Featured LIDAR business practices
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Feb 4, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,652
    2,636
    Paramount CA
    One problem with self-driving is that it is less proactive in other people’s driving than manual driving. I am usually not worried about my driving but others’. I could take better evasive action while driving manually if I notice another car driving dangerously. If everyone had self-driving cars, it would be great, but when you are the only one with them, they hardly improve your safety.
  2. bwilson4web
    16,456
    I have the older, HW V3.0 version, and pretty much have the same with a few rough edges that can be worked around. The Tesla has become my preferred daily driver.
  3. bwilson4web
    16,456
    There is a WamBam Teslacam YouTube channel that shows those events and the more frequent saves. Cases when the car reacts to avoid an accident and the driver only finds out about the close call from their video. The most common being the Tesla stopped in traffic and the following human driver hitting the Tesla in the rear.
  4. hill
    8,988
    Tesla or no, that's often the case with an accident, where - like us on the freeway & drivers screeching to a halt for construction ahead (Google maps showing the incident before we got there) the clueless guy behind us smacked the rear of our plug-in minivan. Airbags fortunately didn't go off but the impact of padded headrests smacking us in the back of our heads kind of temporarily knocked us silly. Fortunately we stopped with enough distance in front of us that the rear ending impact didn't drive us into the car in front of us.
    Gokhan likes this.
  5. bisco
    52,630
    that has happened to me as well, sitting at a red light. not much a human driver can do n those circumstances.
    maybe a system can be developed to warn the offending drivers before the collision. I think some cars already have forward emergency braking
  6. bwilson4web
    16,456
    I haven’t done this, yet, but think about a ‘supersized airbag in the rear bumper. In effect: bang; BOOM, and; those recalled exploding airbags parts headed toward the other car to make sure ithat car is TOTALLED.
    Boeing and Russian capsules are the right size. Perhaps a proximity fuse to give us an extra few milliseconds to maximum deploy the bag.
    #86 bwilson4web, May 3, 2026
  7. hill
    8,988
    You can survive anything if your airbag is big enough
    https://www.nytimes.com/1928/07/05/archives/man-goes-over-niagara-in-a-rubber-ball-third-time-falls-have-been.html
    3PriusMike likes this.
  8. Isaac Zachary
    Isaac Zachary Senior Member
    2,736
    1,454
    Has anyone mentioned that Lidar will now be able to distinguish color? This will make it possible for it to not only determine the distance of objects but to also replace cameras and give both a picture and a distance at the same time of each and every object. So, if the car in front of you turns on it's brake lights then this technology will notice that they are red brake lights so the autonomous driving system can act accordingly. Perhaps the tradeoff is that the picture resolution is lower than what a camera can produce, but the distance accuracy is much better.
    Ouster's new color lidar is coming to replace cameras | TechCrunch
  9. PriusTech
    PriusTech Active Member
    264
    124
    Reno
    Self driving will be just like airbags. The few people killed needlessly will be exaggerated in the press until it gets ironed out and then it will not be an issue. Self driving is not only going to reduce accidents it's going to reduce traffic jams. I moved from Seattle to Reno and a benefit was reduced traffic, but after 7 years it's gotten almost as bad with all the Cali immigrants.
  10. bwilson4web
    16,456
    Need to list side-by-side the specs of a LIDAR and dual cameras. A camera based 3d model is a trivial trigonometric problem to solve. Some cameras have frame rates fast enough to image bullets and explosions. Physics, maths, and computing are easy and already ‘off the shelf.’
