Does the Prius have an engine brake?
Discussion in 'Gen 3 Prius Main Forum' started by Paul Gregory, Apr 27, 2026 at 12:28 AM.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,696
    1,400
    I didn't know you could double clutch the Prius.
    It could give me 3 down-hill options and do so without having to ride pedals, which is to me one of the main points of having an engine or regenerative brake option that doesn't involve a pedal. Like, if I'm going to have to ride a pedal to get the right amount of engine or regenerative braking, then what's the point of the B mode? Just incorporate the extra regen in one-pedal braking, which I hate. And yes, I've driven an F 150 Lightning with one-pedal braking and I hate it.
    Powerglides.
  2. ChapmanF
    18,661
    On the way to becoming "full", the battery first passes a state of charge in the mid-70% range, where the car first begins increasing engine braking while decreasing charging current. That balance proceeds to all engine braking and no charging current at a state of charge of 80%.
    Readers interested in the details can find them here: How much engine braking a gen 3 is capable of | PriusChat
    ... and that it gradually replaces regen over the mid-70s to 80% SoC range as the engineers programmed it to, with no special action needed from you, the driver.
    What does 'prove' that the car behaves as the linked thread describes is not some absence of experience, but easily demonstrated repeatable experience.
  3. rjparker
    10,636
    6,663
    We have been down this road before with the same passengers.
  4. bisco
    52,479
    that's why I bailed out and turned on the ballgame. sox 5, jays 0
