Unable to turn on ECO mode
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Seymour1, May 3, 2026 at 5:03 PM.
  1. Seymour1
    Seymour1 Member
    272
    35
    I once could see on the dash that I was in ECO mode. It was a green light reading "ECO". Now I cannot get it any more. The ECO and PWR buttons seem to do nothing. At least there is no change on the dash. I can press the DISPLAY button on the steering wheel until I see "Settings-Press and hold". From there I can select "ECO". From there, I can see "on" or "off". I select "on". Then, there is no "enter" or "back". I wait a while and the menu turns off. But still, there is no designation on the dash that I am in ECO mode. Do I need to visit the dealer?
  2. ChapmanF
    18,707
    I think the "ECO" selection you found in Settings is for whether the multi-information display ECO icon will be displayed: the one that shows above the hybrid-system indicator when you're not accelerating too hard.
    As for the green ECO driving-mode indicator, it seems there are two possibilities to be distinguished: either (1) the button inputs are being recognized and you're in the driving mode you want, but the dash doesn't show it, or (2) the button inputs aren't being recognized and the mode isn't changing.
    Are you confident you can tell the driving difference between the ECO, normal, and PWR modes? It's just a reshaping of the go-pedal-to-amount-of-go curve. PWR mode gives a bigger go response with the first small pedal input (at the cost of sort of flattening out with larger pedal inputs, to end up at the same place). ECO mode is less responsive at the first small pedal input (at the cost of exaggerated response at larger pedal inputs, again to end up at the same place). The same place all three modes end up at full pedal is the car's full power.
    ECO also has effects on heating and air conditioning, which you might be able to notice. If the weather is hot and you have the A/C set to do a lot of cooling, you can probably perceive that it backs down a little in ECO mode.
    If nothing is changing, the next question would be: does the ECU see you pressing the buttons? A scan tool that can display live data from the power management control ECU can show what I think are the states of the ECO button (called "ECO Mode" in Techstream) and of the PWR button (called "Pattern Switch" in Techstream). I've never paid attention to these myself, so I can't say whether they are direct switch readings (ON when you push, OFF when you let go) or readings of the current selected status (staying on after you select). Either way, they should give you an idea what's going on.
    Does your EV switch have any effect, by the way?
    You can also find an "ECO Switch" live-data item in the Air Conditioning ECU. Per the wiring diagram, that's where the wire from the ECO button actually goes. So the A/C ECU applies its ECO-mode power reductions directly, and the power management control ECU knows the setting (to adjust its go-pedal curve) by asking the A/C ECU.
    The EV switch is wired directly to the power management control ECU. You can see the switch input in that data list under the Techstream name "EV SW2".
    The PWR button is wired (hey, there are three buttons, so we need three different ways of doing it) to the ECM—even though in a Prius it's really another change to the go-pedal curve, which is calculated in the power management control ECU. So the power management control ECU knows the state of that button by asking the ECM.
    As far as I'm seeing in an (incomplete, old downloaded) 2010 repair manual, there isn't any PID in the ECM showing you the PWR switch input state. Might be worth scrolling through all the items your scan tool shows anyway; it might exist but unmentioned in that old edition of the manual, or my eyes might have gone right past it.
  3. Seymour1
    Seymour1 Member
    272
    35
    Thank you for the info. I have a "Creader" scan tool. It managed to allow me to calibrate the brakes after replacing two major parts of the brakes. I could never get the Techstream to fully work with my laptop. I will see if the Creader will solve my problem. I cannot tell any difference in between the ECO or PWR mode in A C working.
  4. Seymour1
    Seymour1 Member
    272
    35
    I used my Creader to help confuse me. I got a reading of :"ECO switch: off" and "ECO MODE Cancel: off" I pressed the PWR and ECO while viewing this screen, but nothing changed. Any ideas? IMG_2709.jpeg
  5. ChapmanF
    18,707
    If your Creader is talking to the A/C ECU and shows nothing when you press the ECO switch, that would put my first suspicion on the switch itself, or the switch panel.
    You've mentioned not seeing any perceptible effect from the ECO or PWR buttons. You haven't mentioned whether the EV button does anything. How about the hazard flashers?
    Those are all part of the same little button assembly, so that's why I ask. Also, do they light up at night when your taillights are on?
    You can swap that little button assembly in maybe 20 seconds (ok, maybe not the first time ;)), so if you had access to another one to compare with it, that might tell you something.
    The Creader "ECO Mode Cancel" PID is (I think) showing you a setting you're allowed to make that would stop ECO mode from affecting the HVAC. It's showing as off (i.e. not cancelled) so I don't think it matters here.
  6. Seymour1
    Seymour1 Member
    272
    35
    Chapman, good thinking! The hazard flasher does not work. The EV button seems to do nothing. I will remove and test the switches. Thank you for your help.
  7. ChapmanF
    18,707
    Do the switches light up when the taillights are on, to be seen in the dark?
    I wonder if someone might have popped that panel off for some reason and left the entire connector to that switch assembly unplugged.
  8. Seymour1
    Seymour1 Member
    272
    35
    yes. All of the digits and symbols light up, even with the tail lights off. And the dimmer control works.
    I hope to have time today to check the switches. I need to find a youtube that shows how to remove the panel that houses the switches.
  9. ChapmanF
    18,707
    It's that roughly triangular-ish piece that holds those buttons, and the Park button, and goes around the shifter. It pulls straight up.
  10. Seymour1
    Seymour1 Member
    272
    35
    WOW! I raised the plastic cover housing the switches and as I did, the connector fell away from the switches. I pushed it in until it clicked and everything works. Thank you for your help. I expected something more serious.
    Brian1954 likes this.
  11. ChapmanF
    18,707
    (y)
    Must have been just hanging on by the illumination pin(s)....
