CTs have the black protective layer in tact. This is surely why mine works - thick metal in tact capable of passing a signal when dry and then when wet or humid, causing the fault light and C1202.
    this is a new one for future owners of all these 3rd gen systems to check?
    I have emailed Lexus as I have that ‘relax warranty’. Perhaps if they agree this is a material failure they can repair it without cost to me other than their second inspection of the issue which should be easy as I have shown them these photos.
    if not… I believe from reading on here Toyota and Lexus dealers would NOT replace just this part if we asked them to and that they’d force the entire brake booster system. If that’s the case, I wonder why Toyota who replaced it last year did not replace this as well? Or… when they worked with the system why did they not notice this? If Lexus do not sort it, in fact, even if they do, I may approach the Toyota dealer and ask for an investigation. They weren’t interested when 50 weeks later this issue occurred as they said it was no longer warranted by them since my used car warranty had expired and that’s what their job was covered by in Feb 25.
    Do you know if that is a Toyota policy that this must be replaced as a full system or just a dealer choice to do so, as when they inevitably try to tell me it wasn’t needed at the time, I would like recourse to Toyota and the warranty company who were likely paying out for this piece for it to not end up in my car. Etc.
  4. bisco
    52,492
    I'm afraid idk what Toyota policy is. do you have a customer service number you can call? I always thought Lexus dealers were much better about these things than Toyota dealers.
    Alexmercy likes this.
  5. SB-CT
    SB-CT New Member
    UK
    Screenshot 2026-04-20 at 20.55.19.png Screenshot 2026-04-20 at 20.55.46.png Screenshot 2026-04-20 at 20.55.50.png
    Spoke to Lexus today. They reckon the protective coating on my reservoir cable is fine. Upon further inspection today.. I agree.
    I joint the pins on the car end of the connection to the reservoir tank with a paper clip to simulate a ‘good connection’ since it’s a simple float switch and when connected, should give in theory solve my fault lights. Nope - no difference. Suggests the reservoir tank itself maybe fine.
    my next course of action tomorrow is to check both ends of the PINK wire from the reservoir tank (car side of the cable) and the other end of it. It leads to the ‘skid control ECU’, pin 36 on my UK RHD car. To see if there is resistance or an ‘open’ in the circuit. I hope I’m using the right terms here.
    if so, I can bypass it for a while and see if the system can go a few weeks without issue. Then… I’ll dig into the actual loom and fix the wire properly and reseal it all up.
    If not.. Lexus can decide whether to replace the skid control ECU or the reservoir as these are both covered under the ‘Relax’ warranty. They told me wire loom repairs will NOT be covered unless they are connected to the part itself (e.g. how the reservoir has its wire seemingly glued into its bottom. But not the loom it plugs into).
    this is all going by the diagrams I found on the leaked Tech Doc system from the CT forum. I presume you guys have something similar for the Prius. If not worth grabbing a copy as I think it’s basically a 3rd gen system and identical :)
  6. Mendel Leisk
    42,015
    I’d try disconnecting your obd powered camera and having codes dismissed, system reset by dealership.
    I had increasing frequent brake anomalies, multiple warning lights on dash coupled with odd brake feel:
    Hybrid System Warning and multiple other lights | PriusChat
    dealership mechanic had Techstream laptop connected, noted the obd connection kept breaking, suggested I disconnect my ScanGauge II. I did this, and no further issues.
    bisco, Alexmercy and SB-CT like this.
  7. SB-CT
    SB-CT New Member
    UK
    Thanks for the reply. The dealership did say this in March when I took it down for my intermittent fault but the lights went off that day. But the camera was in since last June and no issues until now. I also replaced the battery with a brand new Yuasa same part as from factory.
    I can give it a try but today I dropped the car off with Lexus. Hopefully they find the issue and that it’s coverable by the Relax Warranty.
    my intermittent C1202 disappeared yesterday evening as we tested it. All wires were fine but we found a voltage from the pink signal wire of the reservoir was giving near 14 volts not the 4-7 the TechDoc system stated.
    I then found an engine light (P0010), a C1466 which for a while was on with the C1202. I suspect the P code was my messing with wires and trying to find and clean grounding points which had me disconnect the 12v and the HV system (to be safe). I don’t believe I broke or strained anything with all my searching.
    I’m really not sure what’s going on with it. Even my C1202 as we followed the various grounding and continuity checks, at some stage went off leaving just the rear right wheel code I mentioned above - same dash lights / lack of brake assist. So that pink signal wire test fail might mean nothing.
    i will post updates. Gave them up to a week with it and up to three diagnostic hours before I want to approve any more.
    ironically… I saw this ad as I walked from the dealer to the bus stop to go home.
    bisco and Mendel Leisk like this.
  8. SB-CT
    SB-CT New Member
    UK
    Hello again PC forum, thought I’d keep this updated so future owners with the same electrical gremlins know what the ultimate outcome was. There were a lot of great threads on here similar to my issue, but many of them just went silent with no final outcome. Hopefully those owners got a good result, but we will never know!
    The car is at the dealership as of last Wednesday - giving them time to see the issues personally not just a photo of my codes. They were staying on constantly as per my last update.
    They discovered a rear wheel ABS sensor wire hanging on by a thread of copper, barely making contact. This was from the troubleshooting of code C1466. As I had mentioned, mid troubleshooting last Tuesday by myself, by the end up the C1202 was gone and only the C1466 was there. Perhaps this is some root fault and was leading to a coverup fault up the chain from some odd signalling being received by the skid control ECU, making the reservoir circuit appear to be broken. They have ordered and are replacing this and we hope the brake system will behave. Otherwise, further diagnostics if the C1202 comes back - or whichever code, should the four brake horsemen make their presence known on the dash. The sensor wiring makes sense as it seemingly was not so much 'only' wet or dry, or hot or cold, but humidity and then after 30 mins of driving, proper heat / dryness expanding the copper on that wire and allowing it to work for periods at a time, then boom, faults. It does line up. Covered under warranty.
    The P0010 is being covered by warranty too. Camshaft position sensor. I was worried that this was something I caused from investigating the C1202 but sensor is now ordered and will be fitted.
    1.45 hours of diagnostic time. I authorised a little more in case it's needed following the part fitting. I think if future issues still persist along the same systems the warranty has it covered.
    I really hope this gets the CT back to reliable over the long term. If not for the warranty, I suppose I'd have tried a used reservoir, and then went on to the speed sensor testing - possibly a rear brake job. From that I'd like to think I'd have spotted the wire in bad shape and repaired the loom... that's if the warranty didn't apply. I'm so glad I got that last service to trigger the 'Relax' warranty - do you guys have that in your country from Toyota? On a nearly 10 year old car with 96,000 miles... I must say, that's one hell of a way to treat customers :)
  9. SB-CT
    SB-CT New Member
    UK
    Does anybody here have any thoughts on whether the ABS wire with its loose connection might have caused the C1202? I will keep reading the forum but I wonder how likely one bad input can wreak havoc on the rest of the system. I’d like to believe this but I lack the experience with this 3rd gen hybrid system :)
