Do I have the wrong dipstick?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by PHEVisthefuture, May 1, 2026.
  1. PHEVisthefuture
    PHEVisthefuture Junior Member
    83
    25
    Illinois
    New (to me) 2017 Prius Prime owner.
    I have put about 6,000 miles on the car, and during this time the dipstick never changed in level, whether hot or cold. It’s up to the dot where Toyota marks the “normal” Full level of the crankcase, so I thought that’s perfect.
    Recently I had some cold start rattling that was louder than what I felt comfortable with, so I checked the dipstick and it was still Full. Put a half quart of 0W-20 and checked after wiping off with a rag, no change. Put the rest of the quart in, still no change. The dipstick reads Full.
    Now you must be thinking, car isn’t level, hot or cold, nope. Car sits in a level garage (a stick shift wouldn’t even roll when out of gear and no parking brake) and I have checked it in 32F and 85F weather.
    But now my rattle noise is gone. So was I a quart low? Is there a chance someone put the wrong dipstick in my car, and if so, shouldn’t it be way over full if it truly was the wrong one? Or am I actually a quart over, and about to blow the seals on the engine?
    First used car of many that has decided to throw me for a loop on the oil level!
  2. PHEVisthefuture
    83
    25
    Illinois
    To add to this thread, I let the car sit overnight (neither on a charger or been running for 8+ hours) and checked the oil, still at the "Full" mark. After doing some searching, however, I noticed that the dipstick I should have doesn't seem to have a mark at the "Full" level, which I've marked up on the photo attached.
    This was just from a quick Google search showing the dipstick I should have (1530137010):
    https://parts.toyotaofnashua.com/oem-parts/toyota-2008-2024-toyota-engine-oil-dipstick-1530137010
    Can anyone confirm/deny that their 2017+ 4th Gen Prius Prime dipstick has the mark where the ? annotation is on the attached photo?
    I'm now wondering if I was very low on oil (3 quarts or less in crankcase) or if I am now way over full. If it weren't for a slight injury I'm recovering from, I'd jack up the car and drain out all the oil just to be sure.
  3. Mendel Leisk
    42,310
    I checked on Amayama, my 3rd gen is the same part no for dipstick; pictures for comparison:
    oil at the full mark:
    Regarding the relentless readings as “full”, something’s not adding up: if you (say) add a pint of oil, and the level doesn’t budge on the dipstick, you must be doing something wrong, or reading the dipstick wrong.
    Addendum: per the US 4th gen Owner's Manual (on page 593), distance between the two marks on the dipstick represents 1.6 US quarts.
    #3 Mendel Leisk, May 2, 2026
    bisco and Brian1954 like this.
  4. bisco
    52,807
    why don't you post a picture of the dipstick?
  5. PHEVisthefuture
    83
    25
    Illinois
    Here are photos of the dipstick, after being wiped off with a clean rag. I just drove 30 minutes so not all the oil has had a chance to drain back into the wet sump.
    Also, I just noticed that if you flip the dipstick over, it actually reads way high - something I’ve not seen before.
    For comparison, attached is the dipstick for my track car (2009 Corvette LS3), where GM says to overfill the oil by 1 quart (it clearly shows overfilled, and the distance between the middle and top dot is 1/2 quart). This dipstick shows the same thing regardless of orientation.
    With the Prius, both sides are not equal to the top dot - am I way over on the Prius, or way under?
    Photos: 1. Prius Prime dipstick pulled straight out, 2. Prius dipstick flipped over
    3. GM LS3 with known 1 quart overfill (per manual), 4. Cub Cadet 243cc dipstick
  6. PHEVisthefuture
    83
    25
    Illinois
    Here is another reading back to back showing it right side up and flipped over. Which is correct, the first or flipped orientation?
  7. PHEVisthefuture
    83
    25
    Illinois
    I made some markups based on what I am seeing, in both cases (flipped vs, not flipped) the dipstick leaves open to interpretation which reading is the actual reading.
    Wiping off the dipstick with a rag doesn't seem to correct this, I always get two "spots" where the reading could be assumed to be Full.
    This is the forward-facing orientation:
    Then after flipping the dipstick, we get this:
    Really hope I didn't run this engine low, it's my baby, and if it was burning oil I feel like an idiot & should've just drained the oil out to begin with. Then I'd know 100% what's in the crankcase.
  8. notspam3
    notspam3 Member
    136
    71
    Toronto
    2024 Prius Prime
    XSE Premium
    Prius Death Rattle
    PHEVisthefuture likes this.
  9. PHEVisthefuture
    83
    25
    Illinois
    Thank you, @notspam3!
    I will check the spark plugs when I have a day off. Let the car sit overnight and I’m back to the “It’s Full” on one side and over on the other. Maybe I really was a quart low and should have been flipping the dipstick over the whole time?
    This story from Reddit sounds just like mine, and that owner has either low oil when reading one side vs Full on the other.
  10. Mendel Leisk
    42,310
    After pulling the dipstick, wait at least 5 minutes before pushing it back in for the level check; the first pull-out tends to pull oil up the tube, and the wait gives it a chance to drain back down. Otherwise it’ll smear some oil along the dipstick, much higher than the actual level, making it difficult to determine the actual level.
    also, I’ve found the dipstick face towards front of car tends to be more definitive, less prone to the smearing.
  11. PHEVisthefuture
    83
    25
    Illinois
    Thank you, it looks like I’ve actually been a quart low as I tried your method for the first time. It still left oil streaks, but I can clearly see its now at the Full mark (flipping it over reads way high still) so I guess the whole time I was low, just like the Reddit post I referenced above.
    Hopefully no engine damage was done, and my cold start rattle seems to be gone for now. I’ll still check the plugs when I’m able to, it’s a 4 cylinder (a lot easier than Camaros and Vettes where the last 2 plugs nearly require wiper arm removal, lol).
    bisco and Mendel Leisk like this.
  12. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    Newer car, but isn't that what the dimples are for.
    What does your manual say.
  13. PHEVisthefuture
    83
    25
    Illinois
    That’s the issue, I was always at the “B” mark until I tried what @Mendel Leisk had suggested.
    The whole time I saw “Full” then realized it was just residue from the tube. Basically the true level was likely close to “A” but the smears kept it right at “B” which was confusing.
    Luckily nothing seems to have happened, but only time will tell.
  14. rjparker
    11,055
    6,927
    Always read the lower level; the higher side is oil smearing from the dipstick tube.
    On my cars, if I read level first thing in the morning, both sides read the lower level.
    Odds are good your engine is burning oil. A good engine can go 5k miles or more with no observable drop in level.
    Brian1954 likes this.
  15. PHEVisthefuture
    83
    25
    Illinois
    Thank you. I'm OK with consuming 1 quart in 5-6k miles if it doesn't significantly increase. All engines burn oil, it's just some (when new) don't do it at a rate that's noticeable - i.e. at the manufacturer's oil change recommendation (7,500 to 10,000 miles) the amount lost is not even significant and even then, manufacturers only warranty an engine if it's consuming something like 2 quarts every 500 miles or so!
  16. Mendel Leisk
    42,310
    4th gens don’t seem as prone heavy oil consumption. 3rd gens are very prone, due to low friction piston rings
  17. bisco
    52,807
    oil at or above the low mark is fine. I don't think you've done any damage at all
  18. bisco
    52,807
    I'll be shocked if you're burning any oil at 100k. once you're comfortable with the reading, watch it over the next 5k.
  19. Robert21PrimeLTD
    105
    South of Nashville
    The attached photo was taken cold, 3-1/2 hours after the ICE was on. The vehicle is level in the garage. I removed the dipstick and wiped it off and put it (in and then out) of the crankcase. Note that the oil level is slightly about the top hole. The oil was last changed by Toyota 900 miles ago with 0W16. FYI, Corvettes have dry sumps so dipstick level is different than Prius’s.
    The only way to know for sure is to drain the oil and add a known quantity. Keep in kind that even if you warm the block and drain it, some oil will remain in the crankcase and if you don’t change the filter, oil will remain there too.
  20. PHEVisthefuture
    83
    25
    Illinois
    Thanks. Since I bought the car used I have no idea what happened at the dealership, perhaps they only filled it with 4 quarts instead of the 4 and a half so I'm realistically only burning 1/2 a quart or less every 6,000 miles.
    Will do, and plan to do a Blackstone report. I'm still getting used to driving this thing. Coming from a 2012 Volt and the Vette (both relatively high torque cars), you barely have to press the gas to get on a highway. This Prius requires some judicious throttle application to get up to speed, which I'm getting used to, and I'm sure hurts MPG.
    Funny side note - I test drove a Camaro ZL1 (650HP V8, 6 speed manual) and the salesman was shocked I got 24MPG on the test drive. He's like "how did you get it that high"? And I responded, lean into the torque, not the HP, he had no idea what I meant & was perplexed. Probably drove the thing like a maniac when he took it to customers for demos (this was during the pandemic) hence the terrible MPG.
