My wife's 2015 Prius C with only 60,000 original miles has been showing the "Check hybrid system stop the vehicle in a safe place immediately" warning message off and on for the past two years. It always happened on particularly hot days which makes sense because the temp sensors around the hybrid battery trigger the dash warning. We learned to keep the intake and exhaust vents for the battery unobstructed. The hybrid battery's cooling fan has always been clean, I've even completely dismantled it to be sure, and it didn't need taking because part there was dirt or debris inside it. The warning message won't appear if I happen to have the access panel to the regular battery off (which is right next to the hybrid battery). Presumably because the battery is getting all the cooling it needs. Now I'm running down my options. I've seen the hybrid battery's cooling fan working at a low speed on occasion. Is it possible for the fan to be bad but still operate at a low speed? Can I check the health of the hybrid battery's cells with an obd reader and Dr. Prius software or does it really require a shop with better equipment to determine if one or more cells are bad?
You need to first get us the trouble codes it's throwing; because it's obviously intermittent. The trouble codes will tell you what the ECU doesn't like, because right now your just guessing. The OEM clearly states to keep those vents clear, just because your doing that now, doesn't mean that you haven't already damaged the traction pack. This is like, not doing an oil change until the oil lamp lights up. Is the AC working and do you use it? Set the HVAC to auto and 70 degrees to see if the problem reoccurs.
Dr. Prius is more than enough to catch the specific error code. Once you pull that data through the scanner, it'll be pretty obvious what's actually triggering the warning.
a prius aware scanner should give you more detailed codes. look into autel maxi 200. idk if it will work with the c or not. dr prius will give you module voltages. it might be worth opening up the battery and looking for corrosion
A good scanner is the right start to troubleshooting. It's easy to say that a 2015 should be due for replacement about now; that's a pretty normal expectation. But maybe not. A report from a good prius-aware scanner should help. Good luck!
After checking compatibilities online I ordered a VeePeak Bluetooth 5.0 Plus which should arrive on Monday. The proof will be in the diagnostic of the cells. Other than that, upon watching Dr. Prius videos online two things caught my attention. One is an ability to set what temperature the hybrid battery's cooling fan kicks on. I've always felt it activates too late and at too little speed. The other is an ability to wipe codes. I'm guessing that means codes actively displaying and not the log of their history. I'm a little bit hopeful since the codes have never come up in cooler weather. And wonder if corrosion on the hybrid battery pack's busses may be a culprit.
A P0A80 is enough for Toyota to replace the hybrid battery if it is still under warranty. It does not mean its too hot because those are separate codes. It means the modules are unevenly worn which reduces capacity for the whole assembly. If they were too hot the controllers would speed up the fan. Dr Prius can increase fan speed but it goes back to controller logic the minute you don't have Dr Prius connected and in the foreground. So called "rebuilders" use data Techstream or low cost bluetooth apps like Dr Prius or Car Scanner have as a starting point to teardown and test individual modules with custom loads, chargers and voltmeters. Modules that are bad are replaced with better used modules. It can take weeks to do it right at home with minimal tool investment. Even then, the user may have to teardown and replace more bad modules yearly. Or they buy "rebuilt" assemblies with "warranties" but still play wack a mole with poor reliability unlike the first ten or fifteen years. Bus bar corrosion can be a problem and good "rebuilders" will replace them. Want "forget about it" reliability for your wife? I know I do. Which is why I bought a new oem pack years ago.
Perhaps better than just using Dr Prius to get an error code - might be to use Dr Prius to record a log file as you do a nice long drive. On varied roads, up and down hills and at slow an high speed. Then email yourself the resulting log which you can easily upload as a file to an AI - I've used both Grok and chatGPT - which will give you a detailed, and expert report on the condition of the pack and any problems it may have. As a relative novice at this sort of thing, I found this very useful and very educational! Even if you are not in a position to service the pack yourself, it should give you enough insight to judge whether or not to believe a diagnosis you may subsequently get from a 'pro' ? Also, try uploading to more than one AI, as they vary in the style of their reports and one might be better or more easiiy interpreted than another! A print-out might also be a good guide for anyone who does look at the pack for you.
An obdt2 reader and Dr. Prius software will help you determine the condition of the hybrid cells. I have used them before. I also have a 2015 Prius C which I bought new in 2015. I have 160,000+ miles on mine and never had that error though (never cleaned the hybrid battery fan either-but I do change out the compartment filter every quarter though).
Also, keep in mind that since the car is 10+ years old, the battery is basically on borrowed time. These use Ni-MH chemistry, which generally lasts about 10-13 years. I'd start mentally preparing to replace the pack in the next year or two, or honestly, maybe even today.
Well, guys, after countless delays I finally tested the car and results for the Life Expectancy Test came back as 44.38% capacity remaining which is bad condition, with the number 5 block detected as weak. I had a stroke so I won't be replacing the problem cell myself because lifting the battery pack would do me in. The Prius-C would become my coffin. :-D I'll probably use a mobile service that swaps our battery out for a reconditioned one. But my understanding is reconditioned hybrid batteries are really just a mixed lot of used cells that haven't failed yet. With cells that may or may not have been tested to make sure they've retained a certain level of efficiency and the lot of them balanced....Is it possible for a bad cell to be saved in any lasting way using the Prolong Deluxe Reconditioning equipment? We've been a three Prius family (two Prius-C's One Prius). Two of those three have not shown any hybrid system alerts. Tested the full Prius while I was at it and it's in fair condition at 53.14% capacity. All three cars are ready to be traded in for new purchases. The two little ones will be replaced with the Corolla hybrid (which I've heard has the Prius running gear). Wish the Prius-C/Aqua was still sold in the US market....I appreciate the helpful input throughout the process.
Since you have a regular Prius and two Prius-Cs, you would probably need two Prolong Reconditioners, plus another set of harness for the second Prius-C. Last year my Prius showed the P0A80 code. I (DIY) built a grid-charger/discharger. After reconditioning, the battery life was improved from 50s% to 90s%. I also have a Prius C, which did not show any traction battery problem at that time. To be proactive, I also reconditioned the battery using the same grid-charger/discharger. The battery life was also improved markedly, from 70s% to 90s%. Total cost for the DIY material is around $100. You don't need to remove the battery, so no heavy lifting. How long will the battery last? I don't know. I plan to recondition them once per year, and keep finger crossed. If you plan to trade them in, it will be a different story.
