Hello from a CT Owner with Issues
Discussion in 'Newbie Forum' started by SB-CT, Apr 19, 2026.
  1. SB-CT
    SB-CT New Member
    UK
    Hello Forum, signed up as most of the useful information online to do with the Toyota Hybrid system came from this site.
    I own a Lexus CT200 (2017 model, middle facelift). Based in the UK. 96,000 miles on it.
    I'm here for help for a very specific C1202 fault. It's intermittent on and off for the last two months.
    Last year I had the brake booster replaced at the Toyota dealership I bought it from. 50 weeks of zero issues so I suspect that new part was fine and fitted fine. Unfortunately they closed their door on me when I took it back and said as the warranty which the job was done under ended last summer, so did their warranty on that work...
    Unlike when the brake booster went, when my fault this time is ON, I lose ABS / traction and the brake feels like it takes more effort. But cruise control still works as does regen braking so I suspect speed sensors are fine.
    C1202 says brake reservoir malfunction. But the fluid is and remains at the high / correct level.
    Took it to Lexus, that day the fault was NOT on (typical) but still wanted them to check it out. They followed the procedure and said they looked over the system, cables etc and said no issue found, advised me to take out my Nextbase dash cam (new one which can only be powered via the OBD port). I am not convinced that is related.
    The issue has been on and off since. I suspect it's moisture / water related but then yesterday was a hot day and it was on most of the day so even that doesn't check out completely.
    I checked the voltages on the pins, cleaned them out with contract spray and high pressure air to dry them. Voltage / resistance stuff was as expected.
    I'm at a total loss on what to do, or how to further troubleshoot. Though I am not overly familiar with circuit diagrams or electric troubleshooting I do most of my own work (servicing and part repairs when needed) to my cars except bodywork and tyres. So I'd like to give it a try, but my knowledge of hybrid specific stuff is not deep.
    I have had a good search of the forums on here with people troubleshooting C1202 but many of the threads they either have a worse issue such as more brake booster codes and then the threads just stop with not always a solution.
    Can anyone help? Very, VERY grateful for your help. If the forum supports donations and I somehow get this fixed for like say a month straight, would make a big donation!!!
    Alexmercy and bisco like this.
    52,807
    welcome!
    I can't help, but I am curious. have you tried disconnecting the dash cam to see if the light stays off?
    I'm not saying that's the issue, but obd connections do occasionally cause false codes.
    all the best!
    Alexmercy and SB-CT like this.
  3. SB-CT
    SB-CT New Member
    UK
    Thanks for your reply @bisco. I have not tried that for long but Lexus did say that it could be interfering although I’ve had that since last July and the issues didn’t begin until February.
    I held my iPhone under the reservoir yesterday and watched from my Apple Watch live as I pointed it around places I couldn’t see.
    I found something bloody amazing in terms of a breakthrough. The bottom of my reservoir has exposed metal wires which show surface corrosion. They are missing the black plastic protection altogether. I have no idea how this finish could fail other than being exposed to fire level heat or being scraped off by hand. See my photos.
    I found on eBay that nearly every example of this part from way older CTs have the black protective layer in tact. This is surely why mine works - thick metal in tact capable of passing a signal when dry and then when wet or humid, causing the fault light and C1202.
    this is a new one for future owners of all these 3rd gen systems to check?
    I have emailed Lexus as I have that ‘relax warranty’. Perhaps if they agree this is a material failure they can repair it without cost to me other than their second inspection of the issue which should be easy as I have shown them these photos.
    if not… I believe from reading on here Toyota and Lexus dealers would NOT replace just this part if we asked them to and that they’d force the entire brake booster system. If that’s the case, I wonder why Toyota who replaced it last year did not replace this as well? Or… when they worked with the system why did they not notice this? If Lexus do not sort it, in fact, even if they do, I may approach the Toyota dealer and ask for an investigation. They weren’t interested when 50 weeks later this issue occurred as they said it was no longer warranted by them since my used car warranty had expired and that’s what their job was covered by in Feb 25.
    Do you know if that is a Toyota policy that this must be replaced as a full system or just a dealer choice to do so, as when they inevitably try to tell me it wasn’t needed at the time, I would like recourse to Toyota and the warranty company who were likely paying out for this piece for it to not end up in my car. Etc.
  4. bisco
    52,807
    I'm afraid idk what Toyota policy is. do you have a customer service number you can call? I always thought Lexus dealers were much better about these things than Toyota dealers.
    Alexmercy likes this.
  5. SB-CT
    SB-CT New Member
    UK
    Screenshot 2026-04-20 at 20.55.19.png Screenshot 2026-04-20 at 20.55.46.png Screenshot 2026-04-20 at 20.55.50.png
    Spoke to Lexus today. They reckon the protective coating on my reservoir cable is fine. Upon further inspection today.. I agree.
    I joint the pins on the car end of the connection to the reservoir tank with a paper clip to simulate a ‘good connection’ since it’s a simple float switch and when connected, should give in theory solve my fault lights. Nope - no difference. Suggests the reservoir tank itself maybe fine.
    my next course of action tomorrow is to check both ends of the PINK wire from the reservoir tank (car side of the cable) and the other end of it. It leads to the ‘skid control ECU’, pin 36 on my UK RHD car. To see if there is resistance or an ‘open’ in the circuit. I hope I’m using the right terms here.
    if so, I can bypass it for a while and see if the system can go a few weeks without issue. Then… I’ll dig into the actual loom and fix the wire properly and reseal it all up.
    If not.. Lexus can decide whether to replace the skid control ECU or the reservoir as these are both covered under the ‘Relax’ warranty. They told me wire loom repairs will NOT be covered unless they are connected to the part itself (e.g. how the reservoir has its wire seemingly glued into its bottom. But not the loom it plugs into).
    this is all going by the diagrams I found on the leaked Tech Doc system from the CT forum. I presume you guys have something similar for the Prius. If not worth grabbing a copy as I think it’s basically a 3rd gen system and identical :)
  6. Mendel Leisk
    42,306
    I’d try disconnecting your obd powered camera and having codes dismissed, system reset by dealership.
    I had increasing frequent brake anomalies, multiple warning lights on dash coupled with odd brake feel:
    Hybrid System Warning and multiple other lights | PriusChat
    dealership mechanic had Techstream laptop connected, noted the obd connection kept breaking, suggested I disconnect my ScanGauge II. I did this, and no further issues.
    bisco, Alexmercy and SB-CT like this.
  7. SB-CT
    SB-CT New Member
    UK
    Thanks for the reply. The dealership did say this in March when I took it down for my intermittent fault but the lights went off that day. But the camera was in since last June and no issues until now. I also replaced the battery with a brand new Yuasa same part as from factory.
    I can give it a try but today I dropped the car off with Lexus. Hopefully they find the issue and that it’s coverable by the Relax Warranty.
    my intermittent C1202 disappeared yesterday evening as we tested it. All wires were fine but we found a voltage from the pink signal wire of the reservoir was giving near 14 volts not the 4-7 the TechDoc system stated.
    I then found an engine light (P0010), a C1466 which for a while was on with the C1202. I suspect the P code was my messing with wires and trying to find and clean grounding points which had me disconnect the 12v and the HV system (to be safe). I don’t believe I broke or strained anything with all my searching.
    I’m really not sure what’s going on with it. Even my C1202 as we followed the various grounding and continuity checks, at some stage went off leaving just the rear right wheel code I mentioned above - same dash lights / lack of brake assist. So that pink signal wire test fail might mean nothing.
    i will post updates. Gave them up to a week with it and up to three diagnostic hours before I want to approve any more.
    ironically… I saw this ad as I walked from the dealer to the bus stop to go home.
    bisco and Mendel Leisk like this.
  8. SB-CT
    SB-CT New Member
    UK
    Hello again PC forum, thought I’d keep this updated so future owners with the same electrical gremlins know what the ultimate outcome was. There were a lot of great threads on here similar to my issue, but many of them just went silent with no final outcome. Hopefully those owners got a good result, but we will never know!
    The car is at the dealership as of last Wednesday - giving them time to see the issues personally not just a photo of my codes. They were staying on constantly as per my last update.
    They discovered a rear wheel ABS sensor wire hanging on by a thread of copper, barely making contact. This was from the troubleshooting of code C1466. As I had mentioned, mid troubleshooting last Tuesday by myself, by the end up the C1202 was gone and only the C1466 was there. Perhaps this is some root fault and was leading to a coverup fault up the chain from some odd signalling being received by the skid control ECU, making the reservoir circuit appear to be broken. They have ordered and are replacing this and we hope the brake system will behave. Otherwise, further diagnostics if the C1202 comes back - or whichever code, should the four brake horsemen make their presence known on the dash. The sensor wiring makes sense as it seemingly was not so much 'only' wet or dry, or hot or cold, but humidity and then after 30 mins of driving, proper heat / dryness expanding the copper on that wire and allowing it to work for periods at a time, then boom, faults. It does line up. Covered under warranty.
    The P0010 is being covered by warranty too. Camshaft position sensor. I was worried that this was something I caused from investigating the C1202 but sensor is now ordered and will be fitted.
    1.45 hours of diagnostic time. I authorised a little more in case it's needed following the part fitting. I think if future issues still persist along the same systems the warranty has it covered.
    I really hope this gets the CT back to reliable over the long term. If not for the warranty, I suppose I'd have tried a used reservoir, and then went on to the speed sensor testing - possibly a rear brake job. From that I'd like to think I'd have spotted the wire in bad shape and repaired the loom... that's if the warranty didn't apply. I'm so glad I got that last service to trigger the 'Relax' warranty - do you guys have that in your country from Toyota? On a nearly 10 year old car with 96,000 miles... I must say, that's one hell of a way to treat customers :)
  9. SB-CT
    SB-CT New Member
    UK
    Does anybody here have any thoughts on whether the ABS wire with its loose connection might have caused the C1202? I will keep reading the forum but I wonder how likely one bad input can wreak havoc on the rest of the system. I’d like to believe this but I lack the experience with this 3rd gen hybrid system :)
  10. drash
    drash Senior Member
    2,599
    1,339
    Upstate NY
    XLE AWD-e
    Even though your CTh OBD II software was based on 3rd gen Prius, it's still 1st gen Lexus CTh software. My NX 300h software is based on 3rd gen RAV4 hybrid software but it's still 1st gen Lexus NXh software and has it's quirks. When the 12V battery failed I got all kinds of dashboard lights and check engine codes. Fortunately I had a couple of OBD II reader apps and an OBD bluetooth dongle along with other signs the battery was failing. Lo and behold they replaced the 12V battery, everything went away. Cleared the codes and they haven't come back yet. Your post #7 is a highly likely suspect in causing other issues when you have a short to 14V (my assumption) instead of the 4 to 7V expected.
    SB-CT likes this.
  11. SB-CT
    SB-CT New Member
    UK
    That is true and good to know.
    I had initially read issues of weak batteries causing havoc. Had this in previous other brand cars - things like power steering cutting out when the voltage got low, often fixed with a restart and a good drive. I bought a new Yuasa in February, the original was in (so 8 years old) and although it had passed a test by Lexus at the service in early Feb, I have previously had auto stores say my batteries were fine only to fail to start a couple of days later. So I bought the new one , fitted it. The dealer told me it wouldn't need the resets done but if I had issues, that they would be able to do so.
    General Update:
    I got the car back on Friday - and it's been a beautiful few hundred miles of driving .
    It was a bad rear right ABS sensor WIRE - they said it was barely making any contact. This means the C1202 fault was a result of the inconsistent signals from the rear right ABS wheel sensor. As I mentioned, my complete brake booster assembly was replaced February 2025 at a Toyota dealership so I'd have been gutted if any big components of that system needed re-done so soon.
    They couldn't get that particular section of the loom until early June so they did a temporary repair to fix the wire in the meantime. I'll bring it back in. That was covered by Relax warranty too! That places Toyota as the #1 car brand in the world to be taking care of issues like this on an older vehicle.
    While it was there for the week... I asked them to recharge the air con. I had a low refrigerant fault since Feb also, but it blew a little cold. They did a pressure test and found a leak. They didn't have enough time to find the leak, but when it goes back for the ABS loom section, I'm going to pay for finding the leak. Hopefully a part failure and covered by warranty... otherwise I could be out quite the expense to have them fix it on my dime. Unfortunately I think it will need fixing as running the system over time will eventually lead to failure of some other associated electrical systems from what the service guys advised. I trust them though - they have been sound in finding my problems so far, fixing them and didn't use the full amount of diagnostic hours I gave the thumbs up to which they easily could have.
    So overall, my car is back on the road, driving perfectly (you take for granted how good the brakes are until you drive a few weeks with no assistance on them). No fault lights either. So enjoying that - hopefully they stay away.
    I will keep posting updates. Particularly on the A/C - I see a lot of folks on here and the internet replacing the AC pressure sensor. Turns out mine is correctly working... they found 10 'units' out of 4/500 'units' of refrigerant in mine. They said they have seen a fair amount of both damaged from use as well as part failures covered by warranty over the years so until I get it back to them, we won't know.
    I gave it a good clean out on the interior today... glad to have it back in the meantime.
    drash and bisco like this.
  12. bisco
    52,807
    congrats, and thanks for the update!
    SB-CT likes this.
  13. drash
    drash Senior Member
    2,599
    1,339
    Upstate NY
    XLE AWD-e
    Awesome and congrats!
    Great you found a shop that is good like that. I believe the A/C compressor runs off its own DC/AC converter at 25V but yeah if it fails you might see issues with codes saying the DC/AC converter failed and/or it'll start popping fuzes.
    Awesome looking ride! (y) Yup nothing like a good post winter clean out. Lots of salt in bedded in the carpet on my NX 300h and had to spray liberal amounts of warm water and vinegar to get that out. Now to clean the rest of it.
    SB-CT likes this.
  14. markismail
    markismail Junior Member
    amesterdam
