Quirk in the transmission shifter
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Apr 12, 2026.
  1. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    My last mini cooper was like that too.
  2. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    The car should stop under the dryer anyway, so I don’t see why pressing the brake is a problem.
  3. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    The car never stops. It’s in motion when the “Drive Away” light comes on. You’re expected to drive forward, not stop. The car is still being pushed forward when you’re expected to go forward so braking actually fights the pushing mechanism.
  4. KCWhitney
    KCWhitney Active Member
    143
    118
    Connecticut
    2025 Prius Plug-in
    Your explanation makes sense, to a point. Couldn't they have designed the control to avoid going through Neutral to change directions? It's only an electronic switch anyway.
  5. ChapmanF
    19,038
    You've caught on to the "paint themselves into that corner by laying out the pattern the way they did" part.
  6. Gokhan
    6,715
    2,672
    Paramount CA
    Well, at one point, it will stop, as the car wash is not infinitely long. LOL If still not satisfied, you will have to find a Gen 5-Prius-compliant car wash.
    This is merely a safety feature in Gen 5 to prevent people from accelerating suddenly and/or in the wrong direction while stopped or creeping, for example, so that you don’t “front-end” the car behind you in the car wash by putting it to R instead of D from N.
    #26 Gokhan, May 7, 2026
