I'm back; breaking pledge -- electric problem...sosumi
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Apr 28, 2026 at 10:26 PM.
  1. cyberpriusII
    1,157
    1,845
    Hyampom
    rjparker:
    Well, I think I know what to do now. Thanks
    Thanks for putting up with me. I know it can be a pain when things are obvious to you, but other folks do not quite "get it."
    kris
    #21 cyberpriusII, Apr 30, 2026 at 5:04 PM
  2. futurist
    futurist Member
    57
    127
    United States
    2024 Prius
    Anyone who claims to be an 'elder' on a forum for knowing stuff, but is intolerant of honest questions asked of them... needs a binkie and a change :rolleyes:
    Ribbing in good humour, sure. Silence and / or flaming? Just how senior is this supposed forum 'elder'... :cautious:(y)
  3. cyberpriusII
    1,157
    1,845
    Hyampom
    Ah, we all just havin' funs....esp, my toddler who managed to nab a piece of chicken that was meant for dinner and "donated" it to the dogs.
    My fault, I had the chicken in reach. Lucky it was not a live electrical wire! :p
    futurist likes this.
  4. ChapmanF
    18,679
    I keep kind of an assortment of cheap thingies around for testing which wires are live. A multimeter, sure, but also a little pocket-clippy neon light with test probes, and a similar thing with 'gator clips, and some of those funky light-bulb sockets made for festoon lighting, where you just screw the back of the socket down over some wires, and maybe two or three other things I was turning over in my hand one time or another thinking "that might be handy in some situations to see which wires are live".
    So, like, I could turn the breaker off first, and take the old receptacle out, and stick the top black/white pair into one funky festoon socket and screw the back down, and stick the bottom black/white pair into another funky festoon socket and screw the back down, and put small light bulbs in both of the sockets and go flip the breaker back on and come back and see which light bulb lit up.
    If there were no toddlers around, I might just switch off the breaker, remove the old receptacle, and leave both pairs of wires sticking out of the box, bent well away from each other, go back and turn the breaker on, and come back and poke at the exposed wires with the pocket-clippy neon light with test probes.
    But I don't think I would do it that way with a toddler around.
    #24 ChapmanF, Apr 30, 2026 at 6:29 PM
  5. Mr.Vanvandenburg
    1,358
    602
    2020 Prius Prime
    Maybe the local hardware store knows a licensed electrician that will do work after hours for less. Get the whole circuit protected by the first gfci or put a gfci breaker in is what I would do, with all new spec grade outlets at least. An arc fault afci plus a gfci is even better, may be required. It definitely needs replacing from what you said and the picture.
  6. BiomedO1
    4,323
    2,269
    Left Coast
    Yep; can't trust wire colors. I've found them reversed on multiple occasions - usually when people get confused on a 3-way switch wiring. I've done a lot of volunteer work with Habitat for Humanities; and had to always check the way they wired and tied it together. That's a great way to figure out how to do basic household repairs. Unfortunately; you also find out how sloppy your house was put together along with all the code violations - tough to unsee those once you know.o_O:whistle:
  7. ChapmanF
    18,679
    I'm picturing a charitable organization that builds new departments for scholars booted from schools that have cut everything but STEM.
    BiomedO1 likes this.
  8. BiomedO1
    4,323
    2,269
    Left Coast
    All site bosses were retired tradesman. Habitat choses the homeowners and require several hundreds hours of sweat equity; so they at least have the basis to maintain the home properly. I pretty much had electronics down; just didn't know electrical wiring and local codes.
    I encourage anyone going into the trades or have some extra time and want to learn something to volunteer;)
  9. ChapmanF
    18,679
    They also have (well, Habitat for Humanity does) a program called A Brush With Kindness, or some chapters have it, anyway. Its focus, instead of new construction, is people whose existing houses have maintenance tasks that overwhelm them. So sometimes you show up in the morning expecting to be sent off to a build site, and instead end up sent to an existing home to pull out soggy drywall or design/build a new set of deck steps or something. Good practice for a generalist, not quite knowing what set of skills you'll have to pull out of the hat that day.
  10. rjparker
    10,647
    6,679
    Around here Habitat builds small houses for low income families who have resources to pay a much reduced mortgage. The families skill sets can be as little as cleanup and material handling. Lot locations are usually in good school districts and often close in but may have some compromise like proximity to a railroad track. The home's sqft costs are low with volunteer labor when possible and licensed trades when needed. Perhaps the biggest benefit is no interest financing directly from Habitat.
  11. cyberpriusII
    1,157
    1,845
    Hyampom
  12. rjparker
    10,647
    6,679
    Nice. Complete with a green light and vertical screws.
  13. Stevewoods
    Stevewoods Senior Member
    663
    1,212
    where I am
    Did you use the "lever edge" outlet?
