gas-cap cover anomaly
Discussion in 'Gen 5 Prius Main Forum' started by Fenichel, May 2, 2026.
  1. Fenichel
    Fenichel Junior Member
    35
    22
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
    Every once in a while, I reach for the rear-hatch-release button and accidentally hit the adjacent button that opens the gas-cap cover. Pushing the cover closed a few seconds later should restore the pre-existing state, but it doesn't quite do that. At least most of the time, the brief opening of the cover affects the reading of the dashboard's indicator of km-to-fuel-tank-empty. I have taken notes only twice: Once the indicator jumped from 152 km to 215 km, and on another occasion it went from 612 km to 656 km.
    Has anyone else observed this phenomenon?
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    It probably depends on the grade of the slope where you are parked, which affects the fuel level in the tank. That’s why I always use the same pump when refueling. I didn’t know that opening the fuel-inlet lid resets the distance-to-empty range.
  3. hill
    9,027
    Far from ideal if you just pump three or four gallons when you're at ½ a tank
  4. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    Perhaps it needs a little while to recalibrate.
  5. Gokhan
    6,714
    2,661
    Paramount CA
    I believe calibration happens only once (a few seconds after you drive) after a fill-up. It is not dynamic like the electric-range estimate.
  6. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I’d warrant it gets more accurate a few miles down the road.
  7. Gokhan
    6,714
    2,661
    Paramount CA
    I don’t think so. Try it for yourself after a fill-up. DTE is not dynamically updated as far as I know. By the way, I am the DTE record holder on PriusChat, having reached 768 miles in my 2021 Prius Prime Limited.
    What is your DTE after fill-up? | Page 6 | PriusChat
  8. Fenichel
    35
    22
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
    No, it doesn't.
    Gokhan likes this.
  9. Mendel Leisk
    42,330
    If that’s the only thing it does, I wouldn’t care, never use that distance to empty, just the gas gauge.
    frodoz737 and BiomedO1 like this.
  10. BiomedO1
    BiomedO1 Senior Member
    4,576
    2,404
    Left Coast
    they are all just guess-a-mates.... Are you really going to ignore "the last gas station for 50 miles" sign; because your DTE is displaying 51 miles?????? This is why there are "Darwin Awards".....
    Tande likes this.
  11. Winston Smith
    Winston Smith Active Member
    470
    338
    OH
    2024 Prius
    LE AWD-e
    In my Gen 5 (not prime), the DTE is not static. The sum of DTE and trip ODO will typically rise for the first hundred miles or so, and by mile 300 the sum will shrink.
    My WAG is that the DTE immediately after filling includes the entire tank capacity as the denominator in the MPG fraction, then counts it less all the way to an absurd DTE of zero at which point I still have a couple of gallons. It's a weird distortion to avoid telling people that they only have a range eight or so gallons to use before invading the reserve.
  12. Winston Smith
    470
    338
    OH
    2024 Prius
    LE AWD-e
    VelvetFoot and BiomedO1 like this.
  13. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Similarly to Kramer in Jerry's Saab, I figure I can 50 miles after it says "Zero"...maybe.
  14. Fenichel
    35
    22
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
    That's what I do, too, but I was surprised to see that the state of the gas-cap cover affected anything but the dashboard warning that it was open.
