Rough/pulsing engine & Check Hybrid System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fit Yz, Apr 28, 2026 at 11:56 PM.
  1. Fit Yz
    Fit Yz New Member
    Yesterday
    I've been working on this for about 6 months and out of ideas.
    I have a 2010 Prius with around 170,000 miles. Near the end of 2025, the engine started running rough with a pulsing/surging sound and threw a check engine light. I had it scanned at O’Reilly and was told it was related to the EGR system, but I no longer have the exact codes (I can try to track them down if that’s important).
    Over the next few weeks, I removed and cleaned the EGR valve and cooler, cleaned the intake manifold (there was oil pooled inside), and replaced the PCV valve. After putting everything back together, the car ran a bit better but still didn’t sound quite right. The check engine light did not come back at that time.
    In January, I took it on about a 2 hour highway drive. By the end of the trip, the engine started making a pulsing/surging sound again. After letting the car sit for a couple of hours, I started it again and it ran extremely rough right when the engine kicked on. I got the red triangle warning and a "Check Hybrid System" warning, and the car basically died and would not accelerated. I shut it off, restarted it, and was able to limp it to a safe place to park and eventually get it towed home.
    I took it to a local mechanic (not a Toyota dealer). After diagnosing it, he said the hybrid battery needed to be replaced and believed that would fix the rough running and may have actually been the original cause that threw the EGR related codes as the battery was likely failing at that time. He also inspected the cylinders with a camera and said he didn’t see signs of a head gasket issue.
    Since a new OEM battery was quoted to my by my local Toyota dealer at ~$5,500, I decided to try recondition the battery myself. I cycled all the modules multiple times through discharge/charge cycles (up to about 20 cycles) with the goal of getting >5 aH consistently per module. From what I found, “healthy” modules should be >5 aH, but most of mine wouldn’t reach that. I aimed for at least ~4.5 aH per module because replacement modules on eBay weren't advertised to be any better, then balanced the pack and reassembled it based on each modules best performance (all data below).
    After reinstalling the battery, the car seemed to run better at first on a 5 mile drive but I could still hear a pulsing/surging engine. The next day, within a 10th of a mile, I again got the “Check Hybrid System” warning along with a check engine light. I don’t have an OBD2 scanner and it’s difficult to get the car somewhere for another scan.
    I’m trying to figure out whether this really is still a hybrid battery issue or if something else is causing the rough/pulsing engine. Does this sound like a battery problem, or should I be looking at something else, or even a head gasket despite what the mechanic said? Did I recondition the battery incorrectly or incompletely? Did I rebuild the battery packs incorrectly?
    Bottomline, what should be my next step?
    Below is a csv of all my data from the battery reconditioning as well as how I rebuilt the pack.
    Code:
    Module,Pre-reconditioning Voltage (oc),Discharge 1,Charge 1,Discharge 2,Charge 2,Discharge 3,Charge 3,Discharge 4,Charge 4,Discharge 5,Charge 5,Discharge 6,Charge 6,Discharge 7,Charge 7,Discharge 8,Charge 8,Discharge 9,Charge 9,Discharge 10,Charge 10,Discharge 11,Charge 11,Discharge 12,Charge 12,Discharge 13,Charge 13,Discharge 14,Charge 14,Discharge 15,Charge 15,Discharge 16,Charge 16,Discharge 17,Charge 17,Discharge 18,Charge 18,Discharge 19,Charge 19,Discharge 20,Charge 20
    1,7.95,3295,5042,3286,6500,3572,6500,4334,6500,4260,6500,4505,7000,4766,7000,4742,6500,4885,6500,3932,6500,4841,6500,4911,6500,5191,6500,4894,6501,5112,6500,4884,6172,4780,6500,5033,6500,5090,6500,,
    2,7.96,3547,6500,3826,6500,4048,6500,4152,6500,4090,6500,4547,6500,3495,4982,4140,6500,4599,6501,2595,6501,4460,6500,4514,6500,4742,6500,4580,6500,4533,6500,4606,5450,4391,6500,4488,6500,4836,6500,4686,6500
    3,7.95,1422,5578,2671,6440,3139,6478,3565,5611,3775,5926,3841,6500,3308,7000,4516,7000,3453,6500,4896,6500,4520,6500,4981,6500,5012,6500,4636,6500,5081,6501,4873,6500,4765,6500,4791,6500,4958,6500,4882,6501
    4,7.97,1933,6010,2935,6500,3396,6500,3629,6500,3497,6500,3898,6500,3386,7000,4471,7000,4481,7000,4442,7000,4437,7000,4234,7000,4905,7000,4736,6500,4925,6500,5069,6500,4146,6500,2444,6500,4913,6501,4980,5396
    5,7.95,1821,4360,2844,4460,3101,6500,3960,6096,4181,6500,4233,6500,3743,7000,4568,7000,3836,6166,4790,6500,4708,4544,4017,6501,4741,6500,4773,6501,5027,6500,4896,6500,5125,6500,,,4874,6500,4812,6500
    6,7.94,1222,5614,2645,6500,3188,5708,3373,5355,3540,6500,3816,6500,3396,7000,3923,7000,3792,7000,4213,7000,4556,7000,3834,6501,5092,3606,3175,6501,4894,6500,4830,5745,4660,6500,5222,6500,4867,6500,5113,6501
    7,7.94,1411,5220,2772,6248,3312,4950,3466,5487,3796,6500,3866,6500,4690,6500,4793,6500,4878,6500,4745,5588,4597,6500,4971,6500,4643,6500,4771,6501,4867,6501,1748,6500,4896,6500,5125,6500,4874,6500,4812,6500
    8,7.94,2379,5139,2748,5551,2904,5457,3060,5711,3208,5734,3228,5968,3222,6089,3541,6152,3651,6423,4258,6310,3212,7000,4437,7000,4457,7000,3945,6500,4639,6500,4774,5961,4858,6500,4894,6501,4919,6501,5127,6500
    9,7.97,2374,5653,3277,5816,3632,6370,3993,6500,3935,6500,4295,6500,3531,7000,4369,7000,4603,7000,4070,6501,4924,6500,4881,6500,4763,6501,4782,6500,4966,6500,4908,6500,4911,6500,4989,6500,4993,6500,4763,6501
    10,7.96,3201,6500,4219,6500,4156,6500,4186,6500,4692,6500,4349,6500,3698,7000,4745,7000,4621,7000,4841,6500,4825,6500,4535,6500,4633,6500,4708,6500,4908,6501,4710,6500,4907,6500,4732,6500,4693,6500,4905,6501
    11,7.94,1547,4794,2370,5183,2809,5508,3155,6107,3475,6215,3695,6500,3231,6500,4164,6500,4313,7000,4191,7000,4423,7000,4441,7000,4681,6500,3934,6214,4926,6500,4709,6500,5058,6501,4872,6500,4739,6500,4738,6500
    12,7.94,1278,4541,2589,5550,3170,6090,3545,6500,3570,6500,3874,6500,3288,6500,4136,7000,4110,7000,4266,7000,4235,7000,4258,7000,4665,7000,4896,6500,5013,6500,4311,6398,4979,6500,5134,6500,5128,6500,,
    13,7.95,1331,5074,2766,6217,3376,6500,3912,6500,3946,6500,3966,6500,3828,6930,4848,7000,4833,7000,3674,6500,4680,6501,4646,6500,4898,6501,4719,6500,4688,6501,4812,6500,4687,6500,4737,6501,4822,6500,4759,6501
    14,7.98,3168,6500,4298,6500,4332,6500,4436,6500,4611,6500,4631,6500,3521,6500,4762,6501,4612,6500,4905,6500,4669,6500,4603,6501,4901,6500,4940,6500,4645,6500,4630,6501,4450,6500,4486,6500,5034,5512,4484,6500
    15,7.94,2474,6083,3405,6500,3843,6500,4954,6500,4986,6500,5545,7000,3890,6500,5021,6313,5123,6500,,,,,,,,,,,,,,,,,,,,,,
    16,7.94,2246,4482,2986,5482,3482,6196,3964,6500,4486,6500,4250,6500,3595,7000,4792,7000,4123,6500,4864,5979,4917,6026,4734,6500,4892,6500,5117,6501,5019,6500,,,,,,,,,,
    17,7.97,3384,6500,4495,6500,4456,6500,4489,6500,4449,6500,4817,6500,3827,6500,4676,6500,4796,6501,5091,6501,4872,5929,4839,6500,4778,6501,4785,6500,5063,6500,5122,6500,,,,,,,,
    18,7.95,1292,4464,2526,5512,2866,5868,3279,5318,3510,6370,3601,6500,3128,6383,4144,6199,4270,6433,4277,6500,4576,7000,3535,6396,4857,6500,5036,5916,4776,6500,4890,6501,5157,6500,5194,6500,,,,
    19,7.96,1868,5829,3190,6500,3640,5467,3884,5881,4058,6081,4143,6500,3077,7000,4102,7000,4140,6894,4502,7000,4626,7000,4536,6500,4525,6500,4630,6500,4431,6500,4556,6500,4709,6500,5007,6500,4711,6276,4932,6500
    20,7.94,1242,5666,2920,4839,3301,4844,3507,6500,3597,6500,3882,6500,3383,6500,4263,6485,4299,6901,4141,7000,4281,7000,4299,7000,5199,7000,4148,5897,5037,6256,4976,6500,5008,6501,5182,6501,,,,
    21,7.97,2024,4560,3178,4842,3493,6500,3968,6500,4281,6500,4312,6500,3617,7000,4622,7000,3591,6501,4686,6500,5076,6495,5038,6500,,,,,,,,,,,,,,,,
    22,7.94,2109,5510,2742,5698,3185,6413,3692,6500,4019,6175,3953,6500,4031,6500,4627,7000,4533,7000,4624,7500,3999,5789,4810,6501,5146,5028,4328,6500,5217,6500,4918,6500,4959,6500,5092,6500,4924,5905,4945,6501
    23,7.96,2434,5936,2970,6500,3257,6500,3251,6342,3720,6500,3900,6500,3133,7000,4392,7000,4365,7000,4701,7000,3669,4959,4175,6500,4855,6501,4837,6501,4689,6500,4870,6501,4986,6500,4986,6500,4888,6205,4901,6500
    24,7.97,2272,4655,3131,5334,3470,5818,3759,6442,3740,6500,4159,6500,3538,7000,4175,7000,4616,7000,3716,6501,4869,6500,4551,6278,4814,6501,4965,6501,4594,6500,5012,6500,4831,6500,4690,6500,4700,6500,4853,6500
    25,7.96,2204,6500,3031,5407,3587,5525,3826,6500,3991,6500,4273,6500,3623,7000,4746,7000,3903,4860,4108,6500,4843,6500,4958,6500,4776,6500,4988,6500,4761,6500,5086,6500,5239,6500,,,,,,
    26,7.97,1653,4021,2628,6331,3177,6256,3599,6500,3809,6500,3922,6500,3341,7000,4207,7000,4770,7000,3695,6500,4872,6500,4817,6500,4743,6500,5020,6500,4882,6500,4830,6500,4658,6501,4789,6500,4744,6500,4724,6500
    27,7.96,3741,6500,4247,6500,4352,6500,4486,6500,4490,6500,4541,6500,3599,6500,4635,6500,4589,6500,4626,6501,4711,6500,4620,6500,4590,6500,4782,6500,4609,6501,4896,6500,4576,6500,4925,6500,4925,6501,4601,6500
    28,7.94,2326,5182,3369,6500,3869,6500,4065,6500,4171,6500,4385,6500,3991,7000,4326,7000,4549,7000,3649,6500,4311,6500,4365,6500,4931,6500,4573,6500,4758,6500,4652,6500,4583,6501,4809,6500,4690,6500,4678,6500
    Below is how I rebuilt the battery packs:
    Code:
    Pack,Module,Max mAh
    1,15,5545
    1,25,5239
    2,6,5222
    2,22,5217
    3,20,5199
    3,18,5194
    4,1,5191
    4,12,5134
    5,8,5127
    5,5,5125
    6,7,5125
    6,17,5122
    7,16,5117
    7,3,5081
    8,21,5076
    8,4,5069
    9,11,5058
    9,14,5034
    10,26,5020
    10,24,5012
    11,19,5007
    11,9,4993
    12,23,4986
    12,28,4931
    13,27,4925
    13,10,4908
    14,13,4898
    14,2,4836
    I know this is long and a lot, so thanks so much for reading this, and thank you if you're able to provide some help!!
  2. WICruiser
    WICruiser New Member
    22
    WI
    My grand daughter's 2013 had a similar problem, loss of power and red triangle. Towed it to a Toyota dealer and they diagnosed the problem as an inverter failure that was covered under a class action lawsuit settlement.
    It is a long shot but you may want to spend the money to have a Toyota dealer inspect the hybrid system. You may get lucky and get a new inverter and fix your problem.
  3. bisco
    52,485
    doesn't sound like the battery to me. do yourself a favor and look into an autel maxi 200 code reader, instead of guessing and wasting time, money and labor.
