gas-cap cover anomaly
Discussion in 'Gen 5 Prius Main Forum' started by Fenichel, May 2, 2026 at 4:34 PM.
  1. Fenichel
    Fenichel Junior Member
    33
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
    Every once in a while, I reach for the rear-hatch-release button and accidentally hit the adjacent button that opens the gas-cap cover. Pushing the cover closed a few seconds later should restore the pre-existing state, but it doesn't quite do that. At least most of the time, the brief opening of the cover affects the reading of the dashboard's indicator of km-to-fuel-tank-empty. I have taken notes only twice: Once the indicator jumped from 152 km to 215 km, and on another occasion it went from 612 km to 656 km.
    Has anyone else observed this phenomenon?
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    6,599
    2,626
    Paramount CA
    It probably depends on the grade of the slope where you are parked, which affects the fuel level in the tank. That’s why I always use the same pump when refueling. I didn’t know that opening the fuel-inlet lid resets the distance-to-empty range.
  3. hill
    8,964
    Far from ideal if you just pump three or four gallons when you're at ½ a tank
  4. VelvetFoot
    VelvetFoot Senior Member
    1,318
    513
    New York State
    2026 Prius
    Perhaps it needs a little while to recalibrate.
  5. Gokhan
    6,599
    2,626
    Paramount CA
    I believe calibration happens only once (a few seconds after you drive) after a fill-up. It is not dynamic like the electric-range estimate.
  6. VelvetFoot
    1,318
    513
    New York State
    2026 Prius
    I’d warrant it gets more accurate a few miles down the road.
  7. Gokhan
    6,599
    2,626
    Paramount CA
    I don’t think so. Try it for yourself after a fill-up. DTE is not dynamically updated as far as I know. By the way, I am the DTE record holder on PriusChat, having reached 768 miles in my 2021 Prius Prime Limited.
    What is your DTE after fill-up? | Page 6 | PriusChat
  8. Fenichel
    33
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
    No, it doesn't.
    Gokhan likes this.
