Quirk in the transmission shifter
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Apr 12, 2026.
  1. VelvetFoot
    VelvetFoot Senior Member
    1,323
    514
    New York State
    2026 Prius
    My last mini cooper was like that too.
  2. Gokhan
    Gokhan Senior Member
    6,606
    2,626
    Paramount CA
    The car should stop under the dryer anyway, so I don’t see why pressing the brake is a problem.
  3. schja01
    schja01 Senior Member
    1,855
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    The car never stops. It’s in motion when the “Drive Away” light comes on. You’re expected to drive forward, not stop. The car is still being pushed forward when you’re expected to go forward so braking actually fights the pushing mechanism.
  4. KCWhitney
    KCWhitney Active Member
    143
    118
    Connecticut
    2025 Prius Plug-in
    Your explanation makes sense, to a point. Couldn't they have designed the control to avoid going through Neutral to change directions? It's only an electronic switch anyway.
  5. ChapmanF
    18,701
    You've caught on to the "paint themselves into that corner by laying out the pattern the way they did" part.
  6. Gokhan
    6,606
    2,626
    Paramount CA
    Well, at one point it will stop, as the car wash is not infinitely long. LOL
