New to me 2017 Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by PHEVisthefuture, Apr 26, 2026.
  1. PHEVisthefuture
    PHEVisthefuture Junior Member
    77
    Illinois
    Just purchased a new (to me) 2017 Prius Prime and loving it so far! Even with a 1 hour commute to work and 1 hour back, with no charging, I’m averaging 80.5 MPG!
    This car is fun to drive (and I’ve had some fun cars and trucks) and perfect for a long distance road trip for 4.
    Since I’m new to Toyota’s design philosophy - Previous PHEV was a 2012 Volt Premium - does the Prime charge the 12V battery from the HV battery when parked and ignition on?
    Reason being, my old Volt was great for live sound, power for your booth at an art fair, or DJing for up to 5-6 hours with an inverter. Just hook it up to the 12V, leave the car in “Ready” with all accessories (radio, fan, and headlights) off, and it would power a decent sized booth or DJ set for hours.
    Would doing the same on the Prius Prime leave me with a dead 12V battery? Or do I have to have the wheels moving for the HV battery to charge the 12V battery?
    Below is a pic of my Prius charging, what a great car!
    Alex
    52,694
    congrats and welcome!
    yes, as long as the car is 'ready', it's charging the 12 volt from the hybrid battery through the inverter.
    when the hybrid battery gets too low, the engine will come on and off to keep it at a minimal state of charge.
    all the best!
    PHEVisthefuture likes this.
  3. PHEVisthefuture
    77
    Illinois
    Awesome bisco, and thanks for the quick reply!
    That is great to hear and I'm so glad I can drive around in HV mode, keeping the hybrid battery at a full SoC, and run a movie night or art fair booth without any issues.
    Attached is a picture of the biggest PA I've run off my Volt - driven off a 2,000W DeWalt inverter. Didn't have a single issue, although I had to keep levels down to avoid drawing more than the Volt's DC to DC converter could supply.
    I do concert promotion on the side, and it's kind of funny seeing a big stage & music thumping for hours and it's being powered by a hybrid battery... definitely gets a lot of people going "I couldn't believe THAT sound came from THAT little car!"
  4. PriusCamper
    PriusCamper Senior Member
    13,337
    5,395
    Pacific Northwest, USA
    Welcome to PriusChat... Congrats on a great purchase! How much is a 2017 Plugin usually selling for in your region these days and did you have to pay more or less that that? Am thinking with gas prices so high, the value of used Prius will likely go up.
  5. PHEVisthefuture
    77
    Illinois
    I paid approx. $16,000 but after taxes, title, paperwork, etc. it was closer to $17,500. A lot more than my 2012 Volt with similar mileage; however, that Volt required a $10k battery pack right after the 8/100 warranty expired (literally shortly after I bought it) so this time, I was willing to pay a little more for a Prius with a HV battery in good condition.
    I too think the prices of these things are going up - prior to the gas shortage, these were a few grand cheaper in my area (Illinois).
  6. PHEVisthefuture
    77
    Illinois
    Thanks everyone for the warm welcome! I plan to keep this car a very long time since it's my daily driver and commuter. Since I don't really know the maintenance history of this car, would the general consensus be to flush & replace all fluids? Or just replace as needed?
    Doing my research, it looks like the eCVT doesn't have a torque converter so the A/T fluid isn't being used to transmit power, but just lube and cool the internal components. Feel free to correct me if I'm wrong, as every other used car I changed the A/T fluid and by doing so, some ate the transmission shortly after (oftentimes, in the worst place, like a drive-thru or in the middle of nowhere) so I'm hesitant to do A/T fluid flushes and coolant flushes on used cars anymore.
    For oil, since I do a lot of highway miles, I plan to do a Blackstone analysis and see what's a good OCI as I have no idea what oil was used by the used car dealer nor if they replaced the filter.
    Any other suggestions or tips for a trouble-free ownership experience I am all ears - I've already cleaned the HV battery air intake and top off or check the oil regularly!
  7. PriusCamper
    13,337
    5,395
    Yep... out here on the west coast where used hybrid car prices are higher $17K is what I helped a friend pay for a 2017 plugin back in 2022 just before the prices went soaring super high. Currently a 2017 plugin out here is closer to $20K than $17K.
  8. BiomedO1
    4,444
    2,341
    Left Coast
    I would encourage an ATF change every 80K miles with Toyota WS fluid. Flushes are NOT recommended; just a simple drain-n-fill around 3.8 quarts. The OEM factory manual doesn't recommend flushing anything; just drain and fill. This is a planetary gear style transmission; so your mainly dumping out old worn out fluid along with any debris that has accumulated over those 80K miles. Toyota claims it to be a lifetime fluid; if you believe in such fairy tales..... Fluids are vulnerable to thermal and chemical break-down over time.
    Just a word or caution; check your coolant levels periodically - There's a TSB out on leaky exhaust gas heat exchanger for your year and model.
    FWIW; the DC-DC converter maxes out at around 1000W; so watch how far you push the 12V system...
  9. PHEVisthefuture
    77
    Illinois
    Thanks! I'll definitely keep an eye on the exhaust gas heat exchanger and coolant loss, looking at my Carfax it looks like this hasn't been replaced on my 2017 Prime yet.
    Appreciate the heads up on the DC-DC converter too, my 2000W DeWalt interver really pulls under 1,000W RMS, so I should be good, but will look into a nice inline fuse for safety. So far I've had zero issues on the original (2017!) 12V battery, so things are looking good with this used car.
  10. bisco
    52,694
    how many miles on her?
  11. PHEVisthefuture
    77
    Illinois
    I have only 100,000 miles, and say "only" because this was a highway car. Aside from the front hood and bumper being full of rock chips, there are no other (detectable) issues with the car.
  12. bisco
    52,694
    I think 120k is the first big service. there should be an online maintenance schedule
  13. PHEVisthefuture
    77
    Illinois
    Thanks, I plan to do a bunch of the work myself. Just purchased a transmission fluid pump, need to get some spark plug sockets & angled 3/8" drive extensions, coolant test strips, and fluids/filters.
    Looking to send in at least the oil to Blackstone to ensure the 10k oil change interval is working for me (2,000 miles per month). I don't know what the used car dealer filled her up with, at least Blackstone will tell if things are running normally.
    Appreciate the post from @Biomed01 regarding the leaky exhaust gas heat exchanger, I haven't experienced that yet, and (per my Carfax) it doesn't look like the exhaust gas heat exchanger was ever touched. All I have are oil changes, tires at 88k, brakes at 98k, and that's it (if Carfax is even accurate).
  14. bisco
    52,694
    caution where you buy parts. there are tons of cheap counterfeit Chinese parts out there that cause issues shortly after installing.
    online Toyota dealers are your best bet in most cases
  15. sylvaing
    sylvaing Senior Member
    1,213
    514
    There is a magnet in the transmission case that is not accessible (too bad it's not mounted on the end of the drain bolt) so even if you drain and refill the transmission, you won't flush any metal shaving as they'll stay stuck to that magnet. Because of that, I think changing the transmission fluid is a waste in the Prius and Toyota is right saying it's lifetime fluid (and not just for the life of the warranty). Like mentioned, having no torque converter, it's not "working" as hard as in a traditional transmission. Beside steel, the only thing you'll have in that transmission is the motor winding which are coated copper wires and if you get some of that coating in the transmission fluid, you have a much bigger problem on your hand lol.
  16. BiomedO1
    4,444
    2,341
    Left Coast
    Magnets only attract Fe. What about chemical break-down from heat cycling and dirt that grinds on wear surfaces??????
    You've got two giant permanent magnets in those two electric motors too.o_O Throw some magnets in your motor oil pan and you won't have to change your motor oil too.:cry::whistle:
    Your car your problem; do whatever you want......
