Idle rev go up and down continuously
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Artunc, May 7, 2026 at 5:29 PM.
  1. Artunc
    Artunc New Member
    Yesterday
    I tried to search the site but couldn’t locate any discussion about my problem. My 2011 Prius just started to rev up and down shortly after oil change. The coolant is a little low too. The codes it shows are P0171 and P0401. I checked for vacuum leaks but nothing I can see. The EGR assembly and intake manifold cleaned a couple months ago. When I put it to Maintenance mode, it rough idled and died throwing errors P0102 P0113 and saying check hybrid system.
    I would appreciate if anyone can point me to right direction to troubleshoot this issue.
    Thank you.
  2. Brian1954
    Brian1954 Senior Member
    2,490
    996
    South Central PA, USA
    What scanner are you using to check for trouble codes? Does the scanner read live data? If so, what are the short-term and long-term fuel trims?
    An engine that revs up and down during idle sounds like a vacuum leak to me. The P0171 code confirms that the engine is running lean.
    My guess is a problem when you cleaned the EGR system a couple of months ago. Did you use new gaskets between the intake manifold and the cylinder head and also between the EGR pipe and intake manifold when you put it back together?
    Did you clean the EGR cooler. The P0401 code indicates insufficient flow through the EGR circuit.
    #2 Brian1954, May 7, 2026 at 8:28 PM
  3. PriusCamper
    PriusCamper Senior Member
    13,195
    5,341
    Pacific Northwest, USA
    Crappy oil change places are sometimes the last place people drive their car before its ruined. Just helped walk a friend through a major clean and high voltage battery recharge with too much oil in his Prius. So infuriating!
    In my research to help him I learned that these untrained workers often inspect the air filter for an upsell and fail to put the cover back on correctly, which can cause these symptoms.
    I also worked on 2006 Prius a while back that had these symptoms with a different error code and the fix was replacing the throttle body because the throttle body position sensor had failed.
    #3 PriusCamper, May 7, 2026 at 11:39 PM
    Brian1954 likes this.
  4. Mendel Leisk
    42,042
    One possibility: did you happen to have a 12 volt battery disconnection? That'll make for surge-and-drop revs, for the next few start-ups. I'd speculate it's the car recalibrating throttle response.
    That said, all those codes, probably more to it. P0401 is for low EGR flow; this is after the EGR cleaning? You did the cleaning?
    What's the miles on it, and was that the first EGR cleaning? You mention low coolant: was that the impetus for the cleaning?
    Can you clarify the timeline? You mention 2 sets of codes, and egr/intake cleaning and an oil change, but it's not clear the order and the time between each.
    #4 Mendel Leisk, May 8, 2026 at 12:02 PM
  5. Artunc
    Artunc New Member
    Yesterday
    The scanner they used was an Innova 5160rs. I used Dr Prius and Auto Doctor to read live data. It has 203.7K miles on it.
    At a cold start, long-term trim shows 0.00% and short-term trim shows 17.19%. MAF air flow rate is 6.12 g/sec. (see attached)
    I cleaned the EGR cooler, EGR valve, intake assembly 2-3 months ago and that resolved the EGR error code I was getting. (They were pretty clogged up)
    The oil change was 2 days ago, this issue started yesterday.
    After it idles for a minute or so it throws P3190 and shows check hybrid system, which I think that's a secondary code due to engine stumbles and not providing enough power to sustain power.
    Every time it throws hybrid system error, I reset the codes using the apps and disconnect the battery 5-10 minutes.
    Thanks.
  6. Artunc
    Artunc New Member
    Yesterday
    I just tried to post a video and audio of the issue, but this web site doesn't allow me to upload them, saying file doesn't have allowed extension.
  7. Brian1954
    2,490
    996
    Try removing the mass air flow (MAF) sensor and clean it with the proper cleaner. Install it and make sure the electrical connector is attached properly.
